Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 05-04-2010, 10:24 AM   #106
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by g26er View Post
Can someone tell me if i got this right...
You need the advance LCD box to update the firmware + the LED box to change the settings. Is that right? Couldn't you just use the advance LCD box for everything?
Thanks!
If you update the LCD box as well, you can use the LCD box for both.
defcone is offline   Reply With Quote
Old 05-04-2010, 10:29 AM   #107
Exactly what I wanted to know.. thanks!
g26er is offline   Reply With Quote
Old 05-04-2010, 10:29 AM   #108
dameetz's Avatar
Thanks!
Now you can use the LCD box to update and setting up all the esc's parameters. No need to use the LED box anymore to set it up.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 05-04-2010, 10:35 AM   #109
razzor's Avatar
Thanks!
On earlier beta software that was the case where you had to use the led programmer and not the LCD and PC interface..
The new 422 software you can use all features on the lcd programmer and the pc interface.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 05-04-2010, 11:12 AM   #110
Joel Lagace's Avatar
So i finnaly got my LCD box. Ill be testing out this new firmware on my GT2LPF SPeedpassions
Question. I have the new HW SOFTWARE on my pc now. The drop down only shows 420.. How do i get previous firmwares? And how to get them to show up in the drop down box? As it is i have 2 HW softwares on my pc one shows 420 and the other 225. Is there not a way to have all the firmwares usable within one program?
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 05-04-2010, 11:18 AM   #111
Jochim_18's Avatar
So can you use the Speed Passion Low Profile Ver. 2.0 with the new Hobbywing stock Software? I just like the carbon Fiber look better
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 05-04-2010, 11:59 AM   #112
just flashed and tested my carbon LPF... works nice... burned off a set of holeshots in the street ooooooooooops
www.rcottawa.com
Old 05-04-2010, 12:39 PM   #113
Any suggested starting points for DRRS and ATMS when running 422 with a SP 17.5 V3 timming on the motor at 0
Regards
Michael
XRAY T4 2015 | Hobbywing Club Spec | Thunder Power 21.5
miku is offline   Reply With Quote
Old 05-04-2010, 12:59 PM   #114
razzor's Avatar
Regards
Michael
start with the factory defualt settings and make changes from there.
Also read the guidelines/tips document as it has suggestions for 17.5, 13.5 and 10.5
Casterracing ZX1.5R
Old 05-04-2010, 03:21 PM   #115
Yes, defo, theyre all the same.
maxg123456 is offline   Reply With Quote
Old 05-04-2010, 05:20 PM   #116
Koen's Avatar
Hi,
how exactly did you get the hobbywing software on a speedpassion GT2.0LPF ESC?
with the optional Hobbywing "2 in 1 box (LCD)" or the optional speedpassion "LCD Program unit"? Or can both be used?
Thanks!
Koen
Koen is offline   Reply With Quote
Old 05-04-2010, 07:34 PM   #117
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to snowman_evil
Originally Posted by Koen View Post
Hi,
Thanks!
Koen
As Far as Ive been told, they are the exact same box with all feature the same
DEX410V3 - Tekin - Spektrum - Panther
GCRC Raceway - "Lightning"
snowman_evil is offline   Reply With Quote
Old 05-04-2010, 07:45 PM   #118
Im going to be getting my xerun 120amp esc very soon and going to be running it with a tekin 17.5 motor. my LCD box says 1.05 which ive been told is actually the 1.61 version but it just says 1.05. Is this correct?
What would be a good starting point for the speedy setting on a medium size track with a few straights? Just a rough starting point would be great for timing on esc, timing on motor, boost, end RPM etc...
Thanks for any help or advise.
Old 05-04-2010, 07:46 PM   #119
Hi,
Thanks!
Koen
I upgraded my speedpassion LCD to the latest software and then installed the 422 to the car and all works well.
Old 05-04-2010, 07:51 PM   #120
im not an LCD box expert but this is what i have learned on and off the record
-LCD box are the same and will do the same job. (hardware versions are different but the desktop software will update the box)
-Desktop software from Speed passion works on the Hobbywing box
-Desktop software from the Hobbywing works on the Hobbywing box
-I have been able to flash firmware on my SP GT2.0LPF ESC's using the hobbywing box and Hobbywing software.
-I have been able to flash firmware on my SP GT2.0LPF ESC's using the Hobbywing box and Hobbywing software.
www.rcottawa.com
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
