Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 08-30-2010, 01:38 AM   #1111
Benzaah's Avatar
Trader Rating: 21 (96%+)
Originally Posted by defcone View Post
How large was the track? 10500 start rpm seems way too high for a 17.5t
Try 9000 or 10500 mate and see for yourself. the combination of motor timing, low ratio and high boost start means the motor and gearing are dong all the hard work and if you are mashing it then the turbo is kicking in before the boost but the set up below has a low turbo so you dont notice it as much.
Track is very large. Here is a link.
http://www.nearmap.com/?q=@-34.85776...h&nmd=20100216
If you click to the latest update you will see the slight changes that were made to the track. Would have to be at least a 40m straight.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 08-30-2010, 06:15 AM   #1112
blade072's Avatar
Trader Rating: 98 (100%+)
if anyone wants to know a good setup for the same track but for a 10.5 let me know and i will post it here....... all i can say is the xtreme worked flawless....pity my driving wasnt.
David Randall
AWESOMATIX A800 ★ MUCHMORE ★ R1 WURKS ★
TEAM XRAY X116 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 08-30-2010, 07:24 AM   #1113
McX
Default Looking for starting poin
I'm new in 1/12 and brush less stuff. Car is ready, needs to find out, how to set up for the first training day.
Setup:
1/12 CRC, 10.5 Novak balastic, xerun 60A V2, 1S Lipo SMC 5300, Spur gear 64 dp 96 tooth (can change other 64dp size). Radio dx3s.
Track - carpet, not very big, 1 strught about 10-20 metres and turns.
1. pinion tooth? Not sure how to calculate that.
2. Version 1.06_100512 on xerun 60A V2 now. Is it ok? Or I need to put some new version or other more compatible with 1/12? I got program box.
3. Can I remove fun?
4. What settings I should change for starting point in ESC?
I now that lot of information is written before, but there are more than 70 pages and it will take an ages to reed and find everithing I need. So advice would be very help full for me!
cheers
M
McX is offline   Reply With Quote
Old 08-30-2010, 08:35 AM   #1114
JKL1031's Avatar
No do not remove the fun
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
Old 08-30-2010, 09:45 AM   #1115
McX
Why? I red other experience before, that 10.5 T without fun is ok.
Old 08-30-2010, 11:28 AM   #1116
JKL1031's Avatar
I see ur probly using a translator. I tried to delete that first post but cudnt.
The correct word is fan with an "a." u could remove it and see If you can get good runtime without thermal cut off.Hope you understood.
China Lipos
China Speedos
China Chargers
Old 08-30-2010, 11:38 AM   #1117
Hi all,
I was hoping for a little advice. I'll be running 12th scale this winter and don't want to break the bank with brushless. I'm looking at the 60A versions and was wondering if they work with 1s LiPo, specifically, how to hook up the ESC using a small LiPo Rx pack and voltage regulator. Also, what is the difference between the stock extreme and what I assume is the regular 60A ESC (the black one)? I'm not terribly concerned about timing advance although it's be fun to play around with. I'll be running either 10.5 or 13.5 with a Protek 5000 LiPo. Thanks in advance for any and all advice and help!
adam lancia is offline   Reply With Quote
Old 08-30-2010, 11:59 AM   #1118
McX
You are right. Engish and england is not my native stuff! So what?
adam lancia
Yes you can use this ESC with booster or extra battery pack. I prefer booster.
Old 08-30-2010, 12:25 PM   #1119
Blind's Avatar
can anyone confirm for me which speed passion esc will work with this software?
inspire v2.0, short course master, ...?
Looking for the cheapest esc to pick up to play with this
What about the new $27 60a or $37 100a hobbyking esc at HK?
http://www.hobbyking.com/hobbyking/s...pgrade_version)
http://www.blindbatteries.com
http://www.ebay.com/usr/blind_batteries <-My eBay Feedback
Blind is offline   Reply With Quote
Old 08-30-2010, 06:09 PM   #1120
Trader Rating: 112 (100%+)
Send a message via AIM to Valentin.H
Hey guys,
I don't know how many of you run the new 2.0 ESCs from Hobbywing....but i have two cases that i thought i would be able to use (i have a SP 1.0 with a broken case) and got the 2.0 and the 1.0 escs from HW mixed up..so PM me if you are interested..won't let em go for free (since i did put money into these)..so maybe $10 shipped each? they are black for xerun 120a v2
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 08-30-2010, 06:32 PM   #1121
defcone's Avatar
Trader Rating: 15 (100%+)
the 2.0 pro and lpf and the 2.1 stock one will work with this software
defcone is offline   Reply With Quote
Old 08-30-2010, 10:45 PM   #1122
Originally Posted by AGNO View Post
HW 528MOD is available!
If you use Vista you run the program as an administrator and he will appear.
I have Windows 7, but you were right. I ran as administrator and 528mod is there
I have asked like 3 of 4 times before why I couldn't see 528mod and people keep giving me the run around. Thanks for your help.
garycoleman is offline   Reply With Quote
Old 08-31-2010, 01:33 AM   #1123
So what would be a good 17.5 motor to boost? Our track has no A/C and is sometimes pretty warm..Also some start settings would be nice.
Here is my track.
Well I run on a track simillar size with a 13.5. I cannot stand irregular jumps in torque, it just overheats the tires indoors.
With a new 17.5 GM motor, i'd gear it at around 5.50 to 6.00 with stock timing.
I always do RPM start 3,000-4,000rpm which makes ramp smooth
Timing Punch - try -3 or -4 which is a long ramp for a 17.5 for smooth acceleration)
Turbo - Max
Turbo delay 0.2
DDRS 7
maxg123456 is offline   Reply With Quote
Old 08-31-2010, 02:03 AM   #1124
cherry2blost's Avatar
Originally Posted by adam lancia View Post
Hi all,
The new 1s XERUN is available according to my price list, maybe ask Angelo if he can get you one in from HW?
Cheers
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 08-31-2010, 02:21 AM   #1125
AGNO's Avatar
Are happy to be of help.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
