Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 09-01-2010, 03:40 AM   #1141
irgo's Avatar
Originally Posted by maxg123456 View Post
Well I run on a track simillar size with a 13.5. I cannot stand irregular jumps in torque, it just overheats the tires indoors.
With a new 17.5 GM motor, i'd gear it at around 5.50 to 6.00 with stock timing.
I always do RPM start 3,000-4,000rpm which makes ramp smooth
Timing Punch - try -3 or -4 which is a long ramp for a 17.5 for smooth acceleration)
Turbo - Max
Turbo delay 0.2
DDRS 7
max maximum torque wouldbe greater when using rpm log and rpm start custom.
Maybe cobra had an answear from michael.
Quark Force
irgo is offline   Reply With Quote
Old 09-01-2010, 03:50 AM   #1142
defcone's Avatar
Trader Rating: 15 (100%+)
When is the new software going to be released?
defcone is offline   Reply With Quote
Old 09-01-2010, 04:05 AM   #1143
irgo's Avatar
sp promises this month,
Quark Force
Old 09-01-2010, 05:40 AM   #1144
All it does is stop any kind of surge coming in later. THe timing coming in straight away is much lower, therefore less agressive. Working out the figures, my rev range is around 3,000 - 23,000rpm. A very smooth powerband. Much easier to drive on an indoor technical circuit. The GM and Tekin drivers would know this very well.
maxg123456 is offline   Reply With Quote
Old 09-03-2010, 04:07 PM   #1145
JKL1031's Avatar
HEY,,my hobbywing program CD seems to be bblank.
I cant get to LED program settings 10 and 11 for motor rotation and lipo cells.
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
Old 09-05-2010, 08:43 AM   #1146
slow_jun's Avatar
Trader Rating: 14 (94%+)
Default Ezrun 60A SL V1.1 Sensorless
Hi Guys,
Need your clarification, im using 2 in 1 LCD program card for my Hobbywings ESC's, but when i tried to plug in my EZrun 60A V1.1, it only says Connecting to ESC what is causing this? any ideas?,.... also can the firmware be also be upgraded?like version2 or something or use the turbo function... or the new firmware is only for sensored BL?
Thanks in advance.
Mag 3 taon, tapos isalpak pa sa PAGMUMUKHA KO......... tagal....Deeeeymmm!!!
slow_jun is offline   Reply With Quote
Old 09-05-2010, 09:00 AM   #1147
SuperEk4's Avatar
Trader Rating: 32 (100%+)
Originally Posted by slow_jun View Post
Hi Guys,
Thanks in advance.
Bro din we tell u there's no software upgrade for ezrun esc
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 09-05-2010, 01:28 PM   #1148
cannon's Avatar
Trader Rating: 35 (100%+)
Note his name ... SLOW
Some people it just takes a while to sink in
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 09-05-2010, 04:32 PM   #1149
How about the good old EZrun.
I’ve had these(v1.1 60 +35 amp and v2 60amp)since they came out. The v2 is suppose to be USB supported, but there hasn’t been anything
for these to upgrade to,. Iv'e been waiting for years
So the only difference between v1.1 and v2 is that with the v2 is that you can see what # the software is and DRRS goes to 9 instead of 4.
Did HW give up on these? Or does the "USB Supported" on the on the side of the speedo stand for "You Sorry B#stard"
Absolutely no responce from Hobbywing so I thought I'd try here. There must be thousands of these and the re-branded ones out there.
Thanks for your time
TBOTubed is offline   Reply With Quote
Old 09-05-2010, 05:34 PM   #1150
COBRARACING's Avatar
Even though HW does design the software and hardware for Sp and others it doesn't mean that HW endorses it to be fine to run in the HW equipment.
Like i have said in the past HW will design software and hardware to the oem customers requirements example specifications the oem customer is paying the money and is the boss but that in no means relates to any Hobbywing branded products .we can only give advice to the oem customer and thats as far as it goes but they make the final decision so if they want it to be super fast and run on the edge well then thats what they get no guaranteeing it will last .
Can't you see that some software branded sp and others dont really work on hobbywing equipment
Hobbywing will also release recommended motors for use with there esc's which will inlcude hobbywing motors and other brands .
We are building our name not only to be the most reliable and easy to use esc's but also the most competative in pricing and track performance.
We are also going to make changes to our lcd information to match the written manual and setup sheets from 1 -15 so there is not more confusion for the pro guy and the beginner .
thanks for your time guys
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 09-05-2010, 05:36 PM   #1151
Hi Guys,
Thanks in advance.
The ezrun series is not usb supported only the xerun series
Old 09-05-2010, 05:38 PM   #1152
Iíve had these(v1.1 60 +35 amp and v2 60amp)since they came out. The v2 is suppose to be USB supported, but there hasnít been anything
its branded ezrun for a reason which is plug and play with very simple changes via your led box which is not upgradable
Old 09-05-2010, 08:43 PM   #1153
"2.11 The ESC is USB supported. The firmware of the ESC can be updated through an USB adapter on the Advanced LCD Program Box (Optional device)."
http://www.hobbywing.com/english/Art...?ArticleID=419
This has been listed on the Hobbywing web site for the V2 ezrun since it day one.
A while back you asked what would Hobbywing supporters want to see from Hobbywing in way of products and features. well this is one of mine.
Firmware to smooth out the throttle curve on this great little speedo.
Joe
Old 09-05-2010, 09:11 PM   #1154
JKL1031's Avatar
Originally Posted by hobbywing View Post
Hello!
Very sorry for the late reply!
By now the new firmware "100422stock" is ONLY suitable for XERUN-120A and XERUN-60A ESC (Version 2.0 and later). we have no plan to let EZRUN series products compatible with this firmware.
Hello!
We may think to apply the turbo timing and boost timing technology to 1:8 scale ESC (XERUN-80A and XERUN-150A), but by now we haven't a R&D plan to apply the new technology to EZRUN series products.
The reason is: XERUN series is Hobbywing high end product line while EZRUN is a budget-friendly product line. Normally, we will firstly apply the latest new technology to our high-end products.
But we do need to research the market day and day, so our R&D plan is also changed according to the market requirements.
China Lipos
China Speedos
China Chargers
Old 09-06-2010, 02:31 AM   #1155
Joe
smooth out the throttle curve ok not problem it will be done im on to it .
