Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 01-19-2014, 04:05 PM   #11491
Dan the Man's Avatar
Trader Rating: 39 (100%+)
Not a software question, but how to do you attach the cooling fan to the heatsink of an Xtreme Stock ESC ? I can't see any holes where the screws would screw into, and am a little stumped (and a lot tired)
|-●-|Hot Bodies Pro 5 |-●-|Hot Bodies D8 GT-E|-●-|The "F109X"|-●-|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
Old 01-19-2014, 04:10 PM   #11492
Fredp1's Avatar
The screws fit in between the heat sink ribs
Dean(14 years old)- Awesomatix A800, Fanton FR-1 13.5 Motor, Fantom batteries, KO Propo
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Dad(Fred)- VBC Wildfire D06 Dynamics, Hobbywing Stock Spec, R1 Wurks 21.5, KO Propo
Fredp1 is offline   Reply With Quote
Old 01-19-2014, 08:03 PM   #11493
Question in regards to the Punch Rate Switch Point.
In which % will it give the most punch.
Thanks.
Friulimotosport is offline   Reply With Quote
Old 01-19-2014, 09:13 PM   #11494
cneyedog's Avatar
Send a message via AIM to cneyedog
Hobbywing Xerun V3
the lower the better it would seem, I havent tried it that low, maybe someone else can verify that
cneyedog is offline   Reply With Quote
Old 01-19-2014, 09:54 PM   #11495
Trader Rating: 27 (100%+)
The lower the switch point, the earlier the punch settings will engage. It means you need less throttle for more punch.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 01-19-2014, 10:11 PM   #11496
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Originally Posted by COBRARACING View Post
ok can you tell me your punch rate settings in your throttle control ? also please run the esc and motor without a sensor cable and please tell me does the low rpm cogging go away
Drag brake 10%
Punch control 7
Unplugging the sensor wire did not fix it, but it seems worse with the wire plugged in.
I ran it on punch control 1 (worse)
I ran it on punch control 9 (better but still not OK)
I will go check my other car and post back.
On edit, the other car was missing the sensor cable. HOW that is possible I don't know. I'm going to change the cable on the other car and I'll post back if that fixes it.
On reedit - hey, guess what? Sensor cable.
I'm all good now, thank you for your help!
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 01-20-2014, 10:53 PM   #11497
AlanHall's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
anyone know if the xerun stock spec esc are coming back on the falcon sekido site? if not whats a good replacement for 17.5 touring
Alan Hall
AE B5r
AE B5/SC10
AlanHall is offline   Reply With Quote
Old 01-21-2014, 12:01 AM   #11498
Only 17.5 touring? Look for Justock if you're on a budget. The Xtreme Stock is also very very good. I've used all of them in various 17.5 touring cars and can't complain about anything.
Old 01-21-2014, 12:11 AM   #11499
AlanHall's Avatar
yes would just be blinky 17.5 , but would like the option to toss it in maybe a 2wd sc truck with maybe a 8.5 or something. and i also just like that it uses the case like the 3.1 found soe on ebay though
Alan Hall
AE B5r
AE B5/SC10
Old 01-21-2014, 02:22 AM   #11500
TryHard's Avatar
Thanks.
Originally Posted by cneyedog View Post
Hobbywing Xerun V3
Ok, so seems there is some confusion with this setting.
Punch rate switch point DOES NOT affect the amount of punch, simply where the punch rates switch over in the throttle travel.
As an example;
With a first punch rate of 20, and second punch rate of 30, and a switch point of 50%, in the first half of the throttle travel the punch rate will be 20, in the second half it will be 30.
From this, if you set both punch rates the same, the switch point doesn't matter. So with stock at 30/30.. Won't matter where you run the switch point.
This setting is aimed more for modified users, where having a lower punch rate at the start of the throttle travel in beneficial, whilst still maintaing good punch when further up the throttle travel (which is normally at higher speed). For example, with 4.5t I tend to run 10-12 on the first rate, and 14-16 on the second rate, and keep the switch point at 50%, and this gives a nice smooth bottom end, and good mid speed corner punch.
Regards
Ed
Old 01-21-2014, 06:03 AM   #11501
idbdoug's Avatar
Trader Rating: 33 (100%+)
You can get the HW certified refurbished 120a 3.1 for $165 and add in their discount coupon that they run on rctech for more savings which puts you only about $25 away from new 100amp version. The refurbished units carry 180 day warranty
idbdoug
www.fantomracing.com
www.falconsekido.com
www.reflexracing.net
www.gizmoracingusa.com
idbdoug is offline   Reply With Quote
Old 01-21-2014, 06:11 AM   #11502
idbdoug's Avatar
In 1/12 17.5 I move Punch rate switch point down to a single digit. Both 1st and 2nd punch rates set to highest setting of 30. Since 1/12 has tons of traction you want everything you can get.
idbdoug
Old 01-21-2014, 12:56 PM   #11503
maxepower's Avatar
Exclamation Service ESC?
Hello,
I need to get my HW 120 ampXERUN 2.1 ESC serviced, I accidently plugged my battery backwards just for a second, it still works but now there's a cogging affect going on when you first hit the throttle, tried another motor and sensor wire and still happening. Any advice would be greatly appreciated!
thanks in advance!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-21-2014, 01:26 PM   #11504
Blue Sky's Avatar
Send a message via Yahoo to Blue Sky
Is there plan to have the XERUN-120A-1S V3.1 ROAR approved? Thanks.
Blue Sky is online now   Reply With Quote
Old 01-21-2014, 01:32 PM   #11505
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
yes Ronny
Hobbywing 81020340 81020350 81020360 XERUN-120A V3.1 Software V3.1_121129_beta ESC must use Profile #2, red LED on power button flashes when throttle is at neutral in non-timing mode
OVA is offline   Reply With Quote
