Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 05-11-2013, 05:08 PM   #10906
COBRARACING's Avatar
Originally Posted by slow_jun View Post
Again...top notch service...more than a step above the rest...
Thanks again Angelo and Team...
Thank you for your kind words .This is my job and even though we are small compared to others i want us to have the best product but alse be the best in tech support and after sales service.
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 05-13-2013, 06:26 AM   #10907
Holmenkollen's Avatar
Iīm having a bit of problem with my V3. Running a SP4.5t with some boost and turbo on a pretty big track. This weekend I got smoked on the straight by people running Reventon Proīs and SP 4.5t. They had massive power out on the straight, I really lost some ground there. My motor temps are low (57C) but the ESC reads out +115C. And the power isnīt that great, so something is off. The ambient temps were only 15C...
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 05-13-2013, 10:51 AM   #10908
Pro10noob's Avatar
Gear up.
Your ESC is switching like mad and therefore becomes hot.
Your motor hasn't have to do anything and that is why it is still cold.
Gear up 2 teeth on pinion and go out again.
Check motor and ESC temps after 2/3 minutes and work your way from there.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 05-13-2013, 11:13 AM   #10909
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Do you guys know the differences between the Hobbywing XERUN Stock Spec ESC and the XERUN V3.1? I know that one is 100amp vs 120 amp, but is there anything else?
IIGQ4U is offline   Reply With Quote
Old 05-13-2013, 11:37 AM   #10910
maxepower's Avatar
Exclamation Blinky mode for 17.5
Hey guys,
New to Hobbywing ESC's. I just got a XERUN 120A Version 2.1. Does this ESC have a blinky mode and if it doesn't can I download an update that will allow me to have blinky mode? Any suggestions on gearing for 17.5. Right now geared at 3.8 with a Reedy Sonic.
Thanks in advance!
Max
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 05-13-2013, 01:21 PM   #10911
AdrianM's Avatar
Originally Posted by maxepower View Post
Hey guys,
Thanks in advance!
Max
Yes, you will need to get an LCD programming box (~$30US). Then download the Hobby Wing USB Link software from their site.
Up date your LCD Box then update the firmware on your speedo to V3_508 no timing. This sets your speedo into blinky only operation.
Your gearing will be the same as with any other blinky speedo so run 3.8 as a start.
Adrian Martinez
Old 05-13-2013, 02:35 PM   #10912
Hello. I've downloaded V3.3, database version 130513, but it's still showing up as database version 130511. Is that right or have I done something wrong. It's for a V3 which has the latest 129 firmware installed onto it.
RSCosworth is offline   Reply With Quote
Old 05-13-2013, 02:52 PM   #10913
Send me your setup including your pinion gear and spur ratio.
Old 05-13-2013, 02:54 PM   #10914
Its correct ive just added a control file that allows the user to update software from speed passion old version which users have had problems switching back to HW software.
Old 05-13-2013, 03:00 PM   #10915
Cnc case top and bottom and 20 more amps continues current rating thats all is the difference between the two.
Old 05-13-2013, 05:25 PM   #10916
Madulla's Avatar
Isn't the Stock Spec half the weight of the V3.1?
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is online now   Reply With Quote
Old 05-13-2013, 11:09 PM   #10917
No its lighter but not half the weight has also smaller footprint than the cnc 120 amp 3.1
Old 05-14-2013, 06:05 AM   #10918
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
would be interested in the outcome as well. as i have similar troubles with a thunderpower 4.5T geared 1:8,0.
punch 10-12
boost 15 (15000 - 60000)
turbo 0.1s delay (20 deg)
Infinity -- Orion ESC -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
Old 05-14-2013, 07:22 AM   #10919
TryHard's Avatar
punch 10-12
I would strongly suggest dropping the boost end RPM, to closer to 30,000, and adding more of it. 60,000 you'll only ever get close too at the end of the rev range, by which time it's doing diddly squat, as the turbo would have taken over by then (very very very unlikely you'll hit 60,000rpm without getting full throttle basically).
As a good baseline, have a look at the worlds settings from Andy Moore (here) that are up on the Hobbywing site. Very good reference points to use, and what I base my settings on, although need to be a little different due to the rather grunty ProAmps motor's I'm using.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 05-14-2013, 09:27 AM   #10920
IIGQ4U's Avatar
Are there any performance differences or is it mostly hardware related?
