NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#1081
I think the problem is the LCD box can't read the esc with the 528 profile be installed....
#1082
I used HW V1.5 and then updated to later HW version on my SP LCD programmer.
#1083
if you have teh SP firmware then you need to go back to a earlier version HW/SP firmware and then update again with the latest HW. Somehow the SP locks out updating to newer HW firmware for the LCD programmer.
Who would have the HW V1.5 software on hand?
#1085
I just figure it out what went wrong ...You are part of right...If you have the HW LCD box ,you must updated the firmware with the HW V1.6 FIRST before you can use the HW LCD box with the SP 528 software is or load in the esc..
DON"T loaded the SP Firmware in the HW LCD ,use the HW V1.6 than everthing works fine afterward...
PS no need to go back to a HW earlier version ..just load the latest V1.6 it will over ride the current version ...
I think the HW /SP esc are able take or works with any HW/SP version software ...Must have the latest sofware so the LCD box can read what is inside the esc setting ...
#1086
Firmware HW and SP are completely identical and compatible, only change the logos brands.
#1087
hi Korey
#1088
I think it's best to state that you can use HW's software on SP hardware and vice-versa. But not HW LCD Firmware with SP ESC Firmware, nor SP LCD Firmware with HW ESC Firmware.
#1089
This is no longer true to my understanding. The LCD labels read differently between the two brands.
#1090
It can be used without problems the FW LCDbox HW on FW ESC SP and vice versa, only creates confusion in reading the data.
#1091
Both software packages HW and SP are 100% the same you just need the latest USb link software 1.62 to be able to run the 528 and future upgrades .
next week there will be a release of a patch file for the xtreme stock for off road use what it fixes is from forward to reverse elimates the small delay in transfer .
thank you for your time
regards Angelo Tech support Hobbywing products
#1092
Hi guys
I have tried to follow you in here, but i'm lost
Can I use the Hobbywing 2in1 program box pro, with the Xerun 120A brushless speedo, and stil get all the software/firmware updates, both for the speedo and program box??
Please help me sort this out.
And how is your experiense with power, compared to other speedos, LRP, tekin etc etc....
Thanks.
Thanks.
#1093
#1094
#1095
The computer is only for to change the firmware(modified,stock,off road), you can do at home, in the track,all control is easily accessible with LCDbox or LED program card.
