Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 03-09-2014, 05:08 PM   #11641
Johnny-RC's Avatar
Trader Rating: 24 (100%+)
Originally Posted by COBRARACING View Post
V3.1 1s now roar approved ciming next is the stock spec for approval.
Nice! Thanks for the update. Looking forward to the Xerun 3.1 Stock Spec passing. Keep us posted Angelo
Products I run
| Hobbywing | Gens Ace | Highest Servos | Sanwa | Team Associated | AKA |
Johnny-RC is offline   Reply With Quote
Old 03-11-2014, 01:54 PM   #11642
ATLASCOPCO's Avatar
Default V3.1 fan
Hi I need to purchase a new speedo fan
It must be a genuine hobbywing one
Can anyone advise me where I can get a new one from
Many thanks
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
ATLASCOPCO is offline   Reply With Quote
Old 03-11-2014, 02:05 PM   #11643
Pro10noob's Avatar
Try them--------> http://shop.cpdracing.co.uk/
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 03-12-2014, 02:25 AM   #11644
ATLASCOPCO's Avatar
Regards Roy
😔they don't do them
Even on the hobbywing web site dosent show them
Thanks anyway😃
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
Old 03-12-2014, 03:32 AM   #11645
Pro10noob's Avatar
Here you go---> http://www.the-border.com/Hobbywing-Accessory/
They have them on stock.
Regards Roy
Originally Posted by ATLASCOPCO View Post
��they don't do them
Thanks anyway��
l===/o\===l
Old 03-12-2014, 05:13 AM   #11646
Send a message via ICQ to MattW
Thanks anyway��
Schumacher's website lists 2-3 different Hobbywing ESC fans, although I'm not sure which one is the same as the one that's supplied.
MattW is offline   Reply With Quote
Old 03-15-2014, 04:48 PM   #11647
ATLASCOPCO's Avatar
Regards Roy
Thank you Roy 👍
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
Old 03-15-2014, 04:50 PM   #11648
ATLASCOPCO's Avatar
Cheers Matt
I'll check it out
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
Old 03-16-2014, 12:43 AM   #11649
Hi Guys,
i'm back...
A couple of weeks ago i posted that my esc broke down, or something.
it was fixed with another sensor wire.
yesterday i put the 930STOCK firware in again.
when i ran the car for a few minutes i noticed the 'electric smell' again!
a quickly put the 930MOD firmware in it. and the smell was gone.
can to much timing kill a sensor wire?
regards,
Rob
rsterren is offline   Reply With Quote
Old 03-17-2014, 02:00 PM   #11650
Looking for help with V3.1 1cell.
Is there away to test the sensor input as my speedo would not spin the motor when on the ground but would off the ground. Unpluged the sensor wire and it worked again but then went back to what it was doing before. I even changed out the wire but it did the same as before?
Friulimotosport is offline   Reply With Quote
Old 03-17-2014, 02:37 PM   #11651
COBRARACING's Avatar
Three possible causes .
1.The esc sensor circuit has failed
2.The Motor sensor board has failed (possible damaged hall sensor)
3.1 of the phases is faulty ( not possible in your instance as you said it works off the ground)
Look at trying a new motor first .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 03-17-2014, 02:41 PM   #11652
[QUOTE=rsterren;13100431]Hi Guys,
i'm back...
regards,
Rob[/QUOTE
thats not an eletrical smell from your sensor wire but heat from your esc or motor.
the mod software has less timing as mod motors dont need so much timing as they are powerful enough.
dint run stock 930;on mod motors.]
Old 03-17-2014, 11:43 PM   #11653
Ok, but i thought the LRP X20 is a stock motor...
Old 03-18-2014, 12:04 AM   #11654
Pro10noob's Avatar
It can be if your running the 10.5, 13.5, 17.5 and 21.5 motors.
All other are mod
One thing tho, the LRP X12 and X20 motors are running very hot and therefore can smell a lot.
Even with just a little timing they can run up to 100 degrees celcius.
I have smoked LRP motors in combo with the HW ESC more then once.
With same settings and other brand motors, no problems.
The is due to the mechanical timing that is build in the motor.
Use the insert on the motor that gives the lowest timing settings.
It is not a problem of the ESC but the motor timing settings.
Regards Roy
l===/o\===l
Old 03-18-2014, 01:46 AM   #11655
ah ok, I have the 27 (default) timing thingy on the motor..
17.5 turns
That has to be added to the esc timing then? to calculate total timing?
and then it might get to much... I get it..
thnx!
R.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
