Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 09-19-2010, 04:04 PM   #1261
CobraRacing - The message says it is a database update (1.79) rather than a new version of the software. The start of the message is attached below.
Foodie - I just tried it your way and it worked. Thanks very much for the help.
readme.txt
2010-9-17
CAR_ESC_readme.txt
database version:1.79
The new firmware "100912-2R" of XERUN-80A,XERUN-150A EZRUN-SC10 ,EZRUN-SC8 has the following improvement:
1.Eliminates the bug of ESC shortly been shut off(usually several seconds) caused by mistakenly thermal protection
2.Optimize the switching of forward and backward
Steve Leake is offline   Reply With Quote
Old 09-20-2010, 09:09 AM   #1262
dameetz's Avatar
Default HW stock motor
Cobraracing or anybody, whats the spec like for HW 11.5T stock motor? Can't find any info on it. Can the timing endbell be adjusted. Looks cool though. If anybody has experience running them can you pls share as well.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 09-20-2010, 01:55 PM   #1263
njt
njt's Avatar
my speedo as also a updated to 1.79,
also if i click on the device and then the brushless system analyzer it briefly shows a data recorder graph, this then disappears if the program box is connected
if the program box is not connected you can see the data recorder is this a on going up date ?
njt is offline   Reply With Quote
Old 09-20-2010, 05:16 PM   #1264
COBRARACING's Avatar
The new Hw motors the light blue and silver can have no mechanical end bell timing adjustment .Mechanical timing causes to much heat build up and pinging.HW use internal electronic digital timing which is 100% acurate compared to the old mechanical timing
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 09-20-2010, 06:07 PM   #1265
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
Just wanted to say a quick hello from the off road world.
I Attended the J Concepts NE Championship race last weekend. Ran my HW 120 in 13.5 and open modified. Never changed motors. Used the same HW 13.5 motor in both class - more than fast enough- too fast actually. In 13.5 class I could easily pull anyone on the straights and over the triple jump. Even against the mod guys running 8.5 or whatever. Motor and speedo never got hot. Should have cranked it up some more!!!
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 09-20-2010, 09:31 PM   #1266
Afazli79's Avatar
Send a message via MSN to Afazli79
Originally Posted by COBRARACING View Post
The new Hw motors the light blue and silver can have no end bell timing adjustment .
This new motor design 10.5T I've already tried. Its runs cooler by minus 20F compare to Orca motor that I'm using now with the same setup.
Good : Nice design, colour and run cooler
Bad : Less torque but mid and top is acceptable. Holes on the can is too big and myself experiencing motor jam once due to sand going inside through the holes and need to cover some holes.
Overall performance thumb up!!
Team MaxPower Malaysia...
Web : www.maxpowerbattery.net / www.bizonline2u.com
MaxPower / HobbyWing / Team Powers / Hudy / Xray / Robitronic / Tamiya / Tekin / Orca / LiteModz / Huge RC / MuchMore / LRP / Exotek / Smokem / SpecR / Atomic / SpeedMind / Sorex / Fijon / Paragon / Team Associated / Serpent / DS Racing
Afazli79 is offline   Reply With Quote
Old 09-21-2010, 04:49 AM   #1267
jeppesen's Avatar
Do you know how big the rotor is?
12mm - 12.3mm - 12.5mm?
Large scale racing with RS5 Touring car, Sanwa, Sav÷x, Modelsport engines and Shell V-Power
1/10th Racing with RGT R2, Hobbywing, Gens-Ace and Absima.
jeppesen is offline   Reply With Quote
Old 09-21-2010, 11:11 PM   #1268
irgo's Avatar
No
cobra when is the new firmware with rpm log is released?
Quark Force
irgo is offline   Reply With Quote
Old 09-22-2010, 08:26 AM   #1269
csracing's Avatar
Trader Rating: 22 (100%+)
Is the Xtreme Stock the latest? I don't see anything listed on the HW website that talks about a V2.1? Very interested in trying the 60A Xtreme for 17.5T off road but getting a bit confused over the versions..
CSR
csracing is offline   Reply With Quote
Old 09-22-2010, 04:32 PM   #1270
CSR
There is 3 new esc's 120 amp 2.1v ,justock and the 21.v 120 amp 1s
Old 09-22-2010, 04:33 PM   #1271
coming soon ,michael is working on it now.
Old 09-22-2010, 04:34 PM   #1272
csracing's Avatar
Where can I get any of them?
Old 09-22-2010, 08:43 PM   #1273
irgo's Avatar
excelent!
This is a great news for hw and sp, community.
We have engineer on the right track.
Thank's
Quark Force
Old 09-23-2010, 08:57 AM   #1274
So what are people finding wrt adjusting timing on the motor. is it OK to just use timing in esc? or combo with endbell timing? Seems like did motors with different default timing can throw you off on setting the esc.
Surge is offline   Reply With Quote
Old 09-23-2010, 09:44 AM   #1275
Bishop's Avatar
I think in theory you can get the most from motors using no endbell timing, or generally with low to no natural timing, I think timing on the motor can work against the best setup of esc turbo type timing.
The more timing a motor may have in another way, will create heat and stop you adding timing via the esc, and really I suspect your best map or timing profile for power 'and' speed will come using esc timing alone.
Of course I have read in a couple of posts where some have said that felt they got a better setup using some endbell timing, but I think it's a nice way to make the setup more complex.
I'd rather let the esc do 'all' the work, then I can also just plug in the box and tweak settings the easy way, when I started using mine I set the timing on my SP10.5 to 0, so far have not felt the need to change it.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
