Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 11-02-2013, 11:19 PM   #11326
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
So what would cause my 3.1 1s to have random brownouts of power? One lap it will work as expected and be fast as shyte but another lap ill punch it and the car just lumbers down the straight.
I ran the esc in 13.5 blinky and it worked flawlessly though had issues with standing starts until i changed neutral width to 4%.
Switched the esc to a 4.5 car and left the stock software on and encountered this power problem.
While i have attention i might ask for setup advice on 13.5 blinky 1/12. I ran the esc with default stock software settings and it was fine. Curious about the three punch settings ect.
Running with a reedy sonic mach 2 stock rotor. 32deg timing and 88-89 rollout. 70x30 technical medium traction carpet.
My stuff
| Sanwa - Team Associated - Reedy - ProAMPS RC - Novarossi |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/
valk is offline   Reply With Quote
Old 11-02-2013, 11:31 PM   #11327
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Come see me Doug and I will get you set up for stock 12th with your HW. I've been running it in my 12ths for a while now.
AWD
Old 11-02-2013, 11:57 PM   #11328
COBRARACING's Avatar
What is your lvc set at ? Low voltage cut off? Also please do a complete recalibration and also tell me what your punch settings are set at and what battery your using.
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 11-03-2013, 12:36 AM   #11329
Are there any plans to offer any 1s esc options other than the 120 A 3.1 1s? Something like a juststock, or stockspec but for 1s specifically? With the older Xerun 1s not available, the 3.1 seems like overkill for most classes and a lighter 100 A version would be welcome.
Old 11-03-2013, 12:44 AM   #11330
valk's Avatar
Lvc was default 3.4v i think. Punch default for the stock profile but also had the same issue with modified profile.
Battery was turnigy nanotech 5600 50-100c. Motor is tekin gen 2 4.5t with high rpm rotor.
I did notice the tunigies have a wicked sag in mod. My orca program card reported a drop o 6.6 volts in my 4.5 mod tc lol. I have a reedy 65c 6500mah but that battery feels very flat compared to the turnigy 5600.
Planning to puck up some smc 70c batteries. Would those be sufficient for mod?
My stuff
My RC
Old 11-03-2013, 12:56 AM   #11331
We do have something in the pipeworks
Old 11-03-2013, 01:00 AM   #11332
Ill answer in 1 hours time.
Old 11-03-2013, 06:50 AM   #11333
idbdoug's Avatar
Trader Rating: 33 (100%+)
AWD
Will do
idbdoug
idbdoug is offline   Reply With Quote
Old 11-03-2013, 05:50 PM   #11334
idbdoug's Avatar
What's the stock spec v3.1 approval status with ROAR? I read above that new 1SV3.1 has been approved
idbdoug
Old 11-04-2013, 03:04 AM   #11335
vasidudu's Avatar
Originally Posted by COBRARACING View Post
Both will do the same job just the xtreme stock has a smaller foot print .
Software for both the 10.5 and 13.5T i would run software version 930 stock .
If you need setup info please email me at ae@hobbywing.com i would be happy to help out.
Originally Posted by vasidudu View Post
Now if this is not customer service / care, what is?
930 stock: does this allow me to use timing / turbo etc...???
Thanks a LOT for the offer; I will most likely take it.
Best,
v
Hey Angelo,
THX A LOT for your feedback through PM.
This is really appreciated and it is encouraging to have such support.
All the best,
v
| TLR 22 + HW v2.1 120A + SP v3.0 8.5T | MBX6e + HW SCT Pro 120A + HW 4274 1800Kv | TM E4RS II + HW Xtreme 60A + SP v3.0 10.5T |
vasidudu is offline   Reply With Quote
Old 11-04-2013, 04:42 AM   #11336
Originally Posted by sonspit View Post
I have the 150a xerun esc using firmware V103_130806_Beta
hi
I am trying to upgrade or downgrade to firmware V1.00_111207a_2R
so I will not have compatibility issue with my tenshock motor
but the link is telling me beta cannot be updated to this version.
why is that?
can u help me?
Seems as though no one wants to respond to this question... I emailed hobbywing twice and came here for help when I got no response.. But now I see this might be a issue that
goes a little deeper
sonspit is offline   Reply With Quote
Old 11-04-2013, 06:43 AM   #11337
M7H
M7H's Avatar
With the LATEST USB Link software on your PC, you should be able to downgrade your ESC to an earlier firmware version, if it is available in the list. If not, I think it is going to be difficult.
Even if "V1.00_111207a_2R" is not in the list, you can go back to the oldest one available in the list, close the USB software, start an older USB software, and downgrade the ESC again to an older firmware version available in that list.
This way I was always able to downgrade to any firmware I wanted, even sometimes in steps "back in history".....
Serpent
M7H is offline   Reply With Quote
Old 11-04-2013, 08:03 PM   #11338
thx for he response!!
wht I dnt understand is "V1.00_111207a_2R" is on the list..
no sure if I tried to go older, but I'll test it tomorrow..
thx again!!
Old 11-05-2013, 01:42 AM   #11339
M7H
M7H's Avatar
But is "V103_130806_Beta" also in that list?
Serpent
Old 11-05-2013, 04:13 PM   #11340
No it's not.
