Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 03-25-2014, 03:06 PM   #11686
jasons56's Avatar
Originally Posted by COBRARACING View Post
The Hobbywing Xerun-120A V3.1 Stock Spec has met the electrical requirements for ROAR non-timing operation with software version V3.1_121129_Beta.
What about the 1s version? Unless I missed it, didn't see it on the ROAR list yet?
I don't mean to be too much of a pest, just don't want it to come up at a big ROAR race again!
http://www.youtube.com/user/ZenRacing
jasons56 is offline   Reply With Quote
Old 03-25-2014, 05:23 PM   #11687
TryHard's Avatar
Originally Posted by hyujmn View Post
If I set up my v2.1 with mod software and set it to 0 timing, it blinks too. I used to run a 120a in blinky with the latest mod software.
Are you sure it's not blinking for some other reason? A 120a with mod software wouldn't be blinky legal, as the mod software isn't on the ROAR list. 508 is the only legal blinky software for the 120A v2.1
Old 03-27-2014, 03:57 AM   #11688
B4james's Avatar
Is anyone able to help with a V3 base setting for 21.5 Boosted TC using a Trinity Kill shot motor. It's a small indoor asphalt track with lap times around 14-15 seconds
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 03-27-2014, 11:38 AM   #11689
Originally Posted by VA_Racer View Post
ok thanks for the help I figured it out. Now another ? is do I have to tell it i'm running a 1s batt or is it automatic and which version is blinky ? I see stock allows timing.
The very first time you hook it up all you need is a battery (one or two cell), the box, usb cable and the pc running the software. If you are going to install the 508 software, do that first. When that is complete, if you are going to run 1 cell, turn off the voltage cutoff protection and update the esc. Once that step is complete you may disconnect the pc and fully program the esc using the box. If you don't turn off the voltage protection you will get a low voltage flash from the esc when on a 1 cell and the car won't run. You will then need to hook up a 2 cell to reprogram the esc.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 03-27-2014, 11:41 AM   #11690
Interestingly, I have seen the 1 cell V3.1 blink when not in profile 2 (The ROAR spec for blinky). It happens when you turn all of the boost and timing settings down to zero!
Anyone else?
NORCAR @ The Gate
Old 03-27-2014, 11:57 AM   #11691
Send a message via ICQ to MattW
Anyone else?
Yes, I believe that's how it's supposed to work.
MattW is offline   Reply With Quote
Old 03-27-2014, 12:05 PM   #11692
Trader Rating: 27 (100%+)
Even though the 508 is the only ROAR approved blinky software, that doesn't mean its the ONLY way to use blinky mode on the ESC.
And yes I'm 100% sure. I've owned a v2.1 60a, 90a, and 120a, as well as a v3.1 stock spec and v3.1 120a. Every single one of them, regardless of which firmware, will always blink if boost/turbo is set to 0.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 03-27-2014, 07:47 PM   #11693
TryHard's Avatar
Sorry, but thats not correct. The V2.1 should not blink when you set the boost/turbo to zero. I have used the same speedies as well, and never got the V2.1 to do that. The main reason is that the 2.1 has a little timing built into the Mod and Stock software that can't be removed, unless you use the 508 blinky firmware, and also why settings don't directly translate over (the V3 felt a little soft with V2.1 settings on it).
Anyone else?
The V3 and V3.1 are designed to blink when turbo/boost are set to zero, and as far as I'm aware, are the only ones that will. They blink because they are set with zero boost/turbo, not because it is in profile 2.
Regards
Ed
Old 03-27-2014, 07:57 PM   #11694
Regards
Ed
I'll test my ESCs again tonight to see.
Old 03-28-2014, 03:55 AM   #11695
But if you go to tech and they check your esc, you better be in "Profile 2". This is a concern with some organizations right now.
NORCAR @ The Gate
Old 03-28-2014, 04:17 AM   #11696
TryHard's Avatar
I get your point... but the esc won't blink if there is some boost/turbo programmed in, even if it is set in "profile 2". It will only blink if both are at zero. I do agree that best just to set it to "profile 2" for ease though... saves having to remember what settings you use in other modes
Ed
Old 03-28-2014, 08:48 AM   #11697
idbdoug's Avatar
Trader Rating: 33 (100%+)
can you run max turbo with no boost or do you have to run some boost for turbo to function?
This is for both the 100amp and 120amp V3.1 HW speedos
idbdoug
www.serpentamerica.com
www.r1wurks.com
www.falconsekido.com
idbdoug is offline   Reply With Quote
Old 03-28-2014, 11:12 AM   #11698
idbdoug
You can run turbo without boost. They're separate. Boost applies to low end and turbo only activates once apply full throttle, usually.
Old 03-28-2014, 11:30 AM   #11699
idbdoug's Avatar
idbdoug
www.r1wurks.com
Old 03-28-2014, 07:05 PM   #11700
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Uh, oh. I'm wondering why Doug needs to know about boost and turbo!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
