Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 07-24-2014, 11:41 PM   #11791
Airflow's Avatar
Hi, having some problems with my setup.
ESC HB Xtreme Stock (Boosted setup)
Motor Ballistic 13.5 (retarded the timing to less than factory motor settings)
Kit is FF03pro
Lipo is Nanotech 5300mah 60c (almost new)
Problem: After some time, system loses boost but after I restart it, it comes back
again. It will happen the first run. Sometimes after 10 mins. Sometimes it doesnt.
In whole 45 minutes of running, it will happen twice or once.
I swapped out the sensor wires, cleaned all electrical connections, turned off the
overheat protection but still it happens. I also checked the hall sensors and its
working. I also have the same combination in my truck but it's 10.5 set up and
there's no issues with that.
When it happens, it feels like I'm running sensorless mode. BTW, the green light
blinks when I loose boost.
The motor is like 2 years old but maintained in a regular basis.
Anyone had the same experience?
Shall I get a new motor?
Change the timing board?
Get new rotor?
Airflow is offline   Reply With Quote
Old 07-24-2014, 11:51 PM   #11792
COBRARACING's Avatar
Kit is FF03pro
Get new rotor?
please send me an email at ae@hobbywing.com and i will sort out your issue
COBRARACING is offline   Reply With Quote
Old 07-25-2014, 12:09 AM   #11793
Airflow's Avatar
email sent. Thanks
Old 07-25-2014, 12:45 AM   #11794
daleburr's Avatar
Kit is FF03pro
Get new rotor?
What firmware and boost settings? I've had this before on the 211/119 firmware. Upgrading to the 930 firmware solved the issue.
It can also be caused by adding too much boost too soon. So look at increasing your start RPM to at least 6000 and run a boost ramp of at least 300.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 07-25-2014, 01:11 AM   #11795
Airflow's Avatar
I will try this later, thanks bro...
Old 08-01-2014, 03:37 AM   #11796
mes
Originally Posted by COBRARACING View Post
New V3.1 Zero Spec coming soon .This esc will be the replacement of the juststock but will feature more settings in the software.I think it will be the best Zero timing esc on the market.
sorry guys i cannot say anymore at this present time but it will be worth the wait that i guarantee you .
Any news on this one? I haven't had a HW ESC since the HW-based SP GT 2.0 series, but seeing how satisfied one of our club members is with the Justock I talked him into buying, I'd me more than willing to try a (hopefully) cheaper version of the V3.1 series. Compared to the Justock, a higher amp rating for handling faster motors would be nice.
mes is offline   Reply With Quote
Old 08-01-2014, 03:39 AM   #11797
its in production.
Old 08-01-2014, 10:21 AM   #11798
mes
Good to hear!
Any details on specifications and pricing yet?
Old 08-01-2014, 02:46 PM   #11799
Default V3.1 Blinky 17.5 setup
I have posted the below in another section but am looking at what settings can be changed in the blinky setup of the V3.1 stock spec speedo to give a better performance.
Hi
After a little advice I have a 17.5 and run it in my T4-14 I mainly run at Stafford and will be at the next Bedworth meeting. I run it at 2.9 and the motor come off quite hot temp could not say as do not have a temp gun.
The advice that I am looking for is a good gearing and what adjustment I need to do on the end bell trimming
I run it with a V3.1 stock speck speedo in blindly and again not altered any settings in the speedo. Is there also a site to get or see other racers set ups
Andrew
andrewd is offline   Reply With Quote
Old 08-05-2014, 09:26 PM   #11800
Originally Posted by Vincent_Diesel View Post
The other night I attempted to update the firmware with the latest USB software.
Successful firmware update on my new Multifunction LCD Program box. As for my Hobbywing Stock V3.1 ESC, the update failed -- received a communication error. Once that happened my ESC will no longer work. Seems to power up fine but no power to the motor and no longer make a connection to the LCD Program box -- also will not calibrate to my radio. It simply won't work now.
I have two of these and I fear it may happen again when updating the firmware in the future. Anyone know what to do if this happens again?
The same exact thing just happened to me. Help? And what caused it?
Crashaholic is offline   Reply With Quote
Old 08-06-2014, 09:51 AM   #11801
DBM
its in production.
I am also very interested in this esc. Any word on when it will be shipping to vendors?
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 08-06-2014, 05:55 PM   #11802
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Yep, same thing just happened to me...
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS / EA MOTORSPORTS
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 08-06-2014, 05:58 PM   #11803
Please update this thread when you find a resolution. I will do the same. I think something might be wrong with the latest build of USB Link or the ESC firmware.
Old 08-06-2014, 06:26 PM   #11804
kgombe's Avatar
note to self - do not update software
Kijana Crichton
kgombe is offline   Reply With Quote
Old 08-06-2014, 06:31 PM   #11805
Trader Rating: 27 (100%+)
I updated mine just fine. I first installed the newest v3.43 USB Link software and then just went through and updated the firmware. Did two v3.1s, one in blinky and one in mod and both turned out perfectly.
The mod software is noticeably smoother! I felt like I had supreme control over my car's speed in tight corners. However, I did notice my ESC running about 10 degrees hotter than normal. With the previous firmware, it woudl come off the track at around 135-140, but yesterday I saw 149f a couple of times. Is this to be expected?
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
