Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 03-03-2014, 10:43 PM   #11611
Originally Posted by rsterren View Post
Hi guys,
I have a new xtreme stock esc, with a new lrp x20 17.5t motor.
Setup is 'out of the box' with forward,brake,reverse setting for practice.
After a few minutes running the esc led blinks red/green, and power is reduced.
overheat protection is my guess.
But the esc and motor are not hot, just a bit warm, i can touch them without any problem.
So the cant be 80 degrees celcius...
Is it the combination with the lrp motor that the sensors are wrong?
Can i run with heat protection off, as stated in the manual?
Will that not be very risky?
Regards,
Rob
Edit:
Fdr is 5.72
55 spur 25 pinion.
Car is 3racing m-chassis conversion tt01.
from reading this thread, i get the idea that the esc goes into 'unsensured' mode?
if i turn the esc off, and on again, it runs fine for about 1 lap again.
so it may 'lose' the sensors after a few minutes??
sensor cable is also new.
regards,
Rob
rsterren is offline   Reply With Quote
Old 03-03-2014, 10:55 PM   #11612
Airflow's Avatar
From my experience, it's the thermal protection. I disabled mine and it stopped cutting out.
Airflow is offline   Reply With Quote
Old 03-04-2014, 12:11 AM   #11613
ok i'll try that.
i cant find in the manual if both the esc and motor will have no heat protection when i disable it.
my guess would be that disabling heat protection only disables the motor protection, am i guessing right?
regards,
Rob
Old 03-05-2014, 09:11 AM   #11614
ok i'll try that.
regards,
Rob
it still goes blinking after 1 lap...
its the sensors, it goes into sensonless mode..
so, change motor to hobbywing motor, or change esc to LRP esc i guess....
Old 03-05-2014, 10:21 AM   #11615
Check the setting for the cutoff voltage. As a test turn it off.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 03-05-2014, 11:58 AM   #11616
Trader Rating: 27 (100%+)
My issue was a faulty sensor board on the motor.
I had the exact same issue. Motor would be fine at the start and after 3-4 minutes, the motor would cog and the ESC would blinky yellow/greenish colors.
Once I replaced the sensor board and sensor wire, everything was ok!
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 03-05-2014, 01:33 PM   #11617
3.2 volt per cel, 2s lipo fully charged, so should not cutoff.
Old 03-05-2014, 01:37 PM   #11618
Ok, that would be strange, motor is brand new.
But i take the car to a rc shop tomorrow, they also have an indoortrack, so ill show them whats going on, and hopefully we can troubleshoot the problem.
Il keep you guys posted!
Thnx all.
Rob
Old 03-05-2014, 01:44 PM   #11619
Pro10noob's Avatar
Your going to RC paradice then??
Michel knows a lot and if you have another motor, take it with you and try it.
Then you know for sure if it is the esc or motor.
Regards Roy
PS never had a faulty HW esc since i used them
Thnx all.
Rob
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 03-05-2014, 02:11 PM   #11620
It should not.
NORCAR @ The Gate
Old 03-05-2014, 02:38 PM   #11621
Regards Roy
I got the combo from the-border, that are the rc-paradice guys i think?
Was planning on going to pkracing, thats closer to my hometown...
But if rc paradice are the suppliers, i better go there....
Are they open tomorrow after 12?
Old 03-05-2014, 02:42 PM   #11622
Pro10noob's Avatar
RC paradice and the border online are the same.
They are open after 12 from what i know.
Get in touch with them on FB and ask so you know for sure.
You can test your car with esc on there track.
Regards Roy
l===/o\===l
Old 03-06-2014, 07:57 AM   #11623
Hi Guys,
I have a xerun 120A 1S SD V2.1 running blinky V3 508 no timing in my 12th all running ok. However I also have an older xerun 120A V2 (not sure as I have lost the box when moving house) in my TC running stock. Where I run they are now going to run blinky in all classes. When I try to put it into 508 (blinky) I get the error message V.30 110323 stock can not be updated to the version (V3 508 no timing).
I also get the same message when I try V1 508, any ideas?
Regards Bob.
Dadsrace2 is offline   Reply With Quote
Old 03-06-2014, 08:13 AM   #11624
Turn your boost and timing to 0. The ESC is now in blinky mode, no matter what firmware you've got on it. It'll also blink just like normal.
I just always ran the Stock firmware and turned boost/turbo to 0.
Old 03-06-2014, 11:00 AM   #11625
Hi,
I have the new hobbywing quicrun sensored esc........when I rev the motor,it has a step in the power,ie its not linear....this happens at both the lowest punch setting and the max punch setting..also no timing...any ideas?.....the motor is a 17.5T speed passion...
sunktothenutz is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
