Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 01-07-2015, 10:16 PM   #12106
Tandum4056's Avatar
Trader Rating: 97 (100%+)
Quick question, I have a V3.1 120A. I haven't used it in a while so my recollection of it's functions are vague. When I changed the setting to blinky (no timing/ turbo) the power button blinks red. The controller seems to works fine but i could of sworn it used to blink green. Is the red blinking correct or is something wrong?
Thanks in advance!
Tandum4056 is offline   Reply With Quote
Old 01-08-2015, 04:17 PM   #12107
Tandum4056's Avatar
Thanks in advance!
Anyone?
Old 01-08-2015, 04:48 PM   #12108
RoyB's Avatar
Trader Rating: 16 (100%+)
Thanks in advance!
My V3.1 stock spec blinks red.
RoyB is offline   Reply With Quote
Old 01-08-2015, 06:34 PM   #12109
Tandum4056's Avatar
Thanks, i appreciate the input. I would imagine the 120A v3.1 would be the same. Maybe someone else will chime in and confirm.
Old 01-08-2015, 06:56 PM   #12110
OrganicMechanic's Avatar
Trader Rating: 35 (100%+)
1S or 2S?
My V3.1 120A 1S esc blinks red @ neutral and rapid green on throttle with zero timing.
OrganicMechanic is offline   Reply With Quote
Old 01-08-2015, 08:24 PM   #12111
Tandum4056's Avatar
Originally Posted by OrganicMechanic View Post
1S or 2S?
Thanks! I have the 2S 120A V3.1, so i would assume this version should be no different and blink red as well in neutral.
Old 01-09-2015, 09:11 AM   #12112
YoDog's Avatar
Trader Rating: 26 (100%+)
Blinking RED @ neutral is normal for blinky mode and if I remember correctly, it blinks green if there is a sensor failure.
Then again there is always the manual...
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 01-09-2015, 03:54 PM   #12113
gabc's Avatar
In non-turbo and non-boost mode my V3.0 is solid red when throttle is at neutral and blinks red when I give it throttle. Is this normal?
gabc is offline   Reply With Quote
Old 01-09-2015, 04:00 PM   #12114
Tandum4056's Avatar
Thanks! I checked the manual but i could not locate this info in there.
Old 01-09-2015, 05:59 PM   #12115
YoDog's Avatar
Do you mean it blinks when you give it slight throttle or full throttle?
If it's slight throttle, your neutral point needs to be calibrated or you may have adjusted your Throttle trim after calibration.
Is your ESC set to "Blinky" mode or is the Boost and Turbo adjusted to "0" zero?
Old 01-09-2015, 06:20 PM   #12116
FastPete's Avatar
Trader Rating: 44 (100%+)
It blinks red at neutral.
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 01-10-2015, 03:45 PM   #12117
idbdoug's Avatar
Trader Rating: 33 (100%+)
Perfect, exactly what you want it to do. Since its 1 cell, red light will blink at .28 seconds/flash. Flashing green is sensor failure
idbdoug
www.serpentamerica.com
www.r1wurks.com
www.falconsekido.com
idbdoug is online now   Reply With Quote
Old 01-10-2015, 03:49 PM   #12118
idbdoug's Avatar
I know this is HW software section but I couldn't fine a HW motor thread.
Here we go: Has anybody tried the Xerun 17.5 V10 motor in stock TC or stock 1/12?
idbdoug
www.r1wurks.com
Old 01-10-2015, 04:45 PM   #12119
Tandum4056's Avatar
Thanks everyone; all set and ready to go!
Old 01-13-2015, 03:53 AM   #12120
Miholc's Avatar
I have extensively tested 4 pole motors in the last few weeks. Over 320 measurements, and still going on. I will present the results next month here on RC Tech.
I really liked how Xerun 150A performed during 4S and 6S LiPo tests. How nicely one can tume the timing to suit each motor and load.
But I really miss the turbo function for on-road use of our GTe class and in also for C electric class.
Can Xerun 150A be custom updated with Turbo/boost timing? I can be specific... turbo timing range the same AMTS timing is from 0 to 26.25. Setup for turbo slope, disengage and you can program start RPM. So a mix between turbo/boost on Xerun V3.1 120A.
I would really like this function, since I reall measured each motor at different timings and understand now quite good what is happening. And on some Y wound motors works like "charm" :-) (proved later on on Tekin RX8 ESC). Also Delta would motors on 6S at >2000W and almost 50000 rpm do show similar behaviour :-)
Please, please, please! You can email me at mihah44(at)gmail.com ! Thanks!
https://www.facebook.com/mholctuning
www.lipo.si
Miholc is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Monsta
