NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 06-05-2013, 09:04 PM
  #11026
RoyB's Avatar
Trader Rating: 19 (100%+)
Originally Posted by COBRARACING
Correct 129 is the latest for the v3 range
Thanks for the quick reply.
Is there anyway to shutoff the feature that shuts off the esc if you hold the brake on for several seconds?
RoyB is offline
Old 06-05-2013, 09:19 PM
  #11027
COBRARACING's Avatar
Your welcome .No way of shutting off the feature as its part of the data recorder.
COBRARACING is offline
Old 06-07-2013, 11:54 AM
  #11028
RoyB's Avatar
A couple of questions, the last I hope.
In the data log what does the Min battery voltage measure?
What motors will the motor temp work in the data log? Am using a reedy sonic 17.5 and it does not show motor temp. It does show rpms.
RoyB is offline
Old 06-08-2013, 05:45 AM
  #11029
lewis110's Avatar
The only motors I've found that work with the motor temp is the Hobbywing motors. I've tried SchuurSpeed, Murfdogg, epic D3 and thunder power none worked. I beloved it does say in the manual that it will probably only work with Hobbywing motors. Minimal voltage is the lowest seen voltage during the run.
lewis110 is offline
Old 06-08-2013, 12:18 PM
  #11030
Barry_Hughes's Avatar
temp will ok work with GM motors also Corally pro red series, though is a little bit out on the pro red
Barry_Hughes is offline
Old 06-12-2013, 10:01 PM
  #11031
Cool
Temp log will only work with the hobbywing motors basically because of the sensor wire configuration.
Old 06-13-2013, 12:26 AM
  #11032
Where to buy a replacement v3 fan ?
Manson is offline
Old 06-13-2013, 12:39 AM
  #11033
Cpd racing uk
Old 06-13-2013, 12:49 AM
  #11034
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
http://www.cpdracing.co.uk/index.php...d=56&Itemid=61
I didn't realize this feature existed. Thought I would share in case I wasn't the only one.
andrewdoherty is offline
Old 06-13-2013, 01:03 AM
  #11035
rocketron's Avatar
Trader Rating: 16 (100%+)
Many of the current "race" motors do not have a thermistor internal so there is no heat measurement back to the esc.
rocketron is offline
Old 06-13-2013, 09:25 PM
  #11036
tips please
im running a xerun 120a v2 / xerun 3.5t in a tc( sakura zero s) whats the best firmware and gear recommendations for best performance ... I just bash/speed runs for now.
any help is appreciated from the more seasoned hobbyist
sonspit is offline
Old 06-13-2013, 11:33 PM
  #11037
Just an FYI on a V3.1 the temp logs for the Reedy Sonic Mach 2 13.5 motor I have.
luda is offline
Old 06-13-2013, 11:59 PM
  #11038
Cool, a swap to a Mach II sensor board should get their previous iterations to log temps as well. Thanks.
Old 06-14-2013, 10:36 AM
  #11039
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Got a 120 amp v3 xerun forsale. Contact me for infor or look up my forsale thread. Thanks
xrayaustin is offline
Old 06-14-2013, 05:02 PM
  #11040
Meilleur's Avatar
Trader Rating: 24 (96%+)
Angelo,
Thanks for the 13.5 setup. Quick question. Based on your overall timing by the ESC (55 deg), should I set the motor timing to 0 deg?
Meilleur is offline
