Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 11-09-2014, 12:05 PM   #12016
Default HW V3.1 1S firmware update failed
I have just tried to update the firmware on a HW Xerun V3.1 1S ESC to the latest “V3.2_140627_Beta”, and midway through the update an error occurred and the update failed. Now, the ESC will switch on, but do nothing else (it won't even turn off again via the switch).
Neither the USB Link software nor the program box will detect the ESC at all, and it doesn't respond to throttle/brake inputs, and won't calibrate. The ESC was working OK before I attempted to update the firmware. I own several HW ESC's, and have done many updates, and this is the first that has failed, but I am still seriously unimpressed with this. I have only just bought the ESC (used), and I now have to contact the previous owner for the original purchase details to see if I can even get it repaired/replaced in the UK under warranty.
Toon is offline   Reply With Quote
Old 11-09-2014, 06:20 PM   #12017
COBRARACING's Avatar
Can you please give me the warranty code or serial number if you have them and i will sort it out for you dont worry that issue comes under a factory defect .
please get me this information sent to ae@hobbywing.com
regards Angelo
COBRARACING is offline   Reply With Quote
Old 11-10-2014, 04:33 AM   #12018
bigcracing's Avatar
Trader Rating: 32 (100%+)
I have a just stock ESC and am having problems with getting the LCD program box to communicate with it at all. How are you supposed to hookup the LCD programm box.
It will not even programm manually it is probably somthing I am doing wrong.
My LCD programmer has the latest software which I have read it might be the problem Maybe?
Thanks Chris
bigcracing is offline   Reply With Quote
Old 11-11-2014, 07:21 AM   #12019
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Just purchased a xerun 120a v3.1 for mod. Can anyone point me to a good starting setup? Please post up or pm me. thx
Josh-n-ya is offline   Reply With Quote
Old 11-11-2014, 10:25 AM   #12020
JayL's Avatar
Josh: I'll get Brandons settings for you.
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 11-11-2014, 02:14 PM   #12021
Josh-n-ya's Avatar
sweet!
Old 11-18-2014, 03:24 AM   #12022
I'm having my first race in 17.5 boosted class here by us, anyone want to share a good start up on the V3.1 with V10 motor? New to boost and turbo so I don't want to cook my motor first time out. Running rollout of 32.3
SRJRacing is offline   Reply With Quote
Old 11-18-2014, 06:09 AM   #12023
ByteStream's Avatar
Angelo,
Has the latest firmware been sent to ROAR for approval .. I don't see it on the list as of today.
Thanks,
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 11-18-2014, 07:00 PM   #12024
bigcracing's Avatar
Hello Angelo I have sent you a couple of pm with no response. Please respond soon.
Thanks Chris
Old 11-18-2014, 07:51 PM   #12025
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I'd try this rather than PM. I usually get replies inside of 24 hours.
For the poster above looking for mod starting settings feel fre to email me
andrewdoherty @ ya ho o .calm
AWD
Old 11-18-2014, 10:21 PM   #12026
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
Default Upgrade failed
regards Angelo
I just had the same thing happen. Just purchased 3.1. Calibrated initally ok. Went to upgrade and got upgrade failed. Now it's solid red and does not respond. Initiated RMA request with falcon sekido. Anything else to do?
HBRob is offline   Reply With Quote
Old 11-19-2014, 12:07 AM   #12027
Barry_Hughes's Avatar
Thanks Chris
Angelo always says don't use the pm
Email him with your query and you normally get a super fast response
use ae@hobbywing.com
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 11-19-2014, 07:24 AM   #12028
Trader Rating: 77 (100%+)
Without reading all 802 pages, simple question.
Can this esc be used in 1s 1/12 scale? I have one for my TC and love it but all the reading I am doing it doesn't appear you can.
Follow up question if the answer is no. Does Hobbywing make an esc for 1s?
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 11-19-2014, 09:10 PM   #12029
Can you use it for 1s? Yes. But I would recommend the 1s 3.1 far and away over making the 2s work. The built in cap and booster make a very tidy install.
Old 11-20-2014, 12:40 AM   #12030
daleburr's Avatar
You can use it, but you need a separate voltage booster like this one:
http://www.rcdynamics.co.uk/Booster.html
If you're going out and buying an ESC just for 1/12, I'd get the 1s version. If you want an ESC that can also be used in other classes (2s), then boosting the 2s version is a good option (which is how I run mine).
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
