Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 01-13-2014, 07:45 AM   #11461
Pro10noob's Avatar
I assume it is a pancar? looking at your name?
As said before, we need also track length, spur teeth, pinion teeth and tire diameter to determine what to do.
It is a pancar and runs on foam.
So every heat you have tire wear and the rollout will change and there fore the top speed will change also.
Give us motor type, spur,pinion,tire diameter and track length.
The we can calculated what to do.
Change spur/pinion or change settings on ESC.
Also check your sensor cable because if this is faulty, all your setting won't mean a thing as you drive sensorless and there fore no timing or turbo.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-13-2014, 07:48 AM   #11462
Track lenght 25meters, surface carpet 400m2, spur 64dp 36/105T, wheel diameter is 62mm - nosram cpx carpet.
Chassis: hb tcxx
batterry: nano-tech shorty ( good condition after 3 competitions)
New bearing abec5.
gt10r5 is offline   Reply With Quote
Old 01-13-2014, 07:53 AM   #11463
Apple software eh... That may get you a new customer! Picked up a "just stock" combo for my mini (m05) will be testing it out this week. Still running Chinese knock offs in all my off-road, will be waiting to hear more on the apple software before I upgrade those!
Christopher065 is offline   Reply With Quote
Old 01-13-2014, 08:01 AM   #11464
ToysRUsKid's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to ToysRUsKid
Originally Posted by COBRARACING View Post
Just a heads up we are working on a usb link software to work on all Apple products and Android.
I will post more news soon.
Thank you for your support of Hobbywing Products.
That is good news. I just got two new Hobbywing ESCs and would like to be able to use the software on my MacBook.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 01-13-2014, 08:17 AM   #11465
Pro10noob's Avatar
OK TC it is
Dunno what the internal drive ratio is on the TCXX???
If it is around 2.0 then you have a FDR of about 5.83.
I think this is a bit high for a 17.5
The car will be getting out of corners fast but has no top speed.
Go smaller on the spur and check again.
We run that FDR with 13.5 with timing on our track and that one has a straight of about 35 meters.
Regards Roy
Chassis: hb tcxx
New bearing abec5.
l===/o\===l
Old 01-13-2014, 08:41 AM   #11466
I think tcx have 1.95.
Should i change to 5 final ratio?
Old 01-13-2014, 08:41 AM   #11467
Old 01-13-2014, 08:47 AM   #11468
Pro10noob's Avatar
Try that.
Check if top speed is better and check after 2 minutes running, motor temp.
If motor is still running cold you could go down further.
Regards Roy
l===/o\===l
Old 01-13-2014, 10:38 AM   #11469
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
What are people running for punch settings in 12mod? I tried out andy moores setup but I was dumping batteries and was looking for a less agressive feel. I don't usually run much drag brake. Someone helped me and he put in a ton of drag brake but I just couldn't get used to to transition of lots of drag and very low punch. Was almost like I had nothing until full throttle pressed for a second or so.
No fault. Just not my comfort zone. My.fault for not makingthe time to try it out.
I had no problem driving andys setup at all. Just only got 6.5 minutes out of 6500mah lol.
My stuff
Sanwa M12 - Xray T4/16 - Xray Nt1/16 - CRC XTI-WC - ProAMPS - Hobbywing - ReVTECH - ORCA
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com
valk is offline   Reply With Quote
Old 01-13-2014, 05:43 PM   #11470
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
Angelo does the new firmware improve anything on the v3
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 01-14-2014, 11:07 AM   #11471
Barry_Hughes's Avatar
I would try around 5 fdr - boost timing 64 boost start rpm 2500 and lower the boost acc rpm to 250 as this will bring the boost in quicker.
Also the higher the punch control (>9) will give more punch out of the corner, set max reverse to 100.
Turbo settings won't matter as you will only be using boost.
Keep an eye on temps check every couple of mins to start with.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 01-15-2014, 12:53 AM   #11472
CraigMBA's Avatar
Trader Rating: 22 (100%+)
I have a very low speed cogging problem with two different Tamiya shaft drive cars, and two different Thunderpower motors, with two different Justock controllers, If you remove the pinion, the motor is smooth, but unless you nail it from a dead stop, the cogging makes so much noise it sounds like you've trashed a spur. If you nail the throttle, it will drive through it, but this can't be good on the equipment.
Once it starts moving, or if you give it the slightest push, it never does it again.
I speculate this is because the FDR is so high (between 3.2-3.8) the speed control doesn't see the rotor turning and misfires. Any suggestions on how to remedy this?
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 01-15-2014, 01:01 AM   #11473
COBRARACING's Avatar
The gearing is to high .what turn motor you running and what model tamiya car?
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-15-2014, 08:20 AM   #11474
CraigMBA's Avatar
tamiya TCS spec racers need that much gear!
One is A TB-03, 21.5 Thunderpower, geared 3.20. I won the TCS nationals in GT3 with its twin last year.
The other one is the TB04 I would like to run in GT2, 17.5 Thunderpower, geared at 3.50.
The cars needs that much gear to be competitive. Gearing down isn't an option!
Old 01-15-2014, 08:26 AM   #11475
kgombe's Avatar
is the sensor cable good?
Kijana Crichton
kgombe is offline   Reply With Quote
