Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 11-17-2013, 02:13 PM   #11371
COBRARACING's Avatar
Originally Posted by vasidudu View Post
Hi Ed,
Thx for the feedback... And hello QLD, have been there a couple of times and missing the place BIG TIME... Coolangatta, Rainbow Bay, Brisbane, Point Danger... Heaven
So I will go with 930 STOCK.
Does this mean I have to have both 930 STOCK in ESC and prog box?
Thx again,
v
Correct
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 11-17-2013, 02:36 PM   #11372
Mikkel_R's Avatar
Just wanted to say what a great job Hobbywing has done with the new software and hardware. For the last couple of meetings ive ran the new 120 V3.1 and ive got to say its the best ESC ive ever ran (and ive ran a fair few) I run 13.5 boosted and the car has great infield control ,great speed down the straight, good brakes and more than enough adjustability. Running on medium size indoor tracks at the moment and temps are around 35 degrees C which is amazing. Looking forward to testing it on the larger out door tracks.
Mikkel_R is offline   Reply With Quote
Old 11-17-2013, 02:40 PM   #11373
Thank you for your positive feedback and kind words.Wait until we release the updated v10 motors which i consider will be the best motor worldwide period!!.
Thank you once again
Old 11-17-2013, 06:58 PM   #11374
kermit's Avatar
Originally Posted by subaru73 View Post
any ideas on how to install this on a macbook?
Run a windows virtual machine (windows XP or 7) using VMware fusion or parallels
Adelaide RC Team Driver - www.adelaiderc.com.au
XRAY T4 | Futaba | HOBBYWING | Muchmore
kermit is offline   Reply With Quote
Old 11-18-2013, 12:21 PM   #11375
Hi I am running a 13.5 xerun motor with the extreme stock esc in a xray t3, any advice you could give on gearing and esc setup. The track is a medium technical track with a good straight at wrexham uk.
andrewd is offline   Reply With Quote
Old 11-18-2013, 11:12 PM   #11376
Default Help please
Hi guys,
I have a new setup for 1/10 touring car.
Esc is the Justock (zero timing fixed)
Motor the Hobbywing 21.5t
Kit was the JS-6
What is the recommended FDR or roll out for this combination.
and any tips for esc settings would be great too.
Track is medium technical wise
Many thanks
David
madaz kiwi is offline   Reply With Quote
Old 11-18-2013, 11:27 PM   #11377
Trader Rating: 27 (100%+)
What major changes are going to be made from the current 17.5 v10 to the updated one? I always felt like the motor lacked torque.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 11-19-2013, 12:09 PM   #11378
Hello, just a question.
The xerun manual says about throttle range calibration to set the Reverse in the throttle channel.
I have a Futaba 3pm and the reverse is "OFF", and in these conditions I did the range setting. Now the motor runs in the correct direction, so I don't understand why the manual says to use the reverse.
Do I have to change to "reverse on" and do again the calibration?
In this way the motor will run in the contrary direction or not ?
I don't understand, so I have the doubt to do something wrong even if the motor runs good.
maRRRco is offline   Reply With Quote
Old 11-19-2013, 12:27 PM   #11379
Mikkel_R's Avatar
Hobbywing V3.1 121129 beta running Orion VST2 pro 13.5 with standard motor timing
2A PR SW Point 50%
2B 1st Punch Rate 15
2C 2nd Punch Rate 15
2D TH Curve
2E Neutral Range 6%
3A Drag Brake 0%
3B Brake Strength 75%
3C Initial Brake = Drag Brake
3D BR SW Point 50%
3E 1st Brake Rate 20
3F 2nd Brake Rate 20
3G Brake Curve Linear
4A Boost Timing 24deg
4B BT Start RPM 8500
4C BT End RPM 25000
4D BT Slope Linear
BT By TH Yes
5A Turbo Timing 20deg
5B TT Activation Full TH
5C Full TH Delay 0.1s
5D TT Start RPM 20000
5E TT ENG Slope 15deg/0.1s
5F Deng Slope 24deg/0.1s
I use these settings for Medium to Large sized carpet tracks running on sorex rubber tyres. If the track is a medium size I gear to 6.65 (Xray 24t pinion and 84 spur 48dp) and on larger tracks 5.91 (Xray 27t pinion and 84 spur 48dp) if the track is larger enough I would up the boost and turbo and keep an eye on motor temps.
Old 11-20-2013, 09:54 AM   #11380
Hello
I'm trying the first upgrade of my new v2.1, I want to try a supercharged stock firmware.
I have the program box, updated to the last firmware 1.08.xxxx and out of the box my esc come with firmware 1.10_09025_mod that of course doesn't have boost or turbo. The firmware available with the last usb link software are:
v3.0_110930 mod
v1.10_090205 mod
v3_508 no timing
v1_508_zero_rev
v3.0_110930 stock
v1.10_090323a_m
I don't know what to use, Angelo suggested me the firmware 517 but I don't have it in list, so ... ?
Old 11-20-2013, 12:32 PM   #11381
hi
I have a hobbywing Extreme stock set up in blinky mode for running my 17.5t. I want to put it back to the setting for 13,5 open class. any help on were I get the program for this
Old 11-20-2013, 12:45 PM   #11382
kermit's Avatar
Originally Posted by maRRRco View Post
Hello
v3.0_110930 mod
v1.10_090205 mod
v3_508 no timing
v1_508_zero_rev
v3.0_110930 stock
v1.10_090323a_m
If you are running a stock motor and want boost and turbo then use v3.0_110930 stock
Old 11-22-2013, 06:18 PM   #11383
baznz's Avatar
Default 21.5 fdr
Hi guys,
Esc is the Justock and Hobbywing 21.5t
running a FGR of 2.52 roll out of 74.67
at the end of a 5 minute race coming off the track at 50 dec still cold.
looking at going to a FGR of 2.08 and a roll out of 92.78 is this to tall ????
any help is good
baz
Baz
I try to race in NZ
SpecR
Hobbywing
baznz is offline   Reply With Quote
Old 11-23-2013, 03:11 PM   #11384
ATLASCOPCO's Avatar
Originally Posted by COBRARACING View Post
Hi guys
For any support please email me at ae@hobbywing.com
Because it is difficult through rc tech pm reasons i cannot send files like software or setups to you.
New motors available end of this month.
Macbook not supported as yet for usb link software.
Thanks guys.
You say new motors
What type of motor are they
Are they a high rpm or tourque
And images If available
Thank you
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
ATLASCOPCO is offline   Reply With Quote
Old 11-23-2013, 06:09 PM   #11385
idbdoug's Avatar
Trader Rating: 33 (100%+)
A couple of times today running the newer 1SV3.1 one cell HW speedo, the car slow down like it sensed a low voltage. The power button light looked like it was flashing green or green yellow. Turned off speedo and turned back on and it went away. I had the low voltage disabled. Next run I turned low voltage back to auto and this problem didn't happen the next run. I checked battery after charging and it read near 4.2 or normal after charging. I also can't find in manual what this flashing light indicates.
Has anybody else had this happen. Only third weekend with speedo and second weekend on new 1 cell lipo
idbdoug
www.serpentamerica.com
www.r1wurks.com
www.falconsekido.com
idbdoug is offline   Reply With Quote
