Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 03-18-2014, 05:05 AM   #11656
Pro10noob's Avatar
When you have the default timing insert in the motor, i believe the motor timing is 37.5 degrees(correct me if i am wrong)
This with the timing on the esc when using stock maps can be with the wrong FDR be to much and smoke the LRP motor.
What track are you running with what car??
Spur? pinion?
Regards Roy
Originally Posted by rsterren View Post
ah ok, I have the 27 (default) timing thingy on the motor..
17.5 turns
That has to be added to the esc timing then? to calculate total timing?
and then it might get to much... I get it..
thnx!
R.
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 03-18-2014, 05:18 AM   #11657
Any word on the ROAR approval of the V3.1 1-cell model?
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 03-18-2014, 11:34 AM   #11658
Spur? pinion?
Regards Roy
yes could be 37.5, i'm running a fdr of 5.8 in a ta06, before the set was in a tt01 m-chassis conversion running about the same fdr.
so thats not to much i guess..
last time i had to change sensor wire after the sensors got lost (esc blinking green/red).
The motor and the esc dont feel hot btw, can easely touch them..
rsterren is offline   Reply With Quote
Old 03-19-2014, 01:59 AM   #11659
Johnny-RC's Avatar
Trader Rating: 24 (100%+)
A few pages back Angelo stated this....
Originally Posted by COBRARACING View Post
V3.1 1s now roar approved ciming next is the stock spec for approval.
Products I run
| Hobbywing | Gens Ace | Highest Servos | Sanwa | Team Associated | AKA |
http://www.modestorc.com
Johnny-RC is offline   Reply With Quote
Old 03-19-2014, 01:14 PM   #11660
mutley001's Avatar
Default Esc timing vs motor timing vs gearing
Ok this may be a silly question and may have been answered already but how is it best to set up the esc,motor and gearing for booted TC?
High esc timing, low motor timing, high fdr?
Low esc timing, high motor timing, low fdr?
Middle of the road on all 3?
Is it track/motor dependant?
Any help/advice would be great
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 03-19-2014, 06:50 PM   #11661
Three possible causes .
1.The esc sensor circuit has failed
2.The Motor sensor board has failed (possible damaged hall sensor)
3.1 of the phases is faulty ( not possible in your instance as you said it works off the ground)
Look at trying a new motor first .
Thanks for the feed back.
I changed the motor with one of the same make but it was the same. I lowered the timing and it seemed to work with the car on the ground. I'll test it out on the track. Is it possible that the V3.1- 1 cell it just will not work with all motors?
Friulimotosport is offline   Reply With Quote
Old 03-20-2014, 03:09 AM   #11662
daleburr's Avatar
Paul
A lot of it depends on the motor. All motors have a point at which adding more timing (ESC or Endbell) just creates more heat and no extra power. But it varies from motor to motor so you'll need a dyno to figure out exactly what the maximum settings should be. Even then it may not be possible to run those settings as it may still overheat.
Gearing is track, grip and motor dependent. If you've got wheelspin off the corners gear up. If it feels sluggish gear down. On a small/tight track you'll need a smaller gearing to keep the motor RPMs up in the peak power band. On a big track you'll need a bigger gearing, again to keep the motor in its peak power band.
The easiest option is to find someone fast (with the same motor/esc as you) and steal their settings.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 03-20-2014, 05:39 AM   #11663
Default nice 1
wow it amazing! 9club
3p3p is offline   Reply With Quote
Old 03-20-2014, 11:13 AM   #11664
mutley001's Avatar
Thanks - stealing setting is fine but I'm a bit sad in that I like to understand the details of what's happening when setting up speedo,motor and gearing to get the best. The info you've provided is great.
Next question then is what order should you begin the setup process of these 3 things?
Start by getting the gearing right then fine tune the speedo and motor timing? Or get the timing right and play with the gearing?
ARC R11 2017
ARC R10 2013
Team EAM
Old 03-20-2014, 01:41 PM   #11665
Hi guys, I have a xerun 2.1.
Are there any controindications to run with 3s lipo and 5600 Kv motor ?
Everyone use 2s, so I have no informations with a possible use at 3s, but I think this should imply lower ampere so better efficient and low temp.
Any opinions ?
maRRRco is offline   Reply With Quote
Old 03-22-2014, 08:40 AM   #11666
Paul
As Dale has said motor timing is dependant on the motor itself (having found the sweet spot i always left it alone).
Esc timing is track dependant.
Gearing for boosted 13.5 i always ran a FDR of about 7.00.
At a new track i would adjust in this order
Boost and turbo
Gearing (if after altering boost and turbo it still seemed slow)
markrobinson is offline   Reply With Quote
Old 03-22-2014, 01:27 PM   #11667
ATLASCOPCO's Avatar
V10 hobbywing 13.5 motors
Any thoughts anyone
Is there a version one and two?
Thanks in advance
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
ATLASCOPCO is offline   Reply With Quote
Old 03-22-2014, 03:53 PM   #11668
mutley001's Avatar
Boost and turbo
Thanks, I'll have a play
ARC R11 2017
ARC R10 2013
Team EAM
Old 03-23-2014, 12:30 AM   #11669
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
ok guys. I've been following this thread for a little while and this Saturday was the first day I got to run my Justock in an actual event. Its running the latest '508_notiming' firmware (at least according to the program, there is no other version out there) - and I have the LCD box and the software..Running USVTA rules with the novak ballistic 25.5 motor
so here's my issue - how the heck do you get more brakes out of it?? I'm running the brake force set of 87.5% (radio EPA is set at 140%) and it still feels like it just slows the car down, not stops it. If I had to jam on the brakes to avoid driving thru another driver, I'm up the creek - there's nothing there to stop.
I tried setting the brake EPA at 100%, then increasing it on the radio - nothing
Messed with expodential, positive AND negative - nothing
changed drag brake in the software - nothing
so what's the trick?? I'm used to speedos where you need to set it with less brakes because the 'standard' setups are too strong. I've run several other brands before switching, so I'm fairly certain its not something I have wrong in the settings.
help?!?!?!?!?
on a plus side - this has got to be the SMOOTHEST speedo I've ever run. Can't wait to throw my 1s in my 12th scale
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-23-2014, 04:10 AM   #11670
TryHard's Avatar
help?!?!?!?!?
Try setting the ESC brake level to 100%, and also make sure when you calibrate the brakes that the EPA is at 100%. Then put the reverse speed to 100%. Sounds weird, but this can have an effect on the brake level of some speedo's.
HiH
Ed
