Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 09-17-2010, 04:46 AM   #1246
Born2Run's Avatar
Originally Posted by Benzaah View Post
Here are my settings from a big meet here last weekend. Car was wicked fast.
T3 FDR 4.9
Duo 2 17.5 timing between 1st and 2nd tick approx 10 degrees
Drrs 2
AMTS 21*
start rpm 10500
SC boost 3
SC delay 0.2
punch -2
Car ran 0.2 slower than a Tekin v208 with a 14yo gun driver vs myself a 34yo mid pack hack. Very happy with this set up.
Last Sunday i tried your setting on a friends car.Was fast but with my settings (rpm 4.500,DRRS 7, SC Bost level Max) he was faster.Look your self at the white NSX in no2 position:
With your settings
http://www.youtube.com/watch?v=ufzrdZr6Z88
Same car and driver with my settings:http://www.youtube.com/watch?v=HybJM...eature=related
Whatever
Born2Run is offline   Reply With Quote
Old 09-17-2010, 04:22 PM   #1247
Is work on Xtreme Stock 1S lipo ? sorry i did *t find answer
getfriky is offline   Reply With Quote
Old 09-17-2010, 06:21 PM   #1248
JKL1031's Avatar
Yeam im running the Xerun 120A and the hobbywing motor 5.5t combo. Its quick, but doesnt really seem all that so I'm going to try 528mod. My battery is a 5200 30c turnigy pack.
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
Old 09-18-2010, 02:38 AM   #1249
COBRARACING's Avatar
My advice to you is try another brand of lipo (nothing against hobbyking) but we have tested there turnigy packs on 1/10th scale and 1/8th scale and the voltage drop on scale is very rapid not linear whatsever .
There packs are just not cut out for racing .
Alot of the other brands like intellec ,he energy,pro amps,orion and so on had a voltage drop on first load but then levelled off and were linear for a period longer than 8 minutes before they dumped but the turnigy drop 2 minutes after its start up load .
so please try another lipo brand and you will see the difference dont forget 5.5T do demand lots of current and a stable current and voltage drop .
let me know how you go
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 09-18-2010, 03:17 AM   #1250
I'm looking to purchase an extra esc for 1/12scale but I have some questions (I've been out of racing the past 12 months):
If I buy the Xerun 120A 1S and I install the new software 422, I have all the extra's I need (boost - turbo ...).
I can use it in my 1/12 on 1 cell lipo or even tranfer it in my Durango on 2 cell lipo's.
Does the DC/DC booster work good ?
Can someone report on the use in 1/12 scale ?
Bronco1 is offline   Reply With Quote
Old 09-18-2010, 03:58 AM   #1251
Finally received my 1S yesterday, in black for stealth
After a few false starts got it going well, the DC step up works fine, no radio problems, though im not so sure what should be happening when the lipo cutout kicks in, i seemed to lose steering at the end of the straight, so i just turned the cutoff off.
it seemed to require a different setup and gearing approach than the locals with LRP and BD's, i used higher settings, and lower rollut (43mm in 10.5t)
After racing finished, turned down the settings, and dropped a few teeth to see how it would go with a mod motor, it was really fast, and ultra smooth. Motor was dead cold but the speedie cover plate was quite hot. Might be worth putting the heat sink on if your body allows when running mod.
I believe the booster is self detecting, requires no changes. I did hook up a 2S pack to make some setup changes between runs and it worked perfectly.
Its a bit bulky compared to a Tekin or BD, but have to keep in mind it is a true 120 amp speedie, not a stock specific unit.
Im sure we will get more out of them, just a matter of trial and error
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 09-18-2010, 04:09 AM   #1252
Thanks for the quick reply.
I haven't seem them in black yet. Could you tell me how thick it is without the extra heat sink ?
I have Thunderpower 5000mah 40C from last year. Would they still be sufficiant running a 10.5 LRP (3 year old motor)?
Could you show me a pic of your 1/12 car with this esc installed?
Old 09-18-2010, 04:49 AM   #1253
may i know what is maximum temperature for the Xerun 120A could survived? friend of mine running esc Orca TC Spec at 5.5t motor... the FET burnt when esc temp is 80-85'c... the motor temp is about 45'c... thinking about switch to Xerun...
zamrioo2 is offline   Reply With Quote
Old 09-18-2010, 04:56 AM   #1254
TRF4evr's Avatar
just wanna ask if anyone used the hw518 software on a lrp x12 17.5 motor, any suggestion on what setup and gearing to start with.
TRF - HUDY - Much more - Ride
Proamp Lipo - Speedpassion
www.feralbatteries.com
TRF4evr is offline   Reply With Quote
Old 09-18-2010, 11:46 AM   #1255
JKL1031's Avatar
i figured the lipo would be the first weakest link.
I have a suggestion tho if possible: Can each mode or profile on the program card carry a different software version as well; having a mod profile, then a stock profile w/o going to the computer?
China Lipos
China Speedos
China Chargers
Old 09-19-2010, 12:52 AM   #1256
I have version 1.62 of the Hobbywing software on my PC and yesterday when I opened it there was a message saying there was a new version of the database available - 1.79. When I click on 'download' it then returns a message saying 'update failed'.
Am I doing something wrong or did anyone else have the same problem?
Steve Leake is offline   Reply With Quote
Old 09-19-2010, 03:40 AM   #1257
Dear steve
I will only tell you there is an update only if you have downloaded the update but no such software update as 1.79 is available .But i know some people are having failures sending info and dowloading when they are using windows 7 .Ill check on it and let you know .
regards Angelo
Old 09-19-2010, 03:42 AM   #1258
No
Old 09-19-2010, 03:49 AM   #1259
For it to download the update you need to right click the USB link .exe file, and press "Run as administrator", then you can download it
But i dont know what it does.
Foodie is offline   Reply With Quote
Old 09-19-2010, 05:36 AM   #1260
blade072's Avatar
Trader Rating: 98 (100%+)
just want to confirm how good the xtreme is......
today i smashed into a barrier head on (on a warmup lap)
the esc came apart and i had no drive and i thought oh no its dead....
clicked it back together and it was fine...
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
