Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 05-04-2010, 08:10 PM   #121
gixer's Avatar
Nice one.
Just installed the update and will test it tomorrow.
Only worry is temps as summer is starting to kick in over here.
Cheers
Mark
HB Cyclone (WCE Exotek) x 2, Pro3 (Penguin chassis), Pro4, M-04M (Eunos Roadster)
Losi MRC, Axial XR-10
ERevo Erbe, HPI Firestorm (Nitro), Blitz,
gixer is offline   Reply With Quote
Old 05-04-2010, 09:29 PM   #122
Koen's Avatar
Originally Posted by snowman_evil View Post
As Far as Ive been told, they are the exact same box with all feature the same
Thanks! Trusting on your words I've just ordered a second hand Speedpassion GT2.0LPF and a new Hobbywing USB unit from Hong Kong... total cost incl. shipping approx 100USD
Koen is offline   Reply With Quote
Old 05-04-2010, 10:39 PM   #123
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to snowman_evil
Well I was told by 3 people that its the exact same unit. Im actually usinga speed passion LCD programming card with my hobbywing ESC so that proves they must be the same thing if it works
DEX410V3 - Tekin - Spektrum - Panther
GCRC Raceway - "Lightning"
snowman_evil is offline   Reply With Quote
Old 05-04-2010, 10:48 PM   #124
Originally Posted by hobbywing View Post
I think the difference is: XERUN-60A ESC has a little bigger resistance than XERUN-120A ESC. That means the power loss at the XERUN-60A ESC is also a little larger. But the power loss at the ESC is really very very small, so who cares?
So then if an Xerun-60A can handle down to a 5.5T , surely it can work with a 17.5/13.5/10.5 with supercharger?. As there is only a 0.0003 ohm difference in resistance between the 60A and 120A, which will never be seen, then the Xerun-60A should be good for spec racing?
MoonTrap is offline   Reply With Quote
Old 05-04-2010, 10:56 PM   #125
Send a message via MSN to hobbywing Send a message via Skype™ to hobbywing
A XERUN-60A ESC can work with a 17.5/13.5/10.5 with supercharger.
Xerun-60A ESC is good for stock racing, or somebody will say it is even better, but that is only because of its cheaper price than XERUN-120A.
hobbywing is offline   Reply With Quote
Old 05-04-2010, 11:58 PM   #126
razzor's Avatar
If you racing stock classes the 60A is all you need.
Best value for money !!!!
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 05-05-2010, 12:23 AM   #127
gixer's Avatar
Does this update work on the entire XeRun range?
Old 05-05-2010, 12:34 AM   #128
notatoy's Avatar
sorry no oonly the 60amp and the 120 amp hope this helps
notatoy is offline   Reply With Quote
Old 05-05-2010, 12:37 AM   #129
old-man's Avatar
Does anyone know what happened to the "Its official Tekin Beater" thread? Looks like it got deleted.
I guess it was too embarrassing
old-man is offline   Reply With Quote
Old 05-05-2010, 12:39 AM   #130
notatoy's Avatar
yes as those threads go it is the norm i have seen it many many times they always get deleted
Old 05-05-2010, 12:39 AM   #131
gixer's Avatar
Ok
Thank you.
Old 05-05-2010, 04:49 AM   #132
HI,
would like to get some suggestions on settings off "Supercharged" for 4WD buggy with Xerun-60A and 13.5 Speed Passion motor. Track have long straight (80m) and then many quick turns. Spur - 85, pinion - 21, IDR - 2.4375.
Thank you!
Audrius
www.rc-cars.lt - offroad in Lithuania
www.lasa.lt - onroad in Lithuania
audriusv is offline   Reply With Quote
Old 05-05-2010, 04:51 AM   #133
To Hobbywing ,
Below are some Comment on 1.61 Beta, please conside those on final version of software :
1. It would be better to see the firmware version of ESC while the LCD card communicate with ESC.
2. For profit1/2/3, if possible it would like to see profile 1 for stock, 2 for mod..etc.
It means it will upload the correspounded firmware to ESC while you change the profile.
So, no need to bring a computer for RC car playing....
3. In this Beta version, if my ESC loaded as stock mode.
What are recommended setting for use a mod motor like 5.5T.
It is becasue i may attemp stock & mod class within the same day but no computer for reload firmware to ESC.
mos-leung is offline   Reply With Quote
Old 05-05-2010, 06:49 AM   #134
Is SC RPM the same as start or end rpm?
Old 05-05-2010, 07:02 AM   #135
Joel Lagace's Avatar
Originally Posted by mos-leung View Post
To Hobbywing ,
IF while your ESC is connected to the PC you label 1,2,3 to what ever name you want and then load to ESC... Anytime after that that you connect your LCD to just the ESC you will see those 3 custom names you chose.
for instance my:
Buggy ESC has 1-Buggy 2-Buggy slick track 3 F'ing crazy
SC10 ESC has 1-SC10 2-SC10 slick track 3-F'ing crazy
When ever the LCD connects it shows these profile names. Same when i connect to the PC now. As the PC and the LCD read the profile from the ESC unless you upload otherwise from the PC..
Does that make sence?
HOBBYWING: one thing that needs correction is the PDF file. The terminology used does not match the last 5 settings on the ESC LCD read out... You have to remember what setting your own because the names of the settings are not identical on the PDF as they are on the software and LCD
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
