Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 03-23-2014, 05:25 AM   #11671
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by TryHard View Post
Try setting the ESC brake level to 100%, and also make sure when you calibrate the brakes that the EPA is at 100%. Then put the reverse speed to 100%. Sounds weird, but this can have an effect on the brake level of some speedo's.
HiH
Ed
gotcha Ed - I was wondering if that would have worked, but was having to do a completely new setup on my car at the track and didn't want to try. I think the original tekin software related brake force to reverse power - so if you reverse at a lower rate, you brakes were almost non-existent. kinda like the reverse setting (when not used), is like the speedo's brake range. set it at 25% (default, I believe), would only give you a 1/4 of the brake range
I'll give it a shot - I'm assuming once you do that, then the brake level is more effective??
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-23-2014, 08:22 AM   #11672
ATLASCOPCO's Avatar
Originally Posted by ATLASCOPCO View Post
V10 hobbywing 13.5 motors
Any thoughts anyone
Is there a version one and two?
Thanks in advance
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
ATLASCOPCO is offline   Reply With Quote
Old 03-23-2014, 08:25 AM   #11673
Pro10noob's Avatar
From what i have heard and seen is only the holder that keeps the timing insert in it's place, changed from plastic to alloy.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 03-25-2014, 02:59 AM   #11674
Trader Rating: 21 (100%+)
I have the new version of the program box and the 120a 1s version 2.1 . Do I have to have the esc wired to program the esc it wont connect to the program box at all. What am I doing wrong?
VA_Racer is offline   Reply With Quote
Old 03-25-2014, 03:03 AM   #11675
Pro10noob's Avatar
You have to use a 2s lipo to get the 1s esc to work and yes you need to connect the esc/reciever cord to the box.
Then turn on the esc and it connects to the box if all is ok.
Read the manual of both devices.
Regards Roy
l===/o\===l
Old 03-25-2014, 03:13 AM   #11676
Regards Roy
it was kind of unclear the way I read it. do the motor wires need to be connected also?
Old 03-25-2014, 03:16 AM   #11677
Pro10noob's Avatar
I always do as i program it when it is in the car
Regards Roy
l===/o\===l
Old 03-25-2014, 03:36 AM   #11678
ok thanks for the help I figured it out. Now another ? is do I have to tell it i'm running a 1s batt or is it automatic and which version is blinky ? I see stock allows timing.
Old 03-25-2014, 04:08 AM   #11679
Originally Posted by maRRRco View Post
Hi guys, I have a xerun 2.1.
Are there any controindications to run with 3s lipo and 5600 Kv motor ?
Everyone use 2s, so I have no informations with a possible use at 3s, but I think this should imply lower ampere so better efficient and low temp.
Any opinions ?
maRRRco is offline   Reply With Quote
Old 03-25-2014, 05:28 AM   #11680
TryHard's Avatar
You'll need to load the '508_no timing' software onto the 120a 1s to have to running in an approved blinky mode.
HiH
Ed
Old 03-25-2014, 08:52 AM   #11681
Trader Rating: 27 (100%+)
No matter what software you have on there, if you set boost/turbo to 0, the ESC will blink like in blinky mode.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 03-25-2014, 12:37 PM   #11682
Send a message via ICQ to MattW
I'm pretty sure that is only true for the V3/3.1. I'm fairly sure that Ed's advice is accurate for the V2.1.
MattW is offline   Reply With Quote
Old 03-25-2014, 12:56 PM   #11683
If I set up my v2.1 with mod software and set it to 0 timing, it blinks too. I used to run a 120a in blinky with the latest mod software.
Old 03-25-2014, 02:50 PM   #11684
jasons56's Avatar
What is the status on Roar blinky approval for 3.1 1s version?
Thanks!
http://www.youtube.com/user/ZenRacing
jasons56 is offline   Reply With Quote
Old 03-25-2014, 03:00 PM   #11685
COBRARACING's Avatar
The Hobbywing Xerun-120A V3.1 Stock Spec has met the electrical requirements for ROAR non-timing operation with software version V3.1_121129_Beta.
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
