Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 11-06-2013, 02:03 AM   #11341
M7H
M7H's Avatar
Originally Posted by sonspit View Post
No it's not.
That's why you can not downgrade to another firmware.
We are talking about the Xerun 150A ESC, aren't we?
Anyhow, you then have to download the latest USB link firmware from the HW site, and then you should be able to downgrade to any firmware available in the list, and as I mentioned before, maybe downgrade even further, by running an older USB link software version.
You can install several USB link software versions next to each other on your PC, if you just unpack them in seperate folders.
Serpent
M7H is offline   Reply With Quote
Old 11-06-2013, 06:46 PM   #11342
Osiris 75's Avatar
Trader Rating: 17 (100%+)
I'm trying to run Blinky for the first time, and I changed to stock 17.5 preset on the program box, but the esc doesn't blink. Is it supposed to, or is something wrong?
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS / EA MOTORSPORTS
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 11-06-2013, 07:37 PM   #11343
whiskyshooter's Avatar
Stock isn't blinky. It can be but u need to take all the boost and timing out with the box. Or use profile #2 no timing. That's the blinky profile
whiskyshooter is offline   Reply With Quote
Old 11-07-2013, 08:58 AM   #11344
Where can I find the older usb link software.. I currently have ther latest so ok guessing the firmware installed on the esc is old then. But it won't let me flash any firmware thats listed. I find this odd. I have the 120a and never had a problem like this
sonspit is offline   Reply With Quote
Old 11-07-2013, 08:59 AM   #11345
And yes it's the 150a xerun.
Old 11-08-2013, 01:16 AM   #11346
M7H
M7H's Avatar
I don't think it will help, because you have to be able to flash the ESC with the latest firmware, but here you have almost all older version, maybe you are able to flash your ESC.
http://sdrv.ms/VAi4uZ
Serpent
Old 11-08-2013, 02:59 PM   #11347
Default Gearing
Any help out there fork some gearing
I'm running a 17.5t xerun and the xtreme stock speedo
Ran the car tonight and it feel as if it's reving on the throttle I am running at 4.3 fdr and the car that I am running is a xray t3 2011
The track is a little twisty with a 15 -20 meter straight
To get the 4.3 I am using a 75spur 33 pinion 48 dp
andrewd is offline   Reply With Quote
Old 11-08-2013, 04:34 PM   #11348
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Are you running blinky or boost/turbo?
If you're running blinky, you can probably gear taller (smaller spur/bigger pinion) to around 3.8, since the XERUN motors are quite torquey.
If you're running boost/turbo, then you're geared way too tall and probably need to aim for 6'ish (ie: larger spur/smaller pinion).
Phil.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 11-09-2013, 04:14 AM   #11349
I know this forum is for the esc .But I was wondering if Hobbywing were thinking about producing a battery charger. As I been using there motor's and esc for a good while with no issues to speak off. So I would be defiantly interested in a charger produced by HW
big paul is offline   Reply With Quote
Old 11-09-2013, 06:12 AM   #11350
Default Lrp x20 10.5 modified with hw v3
Hi guys....need help on the above combo...
Lrp on 27.5 timing which is box standart, my question is that the motor get 120 degree Celsius in 5 menit....
V3 setting
Fdr 7.1
Boost 22
Boost star 4000
Boost end 14000
Turbo 23
Turbo by throtle
Slope 18 engage and disengage
How to lower the temp on the motor
The track is big
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 11-09-2013, 10:01 AM   #11351
Phil.
Thanks for your help
I have also been asked to race at a 13.5t do you have any advice on gearing for this setup in blinky and boost
Old 11-09-2013, 04:05 PM   #11352
TryHard's Avatar
V3 setting
Fdr 7.1
Boost 22
Boost star 4000
Boost end 14000
Turbo 23
Turbo by throtle
The track is big
Boost start is way too low. Try putting it closer to 6-8,000 rpm (I'd personally go closer to 8). Then adjust the boost end r to about 16-18,000.
A 10.5 will pretty much always be spinning at over 4000rpm on track with that gearing, so your basically adding in extra static timing, which the lrp's don't need.
Also look to lower your punch settings, although 10.5 I would have started out with 30/30, but 25/30 or 25/25 could help to lower temps.
HiH
Ed
Old 11-10-2013, 02:52 PM   #11353
SteveM's Avatar
Trader Rating: 133 (100%+)
I have a new HW Extreme Stock speed control and a new Multi Function LCD Program Box and I can change the various settings just fine. But how do I put the ESC into Blinky mode so the light actually blinks? I run Windows 8.1 and I do not see software on the HW web page that I can install. Please help.
SteveM is online now   Reply With Quote
Old 11-10-2013, 03:55 PM   #11354
COBRARACING's Avatar
Send me an email at ae@hobbywing.com
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 11-10-2013, 03:56 PM   #11355
SteveM's Avatar
Done...thanks.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
