Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 02-24-2014, 04:42 AM   #11596
narcotiks's Avatar
Originally Posted by mattst View Post
Please help, I have got a new V3.1 and run 13.5 T open, I have worked out on the version V2.1 u could control the motor temp using Item 15 acc.
Now with this new version I can work out the acc. Is there a way of working out the acc on this version ?
ACC on the 2.1 was measured in RPM per degree of BOOST
Going from that, you control the ACC on the 3.1 by lengthening or shortening the rev range. For example, START RPM = 4000 , END RPM =16000 and BOOST = 40. The rev range (end rpm - start rpm) is 12000 , and the amount of boost is 40. Since ACC is RPM per degree of BOOST, 12000/40 = 300.
ACC = (END RPM - START RPM) / BOOST
Hope this helps
narcotiks is offline   Reply With Quote
Old 02-26-2014, 12:19 PM   #11597
Cool
Thanks,
That answers why i cooked a motor last race meet. Now I can cool everthing down.
mattst is offline   Reply With Quote
Old 02-27-2014, 12:10 AM   #11598
narcotiks's Avatar
Thanks,
No worries you usually want to run an ACC between 250 and 350 for 13.5t open.
Old 02-27-2014, 01:31 PM   #11599
gsxr0311's Avatar
Trader Rating: 18 (100%+)
Hay what's up guys,
can the 120a c-xerun be upgraded to a boosting esc via a software update?
I have the 2.1 version.
Thanks.
Special Thanks to: RC Target, Ko Propo USA, O'Donnell glow plugs, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is online now   Reply With Quote
Old 02-27-2014, 02:15 PM   #11600
Trader Rating: 27 (100%+)
Yes, the 120a v2.1 can use boost and turbo. Update the firmware to the one that says (Stock)
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 02-28-2014, 12:45 PM   #11601
gsxr0311's Avatar
Would I be able to do this update with the new programing box or do I need to use the old program box to update this esc? Thanks.
Old 02-28-2014, 12:49 PM   #11602
Pro10noob's Avatar
With the new program box you can use the V3.1 and V2.1 without problems from what i know.
You can switch between software.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 02-28-2014, 02:20 PM   #11603
gsxr0311's Avatar
Ok, so far I have been able to use it on both, but someone told me I couldn't do the update on the 2.1 with it. I'll try the update tonight. Thanks.
Old 02-28-2014, 02:52 PM   #11604
poeee's Avatar
Can anyone help me by suggesting some settings to start with in 21.5 Boosted? I have a v2.1 ESC. Motor is a Trackstar 21.5. Currently have FDR at around 6:1.
poeee is offline   Reply With Quote
Old 02-28-2014, 02:55 PM   #11605
Pro10noob's Avatar
No that good with the 21.5 motors but we need more info on track lenght, layout, car you drive.
I pressume it is a TC you want the settings for??
Regards Roy
l===/o\===l
Old 02-28-2014, 03:07 PM   #11606
poeee's Avatar
Regards Roy
Our track has a relatively long straight compared to other tracks, I guess. How long it is, I couldn't tell you.
Yes, it's a TC.
Boosted is all new to me.
Old 02-28-2014, 03:25 PM   #11607
narcotiks's Avatar
DDRRS punch : max
Start rpm : 3000 or 4000
boost : 40
ACC : 300 or 350 (lower number is more aggressive power and more heat)
Turbo : 24
Turbo delay : 0.1
Old 02-28-2014, 03:28 PM   #11608
poeee's Avatar
Originally Posted by narcotiks View Post
DDRRS punch : max
Start rpm : 3000 - 4000
boost : 40
Turbo : 24
Turbo delay : 0.1
Thank you, Sir!
Old 03-01-2014, 10:17 AM   #11609
Trader Rating: 21 (100%+)
Default Help
I uploaded Hobbywing_USB_Link_V3.4_setup_131202.rar (MS Windows Version) onto Multifunction LCD program box, so far so good.
Now when downloading USB Link Software I get asked for the anti-counterfeiting code, I put that in and it tells me the code is correct but no record.
Now what??
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 03-03-2014, 09:52 AM   #11610
Hi guys,
I have a new xtreme stock esc, with a new lrp x20 17.5t motor.
Setup is 'out of the box' with forward,brake,reverse setting for practice.
After a few minutes running the esc led blinks red/green, and power is reduced.
overheat protection is my guess.
But the esc and motor are not hot, just a bit warm, i can touch them without any problem.
So the cant be 80 degrees celcius...
Is it the combination with the lrp motor that the sensors are wrong?
Can i run with heat protection off, as stated in the manual?
Will that not be very risky?
Regards,
Rob
Edit:
Fdr is 5.72
55 spur 25 pinion.
Car is 3racing m-chassis conversion tt01.
rsterren is offline   Reply With Quote
