Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 08-31-2013, 05:04 AM   #11176
TB03Racer09's Avatar
I have a hobbywing xtreme stock 60a esc, I don't own the program box yet. Is there a way of turning off the timing without the program box? (I ran it without the sensor wire plugged in but its not as smooth)
TB03Racer09 is offline   Reply With Quote
Old 08-31-2013, 10:18 AM   #11177
Trader Rating: 27 (100%+)
If you just set boost and timing to 0, it'll be in blinky mode.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 08-31-2013, 10:19 AM   #11178
lewis110's Avatar
Here is the link for the Xtreme stock. If you have the manual you can also look there. It gives you the steps to do it manually. Basically you have to count lights/beeps. Turn on the esc with the red setup button pressed. Hold until the light turns green keep it presses it will beep once for calibration, make sure you hold it until green light. That will get you into program mode.
http://www.hobbywing.com/product_show.asp?id=249
Hobbywing of North America/FalconSekido www.falconsekido.com
Hobby-Pro USA www.hobbyprousa.com
Dialed RC Hobbies/VP Pro USA www.Dialedhobbies.com
lewis110 is offline   Reply With Quote
Old 08-31-2013, 05:31 PM   #11179
I've tried the set key method and it didn't work. I looked at the manual and it says the set key method is invalid when using firmware with 15 programmable items...doah. I guess I will have to wait until I get the program box
Old 08-31-2013, 10:35 PM   #11180
COBRARACING's Avatar
Ezrun no problem but the xerun series is very limited in programming without the lcd program module
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 08-31-2013, 10:38 PM   #11181
Originally Posted by Robkitetop View Post
Cobra can you confirm this? Manuel of the esc states that 'timing' can be used with both sensored and sensorless motors.
Thanks,
Robbert
Timing will work without a sensor but turbo and other features need to know where the rotor is positioned at any given time to work .
Old 09-01-2013, 12:30 AM   #11182
Robkitetop's Avatar
Thanks Cobra. So Boost from the STOCK firmware should work with the sensorless motor or are you referring to the 'AMTS' timing in the older MOD software?
Robkitetop is offline   Reply With Quote
Old 09-01-2013, 01:23 AM   #11183
TryHard's Avatar
Boost/Turbo will only work with a sensored motor, with the sensor plugged in. It needs the sensor to know when in the rev range to apply the extra timing.
AMTS should work with a sensorless motor, as this just add's a set amount of timing to the motor, regardless of RPM. Think of it in a similar manner to motor endbell timing, but applied by the ESC.
Regards
Ed
Old 09-01-2013, 01:57 AM   #11184
Robkitetop's Avatar
Regards
Ed
Thanks for clearing that up Ed! We can either run 13,5t blinky or 12t sensorless at the race. It's a fast flowing track with a long straight so I need the high RPM of the 12t motor. Going to try to increase the 'AMTS' timing and play with the gearing while monitoring the temps.
Old 09-02-2013, 06:00 AM   #11185
BoneCrusher's Avatar
Default 12th scale 4.0T speedo setup help
Does anyone have a starting setup I can try for:
12th Scale Modified using a 4.0 Reedy Mach 2 using a Hobbywing V3.1 1s speedo for an indoor ozite track 36 x 80 feet? Including rollout?
What settings after should I play with with different track types? I'm an intermediate skilled driver.
Anyone's help is much appreciated!
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 09-02-2013, 01:57 PM   #11186
When will the V10 motors be in stock.8.5 turn.Thanks.
tripleh is offline   Reply With Quote
Old 09-04-2013, 04:48 AM   #11187
Hi is there any difference between the stock extreme and just stock for 17.5 blinky? Thanks...
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 09-05-2013, 12:15 AM   #11188
RoyB's Avatar
Trader Rating: 15 (100%+)
The xtreme stock is 60a and the justock is 45a.
RoyB is offline   Reply With Quote
Old 09-05-2013, 12:58 AM   #11189
ta04evah's Avatar
Plus the Xtreme Stock has the additional features of Boost & Turbo settings.
If you're only ever going to race 17.5 blinky then go for the Justock esc. There's numerous racers that use the Justock and like it for it's simplicity, and for it's smooth & reliable performance.
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 09-05-2013, 11:17 PM   #11190
Roar approved v10 motors 1 month away.
