Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 12-12-2013, 08:47 AM   #11431
Default hw 2.1 1S 120A with SP 4.5T V3.0
Hi!
I'm looking for good starting point with that engine.
My set is:
1S HW 2.1 120A (latest modified soft for that speedo, can be done on stock)
4.5T Speed Passion V3.0 engine
Car is 1/12 scale
Any settings?
Regards!
m.a.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 12-16-2013, 04:28 PM   #11432
ta04evah's Avatar
Is it safe to shorten the receiver & switch wires on a Xtreme Stock esc?
The reason I ask is because I want to do a neat install & wiring job in a touring car and the wires are longer than they need to be.
I will be shortening the wires outside of the esc.
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 12-16-2013, 04:30 PM   #11433
COBRARACING's Avatar
Cheers
Rob.
No problem at all Rob just be very careful when soldering and desoldering the rx wire off the board .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 12-16-2013, 04:56 PM   #11434
ta04evah's Avatar
Thanks for the reply, I won't be opening the esc case to shorten the wires, I'll shorten them on the wires outside of the esc case, I'm not good enough at soldering to attempt that.
Cheers
Rob.
Old 12-17-2013, 04:24 AM   #11435
Any thoughts of a Android App for the software?
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 12-17-2013, 04:32 AM   #11436
TCCustoms's Avatar
Not that have heard, alot if askers but they tell US no
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 12-18-2013, 04:04 AM   #11437
Default HELP
Hi There
I have just moved up to mod class at our local track its very high grip but quite small so im running no boost or turbo. With a 4.5 v10 motor and v3 speedo my issue is..
During the run about halfway in my car seems to develop more drag brake to the point where the car is almost stopping in the middle of a corner.
If anyone can help it will be really appreciated and sorry if this question has been asked before.
THANKS
markmarshall is offline   Reply With Quote
Old 12-18-2013, 07:41 AM   #11438
JFuel11's Avatar
Trader Rating: 145 (100%+)
Default Setup Sheet V3.1
Guys,
I posted this in the other Hobbywing threads but wanted to share here as well. I created a setup sheet that is an editable PDF to track my ESC and motor settings. Thought I would share it with others to help share settings and information.
Xerun 120A V3.1 ESC - 12-17-2013.pdf
Good Luck.
Alan
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 12-18-2013, 07:39 PM   #11439
idbdoug's Avatar
Trader Rating: 33 (100%+)
any update on xerun v10 motor in 21.5??
thanks
idbdoug
www.fantomracing.com
www.serpentamerica.com
www.reflexracing.net
www.gizmoracingusa.com
www.falconsekido.com
idbdoug is offline   Reply With Quote
Old 12-21-2013, 03:13 PM   #11440
durtbag's Avatar
The v3.1 1S is roar approved.
Can you clarify this for me? The HW N/A site says: approval pending, this has me on the fence for purchasing.
http://www.falconsekido.com/products/xr120a-1s-v3-1-blk
durtbag is offline   Reply With Quote
Old 12-22-2013, 07:26 PM   #11441
Testing complete just awaiting to be listed.
Old 12-22-2013, 07:49 PM   #11442
Hi guys just some info listed below about sensor errors.
Red-Yellow/orange -green illumination on the esc is sensor error which actually is red - green just because it switches so fast its seems there is a yellow/orange and depending if it sunlight or dark shaded areas that your looking at it from.
Well anyway because we use 100% pure sensored signal from time to time you will get the errors for the following reason.
1. Sensor cable is faulty or come loose from either the motor or esc plus even a wire might have come our of the plug.
2.You motors rotor is not shimmed close enough to the sensor board halls sensors.
3.Hall sensors are damaged on the motor sensor board.
95% of the time the issues occur from the points sbove and not thr esc or its software.
I hope this helps you guys to understand how the whole sensor errors work and what to look for when the error does occur.
Thats with all the 1/10th xerun series.
For the sct pro and the xerun 1/8th both those esc's their software is designed to run a dual mode system were sensored is used on initial starting torque and then switches to sensorless mode during the run to avoid the large electro magnetic fields that the larger 4 pole motors produce so once in neutral on the throttle or on the brake the system switches to its original state of sensored etc etc until the initial torque has built up them sensorless once again
Old 12-24-2013, 08:25 AM   #11443
DriveItLikeYSIT's Avatar
Trader Rating: 89 (100%+)
Here we release the new firmware V103_130806-Beta for XERUN-150A, XERUN-SCT-PRO, EZRUN-150A, EZRUN-WP-SC8 ESCs,
HWNA made a FB post about this firmware. Was there an update to this release?
TEAM DRIVER==> BocaBearings|Pro-Line Racing |HWNA |
PRO4 - HW XR8 SCT PRO ESC & HW G2 4300kv motor
EXOTEK 22 SCT 2.0 - HW Xerun XR10 PRO ESC & Express Motorsports 24KO 17.5t
TLR 22T 2.0 - HW XR10 PRO ESC & HW Bandit 10.5T
DriveItLikeYSIT is offline   Reply With Quote
Old 12-24-2013, 12:59 PM   #11444
That is the latest.
Old 01-05-2014, 02:30 AM   #11445
http://roarracing.org/4rmb/showthrea...ck-30401020037
Motors listed on the roar forum you can find more approved winds on the same forum.
