Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 10-11-2014, 05:39 PM   #11956
Trader Rating: 27 (100%+)
Originally Posted by Fred_turbo View Post
I want to konw which motor collocation the Hobbywing ESC?
Do you mean what motors I'm using?
I have a Speedzone 5.0, Team Powers 17.5, and Trinity D3.5 17.5
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 10-12-2014, 06:24 AM   #11957
PizzaDude's Avatar
Slightly off topic
Can anyone advise the bearing size for the HW 21.5 motor?
PizzaDude is offline   Reply With Quote
Old 10-15-2014, 08:34 AM   #11958
ali_g's Avatar
hi guys,
Can the extreme stock 60amp esc be updated with the latest blinky software?
Hope you can advise
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 10-16-2014, 12:09 AM   #11959
RoyB's Avatar
Trader Rating: 16 (100%+)
Was checking the ROAR approved motor list tonight. Found the modified V10 3.5t,4.5t,5.5t,6.5,7.5 and 8.5t motors listed. Cannot find the higher turn motors listed. Are they not ROAR legal?
RoyB is online now   Reply With Quote
Old 10-16-2014, 01:12 AM   #11960
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Yes, but the approvals are in the ROAR forum(s):
10.5: http://roarracing.org/4rmb/showthrea...ck-30401020046
13.5: http://roarracing.org/4rmb/showthrea...ck-30401020047
17.5: http://roarracing.org/4rmb/showthrea...ck-30401020048
21.5: http://roarracing.org/4rmb/showthrea...ck-30401020049
etc, etc.
Phil.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 10-20-2014, 10:43 AM   #11961
millbank's Avatar
Hi guys,
Having issues running hobbywing v3.43 on my new laptop. no matter how i open it it brings up the same message.
Device cannot be opened
run as admin or normal
any help would be appreciated
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 10-20-2014, 10:44 AM   #11962
millbank's Avatar
Hi guys,
Old 10-21-2014, 05:09 AM   #11963
kgombe's Avatar
hi guys, any suggestions on a FDR for 10.5 boosted
thx
Kijana Crichton
kgombe is offline   Reply With Quote
Old 10-21-2014, 05:17 AM   #11964
Hey Guys
I am running a 3.1 1s speedo on my 12th pan car running blinky software and am finding I have a small delay when starting a race, not so noticable in a stagger start qualifier but last sunday in the final I was nearly taken out by the guy who started behind me on the grid. It ok when running well at least i am not consious of a delay then.
Any ideas.
Bosscat is offline   Reply With Quote
Old 10-21-2014, 05:44 AM   #11965
macdude's Avatar
Originally Posted by millbank View Post
Hi guys,
I am assuming you are using windows 8.1? If not a little more info about the computer might be helpful. If running as admin does not work try running it in compatibility mode.
right click on program - > select Properties -> Compatibility Tab -> select check box "Run this program in compatibility mode for:" then in the drop down box select windows xp. Click Ok to apply these settings. See if this works.
If not try uninstalling and reinstalling. Could be a driver issue.
Also if you are connecting to the ESC don't forget you need to have the device plugged into a battery and switch on.
Also was the previous version of the software working?
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 10-21-2014, 05:54 AM   #11966
macdude's Avatar
Originally Posted by Bosscat View Post
Hey Guys
Any ideas.
Delay usually indicates controller is running in sensorless mode. So check your sensor wire. If this is not the problem then try re-calibrating the ESC to the radio. Could also change your deadband to the lowest setting although if you are just hesitating at start then it probably a sensor issue. If the cable doesn't help then check the sensor board on the motor. I have had both go bad before and you get the delayed start feeling.
Old 10-22-2014, 01:01 AM   #11967
So is replacement the only way to test a sensor board? Have treid recalibration and a new cable. Could it be armature spacing??
Old 10-22-2014, 03:27 AM   #11968
Pro10noob's Avatar
If you haven't opened the motor for maintenance it should be fine.
If you did and the shims ar in the wrong place it could happen that sensor signal is weak and therefore the problems.
Most of the time it is a sensor cable or port on motor or esc if the motor hasn't been openend.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-22-2014, 05:49 AM   #11969
Hi Guys,
I have Xerun 60A v2 esc and Speedpassion LCD Professional Program Card.
Would like to load software for Blinky, what version should I download? I see a lot (e.g. v1.62, v1.63, v1.64, etc)
Many thanks.
Joel
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 10-23-2014, 02:13 AM   #11970
COBRARACING's Avatar
Originally Posted by rccartips View Post
Hi Guys,
Many thanks.
Joel
Download the latest v3.43 that will have the software blinky mode that you need but if you esc has sp software on it and so does the lcd you will not be able to do it .You will need to send me an email at ae@hobbywing.com so i can send you some different files so it can work.
COBRARACING is offline   Reply With Quote
