Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 11-23-2013, 06:56 PM   #11386
Question: I currently run an Orion R10 pro in 17.5 blinky TC. Would there be any advantages to running a HW speedo with this stock software? Different step profiles?
Sean B. is offline   Reply With Quote
Old 11-25-2013, 06:41 AM   #11387
Default SP 3.0 4.5T for 1/12 with HW 2.1 1S 120A
Hi!
Any tip for setting for Speed Passion 3.0 4.5T engine for 1/12 modified with
hw 2.1 120A 1S speedo?
Regards
michal
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 11-25-2013, 09:40 AM   #11388
vasidudu's Avatar
Originally Posted by vasidudu View Post
Hi Ed,
Thx for the feedback... And hello QLD, have been there a couple of times and missing the place BIG TIME... Coolangatta, Rainbow Bay, Brisbane, Point Danger... Heaven
So I will go with 930 STOCK.
Does this mean I have to have both 930 STOCK in ESC and prog box?
Thx again,
v
Originally Posted by COBRARACING View Post
Correct
Hi Angelo,
I have run the car with the 930STOCK on ESC and still 119 in the box...
Have access to everything... Am I missing something else?
Thx for the help,
v
| TLR 22 + HW v2.1 120A + SP v3.0 8.5T | MBX6e + HW SCT Pro 120A + HW 4274 1800Kv | TM E4RS II + HW Xtreme 60A + SP v3.0 10.5T |
vasidudu is offline   Reply With Quote
Old 11-25-2013, 10:00 PM   #11389
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Alright. i guess ive had my 3.1 set way aggressivly for my 1/12.
I tried to run the default modify mode settings with my Tekin Gen 2 4.5 and Reedy 6500mah 65c and still had power dumping around the 3 minute mark.
I turned the boost timing down from 20 to 10 and still had the timely drop in power. sometimes id get the power and others i wouldnt. maybe rpm related, ie i got on the power after slowing down too much to get into a corner and the punch maybe just sagged the battery?
a reedy pack should be able to handle this car me thinks...
well after hooking it up to pclink, the minimum voltage recorded was 3.1 volts.
what do people run for their punch settings? default is 20. ive tried turning the 1st punch rate down to 10 but if the punch rates are throttle position dependant and not rpm, that probably wont help me. should i run maybe.. 5 and 10? just to stop the battery from dumping so hard?
sucks. car was fast a shyte and had a very nice feel.. for about 3 minutes. was able to have a race with someone i cant touch in stock but then my power just.. goes away. or comes and goes unpredictably...
My stuff
Sanwa M12 - Xray T4/16 - Xray Nt1/16 - CRC XTI-WC - ProAMPS - Hobbywing - ReVTECH - ORCA
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com
valk is offline   Reply With Quote
Old 11-26-2013, 01:45 AM   #11390
M7H
M7H's Avatar
Originally Posted by M.Abramowicz View Post
Hi!
Regards
michal
Ever ran modified in 1/12?
really, just run blinky, or put turbo and boost on 0....
Need more speed, use a bigger pinion.....
Serpent
M7H is offline   Reply With Quote
Old 11-26-2013, 03:04 AM   #11391
TryHard's Avatar
Try this as a starting point for settings.
http://www.hobbywing.com/uploadfiles...-2012IFMAR.pdf
It's for a 3.5t, but would probably be a good guide to help start on 1s settings.
HiH
Ed
TryHard is online now   Reply With Quote
Old 11-26-2013, 07:23 PM   #11392
TCCustoms's Avatar
Originally Posted by andrewd View Post
hi
I have a hobbywing Extreme stock set up in blinky mode for running my 17.5t. I want to put it back to the setting for 13,5 open class. any help on were I get the program for this
go to Hobbywing.com and download the software and read the instructions on how to hook and and run the software or look up vids on youtube of people doing it
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 11-28-2013, 08:53 PM   #11393
Fredp1's Avatar
The new V10 motors should be arriving in stock fairly soon.
I've just received 2 21.5 today. Can't wait to try them out.
Dean(14 years old)- Awesomatix A800, Fanton FR-1 13.5 Motor, Fantom batteries, KO Propo
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Dad(Fred)- VBC Wildfire D06 Dynamics, Hobbywing Stock Spec, R1 Wurks 21.5, KO Propo
Fredp1 is offline   Reply With Quote
Old 11-28-2013, 10:36 PM   #11394
ta04evah's Avatar
I'm interested to see how they go too next Friday night.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 11-29-2013, 12:12 AM   #11395
Fredp1's Avatar
It will be a interesting night to see the difference.
Luke's 417x will loose the Hackmoto and get the v10.
Dean looses the T2 and the XERUN and gets a 417v5 with a v10.
I'll be driving a 417 with one of the boys old motors.
Somehow I think I got the short straw.
Old 11-30-2013, 01:44 AM   #11396
COBRARACING's Avatar
Hello HW friends.
It has come to our attention that some are having issues with their escs going to sensorless mode during their runs .
What we have found is that many are not shimming their motors either to tight or to loose when either changing rotors or during maintenance and some dont do any maintenance at all especially off road were the sensors board hall sensors do get dirty .Some brand of motors dont shim the motors correctly from factory so you must be aware of this issue
No matter what motor you run the shimming has to be perfect or you will encounter errors .It is not the software or the esc in many occasions but what i have discussed in this post .
Shimming is very important to align the rotor with the hall sensors of the motor sensor board for limited errors and performance issues.
Thank you for your time and happy racing.
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 11-30-2013, 01:47 AM   #11397
Hello HW friends.
Can you tell me the best way to shim a motor or how to check correctly??
Bryan D is offline   Reply With Quote
Old 11-30-2013, 01:53 AM   #11398
Motors are different in design but id say about 0.5mm of play just make sure the sensor is as close as you can get it to the rotor end with 0.5mm play when moving the rotor shaft.
Old 11-30-2013, 03:56 AM   #11399
Bar
I had problems with running the hobbywing xtreme stock in 13.5 boosted going into sensorless mode earlier in the year, this would only occur in the finals from a standing start, it seemed to be worse the taller the gearing i ran. This happened with a nosram motor and a gm motor, both shimmed correctly. Towards the end of my outdoor season here in the UK i got myself a new hobbywing v3.1 stock spec. I have not had any problems since, and it has so much more bottom end grunt, it runs cooler and the brakes are also a hell of a lot better as well
Luke Burr
Bar is offline   Reply With Quote
Old 11-30-2013, 04:05 AM   #11400
Default Setups
HiH
Ed
I see that there are setup sheets for the esc I have the extreme stock combo with the 13.5 and 17.5 motors. Is there a place that you can go to view other racers setups and also upload mine to perhaps help over racers
andrewd is offline   Reply With Quote
