Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 09-27-2010, 10:11 PM   #1306
Bishop's Avatar
10.5T apparently do not handle the timing like a 17.5 or even a 13.5, so you need to go easy on the timing, so yeah you can use the STOCK firmware.
For on-road I'm using a FDR of 7.1, but I thinking of going 7.4 to try some stuff.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 09-27-2010, 10:29 PM   #1307
COBRARACING's Avatar
Originally Posted by mok View Post
I managed to cook a motor yesterday the first time I used this esc..
Are there any starting setups for a short course truck?
What software version should I be running for a 10.5T motor? stock or mod?
-Mark
stock software 518 but dont load it up so much with timing and boost
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 09-27-2010, 11:39 PM   #1308
izzyracer's Avatar
Trader Rating: 27 (100%+)
Default New
Oops delete
Izzy
izzyracer is offline   Reply With Quote
Old 09-27-2010, 11:39 PM   #1309
izzyracer's Avatar
Default New to programable esc's
I just purchased the xerun 120a 2.0 and program box and should be here soon. I will be pairing this up with my LRP 17.5 brushless motor and i am lookong forward in learning to maximize this ESC's capabilities. I am also new to programing, any word of advice would be appreciated. Also will the program box work with my SP Citrix Spec esc? Thanks in advance.
Izzy
Old 09-28-2010, 12:42 AM   #1310
AGNO's Avatar
What model of LRP 17.5? X12?
The program card LED Citrix not work with the Xerun.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 09-28-2010, 12:51 AM   #1311
AGNO's Avatar
Originally Posted by jazzck View Post
Hi,Guys pls help ask I used 512 stock....
10.5t motor can used at FDR??????
512? maybe 518 ...
This is my setup for 10.5, is not optimal because I still have to improve it, but worked very well with high ambient temperatures
Old 09-28-2010, 12:59 AM   #1312
izzyracer's Avatar
Actually an x11
I mean, i want to use the program box with the sp cirtix spec esc to change brake and drag brake, not possible?
Izzy
Old 09-28-2010, 01:18 AM   #1313
AGNO's Avatar
Actually an x11
Unfortunately, the X11 I have not tried, then the only advice is to start with parameters recommended by the manual supercharged Hobbywing.
I tried the program box LCD on Cirtix but does not work.
Old 09-28-2010, 05:26 AM   #1314
ShadowAu's Avatar
Is there anywhere I can download a current version of the setup sheet?
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
Old 09-28-2010, 07:16 AM   #1315
AGNO's Avatar
Test here
http://www.mediafire.com/?zhnwmmhz34o
Old 09-28-2010, 03:05 PM   #1316
ShadowAu's Avatar
Thanks but I have that one and if you look at the SC Punch its not what the current software uses for settings... and I don't have anything to modify PDF files
Old 09-28-2010, 06:29 PM   #1317
whoopass's Avatar
cobra, I have an issue with the 120a v2.0 ESC. I have purchased a red series corally 13.5 motor, ran it once and it was fine, on the second time the car ran at half power and the green light was flashing on the ~ESC indicating ESC has overheated.
Obviously it has not, I assume this type of motor does not work with the ESC?
is that correct? have you seen this issue before?
cheers
Running 518 stock setting, with 1.79 DB also.
whoopass is offline   Reply With Quote
Old 09-28-2010, 10:24 PM   #1318
cheers
Dear loyal customer
Yes you do have an overheat problem .from what i am aware of hobbywing esc's are set up to run with motors that have true windings to the kv rating .I know there are motors out there that are example 10.5T but something like 4500kv which is about 1300kv over the standard 3200kv that a 10.5t is rated .
Now if you have high settings on such high kv rated motors yes they will overheat .all motors are different nothing is accurate especially kv ratings and turns as well as internal resistance but also high fearing or low gearing depending on track layouts and lengh there are many things that contribute to heat.
please send me an email at [email protected] and we can take it further and help you solve the problem .
regards Angelo
Old 09-28-2010, 10:41 PM   #1319
Hi guys
Just some news from hobbywing that anyone who purchases there product direct from online stores in Asia or Ebay faces problems with tech support and after sales service .If the store wont help you then the problem will lie on you and costs will be added if the product needs to be sent back to hobbywing for service or replacement .we dont wont you risking your hard earned money as we know its hard to come by .we make agreements with stores who carry the products that they must carry the support for there customers .
We have been finding alot of none authorised stores in hong kong have been getting the products via grey import as we call it over border crossing from china which is hard to police and selling them to online stores .
when the product is sent back at your cost and found the receipt to be of an online nature from Asia or ebay the costs will be added to your repair or replacement .
We need to protect the distributors and legitimate Authorised dealers from around the world as we have been getting many complaints about sellers who dont want to support after sales service and customer after sales tech support.
I will always be here to support you all and always will 100% but if the product is sent back to factory as stated above then there is nothing i can do its up to the factory then and there policy to deal with the matter .
we are not here to screw you we are here to help and give you the best support possible which means replacements and support or repairs from reputable dealers and distributors networks but we also have to look after the people who do the right thing and take the appropraite channels to purchase and we dont mean you customers we mean the distributors and dealers .
Pricing will not change pricing will always be competative i assure you of this .Also hobbywing will also ask for the warranty card that is supplied with the esc to be filled in and the place of purchase and cop yof receipt attached and sent back to the factory .we want to build a database.
we want to service you better than before and not for you to have to wait 6 months to have a email answered or 6 months for a repair .
ok guys thank you for your time .
Any questions please fell free to contact me .
Old 09-28-2010, 10:59 PM   #1320
Holmenkollen's Avatar
cheers
I have had problems with 3 Corally Red Series Pro motors (2x4.5, 1x5.5) which had similar problems. Worked fine for a while then they gave up. This with a LRP TC-Spec. You can´t change the timing on these motors and I think they´re default set at 30 degrees.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
