Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 08-20-2014, 05:24 PM   #11866
DriveItLikeYSIT's Avatar
Trader Rating: 92 (100%+)
Originally Posted by COBRARACING View Post
no issue at all
what's the link to update stock spec 3.1 ESCs?
TEAM DRIVER==> BocaBearings|Pro-Line Racing|HWNA|Gens ACE|
EBSL - HW XR8 SCT PRO ESC & HW G2 4300kv motor
EXOTEK 22 SCT 2.0 - HW XR10 PRO ESC & HW Bandit 10.5t
EXOTEK 22T 2.0 - HW XR10 PRO ESC & HW G2 7.5T
DriveItLikeYSIT is offline   Reply With Quote
Old 08-20-2014, 05:29 PM   #11867
COBRARACING's Avatar
You can download the software from this link.
Scroll down the page and in blue you will see the link .
Always run in admin mode when using the software.
http://www.hobbywing.com/product_show.asp?id=218
COBRARACING is offline   Reply With Quote
Old 08-22-2014, 12:06 AM   #11868
IgorR's Avatar
Hello,
I'm a newbie with hobbywing ESC.
I own a Xerun 3.1 1S ESC.
I installed the USB link 3.43 software (14702) on my computer database version: 140627
No problem to connect the ESC on my computer.
When I check the firmware list I have only 3 firmwares available and all with a beta name
(3.2.xxxx, 3.1.xxx, 1.xxx).
I'm just wondering if it's normal?
Wicth one should I run for 1/12?
Yokomo YR-X12
Shepherd Velox EC
IgorR is offline   Reply With Quote
Old 08-22-2014, 07:29 AM   #11869
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
The 3.2 is the one to use.
Old 08-22-2014, 12:33 PM   #11870
Hi,
I have got a waterproof V3.1 and the data logging does not work correctly.
The motor temp displays 255, min voltage 11.7 and the max rpm shows 00000 all the time
I have updated the software to V3.2 (with no problems) and it still displays the same values.....any ideas?
Also is there a setting to bypass the switch setting i.e. switch always on, as i think the switch is faulty.
adyb is offline   Reply With Quote
Old 08-22-2014, 12:58 PM   #11871
JayL's Avatar
not all brands of motors work with the temp correctly or have a temp sensor at all
if you have voltage cutoff and esc and motor temp thermal setting turned off, I have found the datalog doesn't work correctly
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 08-22-2014, 04:02 PM   #11872
The motor is a Hobbywing V10 the only setting I have turned off is motor temp.
Thanks.
Old 08-22-2014, 04:45 PM   #11873
JayL's Avatar
ok, so datalog works like this:
you run the car, you turn it off
BEFORE YOU EVER TURN CAR ESC ON AGAIN,
you plug esc into program card and computer, you start Hw app on computer, you plug in battery then you turn esc on and check datalog page on computer.
IF you turn the esc on AFTER you run it and BEFORE you do the process above the log clears.
Old 08-23-2014, 02:02 AM   #11874
Thanks.
hold the reverse on your radio after your run for 6 secs it will save the data and then turn off .Then turn it back on with the lcd programmer plugged in and ill will show you the correct log
Old 08-23-2014, 07:21 AM   #11875
JayL thanks for the help
Cobraracing thank you for the tip!! Did you any suggestions on how to bypass the waterproof switch via software as it's faulty?
Old 08-23-2014, 07:40 AM   #11876
I recommend you Replace the switch or you might damage the bec .
Old 08-24-2014, 02:22 PM   #11877
Frank Hodits's Avatar
XERUN 150 w/4274 1800. Seems like the midrange was a little weak. I was running punch at level 4 and bumped it up to level 6 and it seemed better. What punch level are you guys using with this setup in 8ight-e geared 16/48? Should I try level 7 or 17/48?
https://www.facebook.com/midwestrc/
Frank Hodits is offline   Reply With Quote
Old 08-24-2014, 02:26 PM   #11878
please send me your complete setup At [email protected] and ill work out a setup for you
Old 08-25-2014, 03:50 AM   #11879
IgorR's Avatar
Yokomo YR-X12
Shepherd Velox EC
Old 08-25-2014, 11:38 AM   #11880
mikee123's Avatar
Well just tried updating my HW v3.1 (not stock spec) and guess what?
I now have a speedo that does not work.
BRAKES! WHO NEEDS BRAKES? I DO.
mikee123 is offline   Reply With Quote
