Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 03-06-2014, 12:06 PM   #11626
AlanHall's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
Originally Posted by sunktothenutz View Post
Hi,
I have the new hobbywing quicrun sensored esc........when I rev the motor,it has a step in the power,ie its not linear....this happens at both the lowest punch setting and the max punch setting..also no timing...any ideas?.....the motor is a 17.5T speed passion...
Do you have a different sensor cable to try
Alan Hall
AlanHall is offline   Reply With Quote
Old 03-06-2014, 01:28 PM   #11627
Hi,
Yes have tried a new sensor lead....
sunktothenutz is offline   Reply With Quote
Old 03-06-2014, 01:41 PM   #11628
AlanHall's Avatar
Hi,
i had exactly what you described and swapped leads and it was fine after . is the sensor board possible bad?
Alan Hall
Old 03-07-2014, 07:01 AM   #11629
Trader Rating: 21 (100%+)
Default Need help
I bought a juststock ESC and I've had a few problems since day 1. Found out the speedo is 3 1/2 years old new. Sorry I didn't stick to Tekin.
I resolved most of them, now trying to calabrate the speedo to my 3pk. I turn on the radio, OK there, Hold down the set button and turn on the speedo. Red light flashes then release it, then nothing, stays flashing.
What am I doing wrong??
Thanks.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 03-07-2014, 07:13 AM   #11630
TryHard's Avatar
Thanks.
Have you actually looked how to calibrate the esc correctly? As in read the manual?
You need to set the neutral, then press whilst holding full throttle, and then press again whilst holding full brake. Then the esc will be good to go.
| THard.co.uk | Xray | MuchMore |
Old 03-07-2014, 07:22 AM   #11631
You need to set the neutral, then press whilst holding full brake, and then press again whilst holding full brake. Then the esc will be good to go.
How stupid of me, I didn't know I had to read it. Thank you for your insight.
Old 03-07-2014, 07:36 AM   #11632
Pro10noob's Avatar
Lol.
Also don't forget to set the transmitter in neutrall and throttle epa to 100%
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 03-07-2014, 07:39 AM   #11633
Originally Posted by Pro10noob View Post
Lol.
Regards Roy
done that
Old 03-07-2014, 07:42 AM   #11634
Pro10noob's Avatar
Some transmitters you need to put servo reverse on also for the throttle channel.
From the manual:
Switch off the ESC, turn on the transmitter, set the direction of throttle channel to ”REV”, set the throttle trim to “0”, set the “EPA/ATV” value of throttle channel to “100%”, and disable the ABS function of your transmitter. B) Use a pen or screw driver to hold the “SET” key and then switch on the ESC, and release the “SET” key as soon as possible when the red LED begins to flash.
Regards Roy
l===/o\===l
Old 03-07-2014, 11:34 AM   #11635
Thumbs up
RC paradice and the border online are the same.
They are open after 12 from what i know.
Get in touch with them on FB and ask so you know for sure.
You can test your car with esc on there track.
Regards Roy
Ok, been there.
We tested the car.
First the plug broke of my lipo.. that showed my soldering skills
After fixing that, a short run on the track made the esc go 'sensorless'
So, verdict, esc 'not good'..
Bought a lrp esc so i can at least run this weekend.
BUT, it came with another sensor wire, and i could not resist to try that wire with the HW esc.
Its the 3rd wire i try'd sofar..
And it runs like a bat out off hell!!
Yeeeeh...
So i got me a spare lrp esc, and a combo fit for gold on this weekends rallycup :-)
So lesson learnd, try at least 3 sensor wires before giving up
Thnx guys!
Have a good weekend.
rsterren is offline   Reply With Quote
Old 03-07-2014, 12:31 PM   #11636
From the manual:
Regards Roy
done that too
Old 03-07-2014, 02:19 PM   #11637
Pro10noob's Avatar
@rsterren...Good to hear that the problem is solved.
Have fun with the esc and beat the rest in your race
Regards Roy
l===/o\===l
Old 03-07-2014, 02:24 PM   #11638
Regards Roy
Thnx Roy!
Old 03-09-2014, 12:34 PM   #11639
Well i came in last... of 10.. a 3racing mchassis conversion tt01 is nog build to rally, jump, and roll but the esc worked yust fine!
Old 03-09-2014, 05:03 PM   #11640
COBRARACING's Avatar
V3.1 1s now roar approved ciming next is the stock spec for approval.
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
