Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 10-23-2014, 02:17 AM   #11971
COBRARACING's Avatar
Hello friends
I would like you guys to tell me what features you would like on our Hobbywing products i can say a larger bec like 7.4v 6 amp is on the cards but id like some ideas from you the customers i wont promise that they will be implemented that will all depend if they can be done in the hardware and software.
post your ideas here.
thanks your friend always Angelo
COBRARACING is offline   Reply With Quote
Old 10-23-2014, 05:04 AM   #11972
Default New features
Angelo
There is a device available that you connect to the sensor lead that by lighting one of 3 LED's in turn tells you if the sensor board and sensor cable are working properly. if that feature could be incorporated that would be really useful in my opinion.
Bosscat is offline   Reply With Quote
Old 10-23-2014, 05:38 AM   #11973
Bar
Originally Posted by COBRARACING View Post
Hello friends
If we are talking ESC's I would say a little smaller, especially with current chassis design getting narrower, better brakes for spec racing, LRP and others are well ahead on this front. Love the built in switch, maybe a little more robust, seen a few with the switch faulty, oh and make it waterproof
Luke Burr
Bar is offline   Reply With Quote
Old 10-23-2014, 06:34 AM   #11974
DriveItLikeYSIT's Avatar
Trader Rating: 92 (100%+)
Hello friends
a HW app for smartphones to adj esc settings
Current limiter and custom throttle curve esc settings
Smaller & lighter 1/8 scale ESCs
Motors with ceramic bearings installed
Motor sensor wire harness
TEAM DRIVER==> BocaBearings|Pro-Line Racing|HWNA|Gens ACE|
EBSL - HW XR8 SCT PRO ESC & HW G2 4300kv motor
EXOTEK 22 SCT 2.0 - HW XR10 PRO ESC & HW Bandit 10.5t
EXOTEK 22T 2.0 - HW XR10 PRO ESC & HW G2 7.5T
DriveItLikeYSIT is offline   Reply With Quote
Old 10-23-2014, 01:15 PM   #11975
JatoTheRipper's Avatar
Originally Posted by Bosscat View Post
Angelo
Great idea!
Also great ideas. A smartphone app for Android is a must.
Smaller ESC's with more powerful braking too.
Leaf Spring Mafia - Member #1
https://www.shapeways.com/shops/leafspringmafia
https://www.facebook.com/LeafSpringMafia
https://www.instagram.com/LeafSpringMafia
JatoTheRipper is online now   Reply With Quote
Old 10-23-2014, 02:21 PM   #11976
JayL's Avatar
Use a plug for the receiver wire.
I'm fine using the box instead of taking a chance frying my phone, the box is tiny and cheap.
I do like the sensor check idea, maybe have the program box show that
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 10-24-2014, 04:03 AM   #11977
G-rem's Avatar
I run a HW V3.1 esc with a HW V10 5.5t motor and I can tell you brakes are super strong! I don't put BR SW point 1 and 2 to the maximal value (20) because tyres will slip on asphalt if I do...so the HW pair (esc/motor) are very efficient considering brakes...maybe woth other motor they are not as strong, I don't know.
And the HW V3.1 WP does exist!
G-rem is offline   Reply With Quote
Old 10-24-2014, 05:38 AM   #11978
Fry your phone? I'd guess there's probably less than 1% chance that would happen. Tekin is already doing this.
Old 10-24-2014, 07:16 AM   #11979
tbrymer's Avatar
Pretty much zero chance that would happen.
tbrymer is online now   Reply With Quote
Old 10-24-2014, 07:26 AM   #11980
Mikkel_R's Avatar
Hello friends
The only thing I would like from the new ESC is brakes the same or stronger than that given with the LRP Flow ESC.
Mike
Mikkel_R is offline   Reply With Quote
Old 10-24-2014, 07:57 AM   #11981
Bar
Which is why I said for spec racing, I wasn't aware of a 5.5t spec class :P. The problem with the current waterproof ESC is that the sensor wire goes inside the ESC itself, so you can't change it, which is not a million pound idea.
+1 Mikkel_R
Luke Burr
Old 10-24-2014, 09:23 AM   #11982
JayL's Avatar
I've seen many phones fry with bent usb or break the charge connector, and who knows what will happen when your esc is fried and you plug it in and this would only work with android unless they use an in between wifi/bluetooth box like speedpassion, in which case the prgram box would be cheaper but whatever, as long as they keep the cheap program box i'm good
Old 10-24-2014, 10:09 AM   #11983
Jorge T's Avatar
Hello friends
implement full data logging of rpm, volts and temp per run, instead of only a snapshot of max temp, max rpm and min. volts.
540 Tuning
RSD
Jorge T is offline   Reply With Quote
Old 10-24-2014, 01:22 PM   #11984
macdude's Avatar
Mike
17.5 blinky brakes are strong. You just need to adjust the default to get the "feel" that you like. Reverse force affects how strong the brakes feel. Not just the brake percentage needs to adjusted for maximum force.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 10-24-2014, 01:41 PM   #11985
AlanHall's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
i actually had my last laptop "pop" as soon as i turned on the esc once.. its was a SP reventon pro
Alan Hall
AlanHall is offline   Reply With Quote
