Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 11-10-2013, 05:04 PM   #11356
Originally Posted by TryHard View Post
Boost start is way too low. Try putting it closer to 6-8,000 rpm (I'd personally go closer to 8). Then adjust the boost end r to about 16-18,000.
A 10.5 will pretty much always be spinning at over 4000rpm on track with that gearing, so your basically adding in extra static timing, which the lrp's don't need.
Also look to lower your punch settings, although 10.5 I would have started out with 30/30, but 25/30 or 25/25 could help to lower temps.
HiH
Ed
thanks ed...
but unfortunately i did burn the motor yesterday before i read you post..
just a curios, you were saying 10,5 motor spinning over 4000rpm... is that mean all 10,5 motor or just this lrp x20 motor?
cheers
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 11-12-2013, 05:20 AM   #11357
TryHard's Avatar
Originally Posted by k4mp4q View Post
thanks ed...
cheers
The statement is pretty much for all 10.5 motors.
Using the speedchart I have, and plugging in your settings, the start speed for the boost is around 4mph. Now, from previous testing, the slowest corners on most tracks are around 7-9mph. So the settings your using are pretty much having most of the boost dialed in the whole time... hence the overheating.
HiH
Ed
Old 11-12-2013, 06:24 AM   #11358
Nuno Gancho's Avatar
What will be the difference if having the same FDR example 7 what will change if we have a bigger/smaller spur gear or pinion to achieve the same final FDR. thanks.
Nuno Gancho is offline   Reply With Quote
Old 11-12-2013, 07:06 AM   #11359
Bar
Does anyone know where i can find a blank setup sheet for the hobbywing v3.1?
Luke Burr
Bar is offline   Reply With Quote
Old 11-13-2013, 12:57 AM   #11360
vasidudu's Avatar
Hi to all,
In need of some advice here.
I am running an Xtreme 60A in my TC with a Speed Passioon MMM 10.5T.
Angelo kindly sent me a setup sheet for the type of track I will be running on, THANKS for that Angelo
Now my issue:
I am using a prog box (not the latest one but not the LED one).
In the setup sheet provided by Angelo, it states F/W: 211 STK. I suppose this is the firmware version that has to be used in the prog box?
Now to "inject" the 930 STOCK in my Xtreme ESC, I will have to have the following:
1. 211 STK installed as firmware in the prog box
2. USB link v3.3 installed on my PC?
Could anyone confirm this?
Many thanks,
v
| TLR 22 + HW v2.1 120A + SP v3.0 8.5T | MBX6e + HW SCT Pro 120A + HW 4274 1800Kv | TM E4RS II + HW Xtreme 60A + SP v3.0 10.5T |
vasidudu is offline   Reply With Quote
Old 11-13-2013, 05:06 AM   #11361
TryHard's Avatar
Originally Posted by vasidudu View Post
Hi to all,
Now my issue:
Many thanks,
v
If I'm reading that right, you want to install 211_STOCK so as to match the setup sheet?
Honestly, if you have 930_STOCK installed already, just use those settings with that firmware. No need to roll back to 211.
930 was is the most update firmware available for the xtreme 60A, and has all the same settings as 211, with some more improvements.
HiH
Ed
Old 11-13-2013, 05:24 AM   #11362
vasidudu's Avatar
HiH
Ed
Hi Ed,
Thx for the feedback... And hello QLD, have been there a couple of times and missing the place BIG TIME... Coolangatta, Rainbow Bay, Brisbane, Point Danger... Heaven
So I will go with 930 STOCK.
Does this mean I have to have both 930 STOCK in ESC and prog box?
Thx again,
v
Old 11-13-2013, 05:37 AM   #11363
lewis110's Avatar
Hi Ed,
Thx again,
v
You don't have to install into program box. The program box just reads/displays what's already installed in the esc.
Hobbywing of North America/FalconSekido www.falconsekido.com
Hobby-Pro USA www.hobbyprousa.com
Dialed RC Hobbies/VP Pro USA www.Dialedhobbies.com
lewis110 is offline   Reply With Quote
Old 11-13-2013, 05:43 AM   #11364
vasidudu's Avatar
BIG UP to you, thx for the feedback...
So if I gather well, once I have updated the soft in the ESC (to 930_STOCK), the prog box will display it on its screen once connected to the ESC?
Thx again to all, much appreciated,
v
Old 11-15-2013, 03:04 PM   #11365
Default Gearing
Originally Posted by PDR View Post
Are you running blinky or boost/turbo?
If you're running blinky, you can probably gear taller (smaller spur/bigger pinion) to around 3.8, since the XERUN motors are quite torquey.
If you're running boost/turbo, then you're geared way too tall and probably need to aim for 6'ish (ie: larger spur/smaller pinion).
Phil.
I ran the motor tonight at 3.8 and could fry an egg on it after 5 mins would you suggest going down or up a pinion
Would probably got to about 4.2
andrewd is offline   Reply With Quote
Old 11-15-2013, 07:29 PM   #11366
FastPete's Avatar
Trader Rating: 44 (100%+)
Smaller pinion. Have plenty of top speed-top end?
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 11-15-2013, 09:48 PM   #11367
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
If the motor's getting too hot in blinky, then shorter gearing is the easiest thing to do. There are two ESC settings that can have an impact on heat build up which are "punch" and "drag brake". Finding the right balance between all three for any given track and your preferred driving style will be a matter of experimentation.
If the motor was topping out with your initial gearing at 4.3 and getting too hot at 3.8, at least you know the answer is between those two
Phil.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 11-16-2013, 12:08 AM   #11368
Default Gearing
Phil.
Thanks will give it go and update the post
Old 11-17-2013, 01:35 PM   #11369
subaru73's Avatar
Trader Rating: 41 (100%+)
Default usb software link
any ideas on how to install this on a macbook?
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 11-17-2013, 02:11 PM   #11370
COBRARACING's Avatar
Hi guys
For any support please email me at ae@hobbywing.com
Because it is difficult through rc tech pm reasons i cannot send files like software or setups to you.
New motors available end of this month.
Macbook not supported as yet for usb link software.
Thanks guys.
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
