Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 01-15-2014, 08:34 AM   #11476
Trader Rating: 27 (100%+)
Sounds like a sensor cable to me.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 01-15-2014, 03:21 PM   #11477
COBRARACING's Avatar
Originally Posted by CraigMBA View Post
tamiya TCS spec racers need that much gear!
One is A TB-03, 21.5 Thunderpower, geared 3.20. I won the TCS nationals in GT3 with its twin last year.
The other one is the TB04 I would like to run in GT2, 17.5 Thunderpower, geared at 3.50.
The cars needs that much gear to be competitive. Gearing down isn't an option!
ok can you tell me your punch rate settings in your throttle control ? also please run the esc and motor without a sensor cable and please tell me does the low rpm cogging go away
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-16-2014, 12:48 AM   #11478
Trader Rating: 57 (100%+)
I actually come on here to ask the same question as Craig.
In a 1080 gram F1 car.
Orca 21.5 with a Justock
It feels as if there is traction control on the car. Initial punch the car bogs extremely bad on track. It even does this in free rev on the workbench. Sounds slow for 1 second then zings up, like it has boost kicking in.
PROMODVETTE is offline   Reply With Quote
Old 01-16-2014, 12:58 AM   #11479
Whats you drag brake set at?
Old 01-16-2014, 02:23 AM   #11480
On my last run I used 5% drag, 25% force, 0% initial trying to get it to change and it didn't. Like the other guy, it was only effected from a stop or very slow roll. Once it was moving there were no issues.
Old 01-16-2014, 02:26 AM   #11481
What motor brand and wind you running
Old 01-16-2014, 03:47 AM   #11482
idbdoug's Avatar
Trader Rating: 33 (100%+)
Which F1 are you running? F104v2 diffs u have to run tight. I run same speedo but with 2 different types of trinity based 21.5 with no issues. Can't emphasize enough to try a different sensor wire!!
idbdoug
www.serpentamerica.com
www.r1wurks.com
www.falconsekido.com
idbdoug is offline   Reply With Quote
Old 01-16-2014, 06:24 AM   #11483
ORCA 21.5 in the new speed passion car. After thinking about it, pretty sure I done goofed. I probably threw away the brand new sensor wire and put the old junk one on the car
Old 01-16-2014, 07:27 AM   #11484
idbdoug's Avatar
Well I've done worse, lol
Had new HW 3.1 1S speedo 2 weeks and it started acting up or so I thought, not! Found out sensor wire bad. Next week thought I had bad motor but turned out to be stripped nylon nut on 1/12
idbdoug
www.r1wurks.com
Old 01-16-2014, 09:39 AM   #11485
JayL's Avatar
I have had this same problem and it always ends up being the deadband set too narrow
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 01-16-2014, 10:34 AM   #11486
Pro10noob's Avatar
Why do you have to run the F104 diff tight??
Use a 1 piece trustbearing in it and it runs smooth as a baby bum and still got traction enough.
Keep in mind that you have to use the spring washers like this-----> )(
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-16-2014, 10:44 AM   #11487
idbdoug's Avatar
Regards Roy
Yep, I use thrust bearing but I was used to setting like a older F103 diff. Even Mr Exotek has referred to older F103 diff being easier to set.
idbdoug
www.r1wurks.com
Old 01-17-2014, 08:21 AM   #11488
madjack's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to madjack
Thumbs up
I had the same issue with an F1 car (traction control symptoms). After troubleshooting all sources (motor, sensor wire, radio etc.) I worked with HW Tech support and ended up updating the firmware. Problem solved, plenty of bottom end now.
madjack is offline   Reply With Quote
Old 01-18-2014, 05:23 AM   #11489
Hi Guys,
Bit of a noob with all this timing stuff, can someone let me know the best settings and firmware for the HW Xerun 90A 10.5T combo and also recommended FDR for medium length medium traction TC bitumen track in a Xray T4 2014?
Much appreciated.
omen1975 is offline   Reply With Quote
Old 01-18-2014, 08:10 PM   #11490
Thanks COBRARACING for the help, your response time is incredible!
bee200sx is offline   Reply With Quote
