Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 12-19-2014, 01:08 PM   #12091
OrganicMechanic's Avatar
Trader Rating: 35 (100%+)
Originally Posted by waltss2k View Post
Trying to find out if J Stock can be used in Wgt with 1 cell and 13.5
Not without a 1s booster
http://www.falconsekido.com/products/1s-dc-dc-booster
OrganicMechanic is offline   Reply With Quote
Old 12-31-2014, 03:28 AM   #12092
Hello,
Could someone help me out?
Just installed a v2.1 120a for someone.
When we update the software, from esc and box,
We always get the notice on he box update software.
Witch software do you guys recommend for the esc and the settings box.
The esc now doesn't make speed. When you put feeling or timing on it.
Changed already sensor cable. And motor is okay on my v3 Speedo.
Best regards
DW Hobbyshop
Serpent, VBC racing, muchmore racing, skyrc, nosram,...
Driving a ERYX3.0
stofke is offline   Reply With Quote
Old 12-31-2014, 05:46 AM   #12093
Originally Posted by stofke View Post
Hello,
Best regards
Did you reset the Reverse/Neutral/Throttle points after the update?
Old 12-31-2014, 06:25 AM   #12094
Recalibrate throttle between remote and esc. Set epa throttle trim to 100% then recalibrate. Hope this works out for you. I had issues with my old hobbywing ver 2.1 and ended up upgrading to S.P pro esc.
rudeboy03 is offline   Reply With Quote
Old 12-31-2014, 06:48 AM   #12095
Pro10noob's Avatar
Never had any issues when upgrading software.
Upgrade software, recalibrate all with epa on 100% and then do the settings again(turbo, boost a.o)
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-31-2014, 07:12 AM   #12096
I should add it was a V3.1 1S that needed the throttle/reverse/neutral points reset after esc firmware update. Will be the same for a V2.1 however, same firmware.
I was rocking about ~75% throttle for 2 heats until I figured it out, reset the points and walla 100% throttle. Talk about frustrating , I was getting flat out drug down the straight.
Old 12-31-2014, 07:49 AM   #12097
Pro10noob's Avatar
Was talking about both ESC types Organic.
Got V2.1 1S V2.1 2S and the V3.1 2S
Every time i updated the ESC i followed that procedure and it works flawless.
Regards Roy
l===/o\===l
Old 12-31-2014, 11:27 AM   #12098
Regards Roy
I know you were Roy.
I was adding clarification to my previous post for stofke.
Old 01-03-2015, 05:26 AM   #12099
A question for Angelo:
When the new Android/iOS version comes out will we have to get the Bluetooth programmer or will we be able to use a cable and our existing programmer boxes?
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 01-03-2015, 08:04 AM   #12100
Hello,
I recalibrated the speedo. Only problem is when i put latest mod or stock software on it, i can't connect program box. Even when i update the program box. I can chose between 3 softwares for the program box. But always get the notice: software update needed. Can not even do settings with PC.
Old 01-06-2015, 07:31 AM   #12101
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
I'm having problems getting the PC software to connect to the programmer box OR the ESC. Any issues with Windows 8 (I've tried x86 and x64 and both fail). When I open the V3.43 software it says, "Device Cannot Be Opened."
I've tried connecting everything first as I've seen earlier in this thread and I've done before. Not sure what could be going on. Any tips or pointers?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 01-06-2015, 08:50 AM   #12102
bdmpastx's Avatar
There will never be a bluetooth module for IOS. The reason is Apple will never allow the Serial profile to use on Bluetooth. Trust me, I know. It would open up so many doors if they would.
He is talking about a Wifi module that will act as a router/webserver that can send serial commands to the ESC. In saying that, I would assume a whole new box would be needed. I have worked on similar items. Fn Apple could make this so much easier if they would open that BT profile.
bdmpastx is offline   Reply With Quote
Old 01-07-2015, 03:56 AM   #12103
I am IOS dumb but my questions was would we be able to use either. Bluetooth can have issues based on versions on either end so a wired connection may still be preferred.
NORCAR @ The Gate
Old 01-07-2015, 11:10 AM   #12104
COBRARACING's Avatar
you will have to use the wifi module that will be available for purchase .
COBRARACING is offline   Reply With Quote
Old 01-07-2015, 02:20 PM   #12105
Thank you, I will be looking forward to the release.
NORCAR @ The Gate
