Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 10-05-2010, 02:11 PM   #1396
Send a message via MSN to geubes
Originally Posted by izzyracer View Post
I installed on my daughter's computer running windows 7 and the advance interface is complete, but on my computer running XP it's not. So I conclude that it is an XP issue??? any updates?
Most probably to do with font DPI or the media centre theme you are using.
Try selecting a standard XP theme, or firstly go into properties on the desktop, across to the settings tab, there should be a "Advanced" button there. Click that, there will be a DPI setting. Change this back to Normal Size 96 DPI. Might have to restart the PC to take effect.
Also in the Appearance tab (in the same properties). go into advanced there, choose each option in the drop down, and if it has a Font property, set this to Tahoma, size 8.
geubes is offline   Reply With Quote
Old 10-05-2010, 02:24 PM   #1397
darrenoakley's Avatar
Anyone no if there is any way to limit the end RPM with 518 ? or a cunning way round this if say i only want from 3500 to 5000 or something like that.
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 10-05-2010, 02:46 PM   #1398
izzyracer's Avatar
Trader Rating: 27 (100%+)
You my friend is a genius!
I followed your instructions, and wallah they are there, so somehow my previous settings hid the other options. I truly appreciate it!
Izzy
izzyracer is offline   Reply With Quote
Old 10-05-2010, 02:59 PM   #1399
No Problem I do this kinda support daily.....and I thought work ended at 5pm
Old 10-05-2010, 10:47 PM   #1400
Holmenkollen's Avatar
@ whoopass: have sent you a PM!
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 10-06-2010, 12:23 AM   #1401
whoopass's Avatar
got you PM cheers, ok this is what I did but I have not had chance to test it, will do this Sunday hopefully!
Remove motor from car
Unscrew endbell and hall sensor PCB.
I then placed 2 small pieces of tape over the small circular contacts that could touch the endbell housing (on the removeable PCB/hall sensor).
also I insulated the 3 solder marks on the motor you can see that the motor wires solder onto. easy to see if you hold the motor facing you.
thats it, as I said not yet tested it!
whoopass is offline   Reply With Quote
Old 10-06-2010, 01:00 AM   #1402
COBRARACING's Avatar
Originally Posted by cherry2blost View Post
Hi just to let you know, XTREME STOCK and 1s 120SD in stock NOW in the UK.
www.racersinexile.org.uk
Ive checked out your website and im impressed with pricing and explanations .
welcome on board and any assistance that you might need plese dont hesitate to contact me .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 10-06-2010, 01:19 AM   #1403
I am asking again.
Does anybody know how mouch timing does the turbo add above the dynamic timing in 518Stock and
528MOD?
Is it 0-8deg or is it for example 2 or 3deg/step? More? Less?
snabbgas is offline   Reply With Quote
Old 10-06-2010, 01:44 AM   #1404
TeamWTF's Avatar
In 518 stock, with the data sheet i have downloaded, the increments are 1 degree
So 0-8 degree
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 10-06-2010, 01:50 AM   #1405
Yeah, but it was mentioned earlier that the stock firmware added alot more turbo than the mod.
And it looks the same for mod as it is adding 0-8deg.
It also feels more than 8deg doesn't it?
Old 10-06-2010, 01:55 AM   #1406
its all Digital algorithms it has nothing to do with the settings why the turbo in the 518 is more that the 528 mod its just the way it is to save the esc when in 528 mod mode
Old 10-06-2010, 02:16 AM   #1407
Ok but it still would be very interesting to know how mouch extra timing is applied with the turbo or supercharger or whatever at various settings.
everything else it pretty straightforward like start RPM (clearly indicated by number), and timing punch (RPM/Deg)
I'm very very happy with the performances of these Esc:s!
I'm just the "must know" type
Old 10-06-2010, 09:29 AM   #1408
Is it possible to switch between profiles in the LCD programmer? I canīt get it to work.
Old 10-06-2010, 03:30 PM   #1409
Is it possible to load 518stock onto justock esc, Im sure i read it some where, but it may of been a late night, and wishful thinking
HandS is offline   Reply With Quote
Old 10-06-2010, 04:05 PM   #1410
It will not work im 100% sure of it as the justock uses a different bit cpu which will not allow the justock to run with 518 super stock software .
