Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 04-05-2013, 11:40 PM   #10786
COBRARACING's Avatar
Originally Posted by hyujmn View Post
So then what's the fix for someone who doesn't want to change radios, receivers, motors, and servos just to get an ESC with brakes?
Obviously, Angelo, there is an issue here. It's not like it's a single occurrence and nobody else has ever reported it. We've got the last 100 pages asking about the soft brakes on Hobbywing ESCs.
There's gotta be SOMETHING you guys can look at. There are so many people here talking about the soft brakes, that it simply could not be a coincidence.
I could be something simple in your settings overall.so i will do some of my own testing .
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 04-06-2013, 12:33 AM   #10787
AdrianM's Avatar
I run a HW Xerun 120A 1S speedo in 1/12 and WGT.
I had a problem with weak brakes.
I downloaded the latest USB Link app.
Updated my LCD box and loaded V3_508 No Timing on both speedos.
I set the parameters as noted in the attached text file. Its an Export from the USB Link app with my settings. You can save this file on your PC and import it into your USB Link then load it on your ESC.
I run a Futaba 4PL with a Spectrum H5020G servo and Trinity D3.5, D3 and TP Z3R 13.5 motors.
With my TX throttle and brake end points at 100% (no higher or lower) and my throttle trim centered I calibrated my ESC to my TX.
Now my brakes are strong and will almost lock up the rear wheels on my 1/12 and WGT.
Adrian Martinez
Old 04-06-2013, 02:42 AM   #10788
TryHard's Avatar
I strongly suggest doing what Adrian has done and follow his setting.... I believe there was a small change made with the 508 brakes in the V3.2 USB Link. So download and use the latest version from the latest software.
I personally don't have any issue with the brakes on my V2.1 in 17.5 Blinky TC, using the latest 508 version from the v3.2 usb link.
My settings are pretty much the same as Adrians, geared at 3.9FDR, with a D3.5 17.5, and Sanwa radio gear.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 04-06-2013, 07:04 AM   #10789
ByteStream's Avatar
+1
Yes there was a change made. Everyone that I know with a v2 based HW at the track has seen an improvement and has had no complaints.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 04-06-2013, 07:48 AM   #10790
ATLASCOPCO's Avatar
look forward to your findings as my brakes are also poor
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
ATLASCOPCO is offline   Reply With Quote
Old 04-06-2013, 08:06 AM   #10791
Trader Rating: 27 (100%+)
Ok, I will try that. I"ll need to borrow my brother's program box, because we use his for all the v2.1 ESCs we have.
Edit: One more question. For you guys that run 17.5 blinky, do you feel it's necessary to have the fan on top of your ESC for cooling? I know a lot of Orion guys that run fanless even in mod, and since Orion R10's are just Hobbywing OEMs, I'm wondering if it's necessary for my ESCs
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 04-06-2013, 10:53 AM   #10792
Hello,
can you tell me what's the latest USB Link Software I can load on my LED program card? Can I use version 3.2 as long as I make sure that I don't use the 211 Stock Firmware?
Thanks for your help!
mp4-18 is offline   Reply With Quote
Old 04-06-2013, 02:26 PM   #10793
Originally Posted by mp4-18 View Post
Hello,
The 3.2 usb link will not allow you to download any other software to your esc but only whats available for the esc you have just plugged in .It will give you only those options say for the v3 or the 2.1 etc so there is no chance of making a mistake.
Old 04-06-2013, 02:28 PM   #10794
I suggest always run a fan becauseca cool esc is a better performing and efficient esc.
Old 04-06-2013, 02:32 PM   #10795
Never run your radio above 100% of end points especially for throttle yhis will give you issues with brakes some radios like futaba have settings up to 120% which some racers think it will give you more puncj out of the corners no it wont it will just give you problems with esc nothing more .
Old 04-07-2013, 08:33 AM   #10796
TCCustoms's Avatar
what is everyone using to to unzip the 3.2 .rar file that is FREE?
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 04-07-2013, 09:06 AM   #10797
WinRAR or 7-Zip
Old 04-07-2013, 09:54 AM   #10798
TCCustoms's Avatar
WinRAR or 7-Zip
is 7-zip something on windows 7? Thats what i run and if so i didnt kno there was something to unzip...
EDIT: Just downloaded it and used it in less than a minute to open the 3.2 USB Link software....Awesome, thanks!
Old 04-07-2013, 01:33 PM   #10799
Default New v3.1 problem
I have a problem with my new v3.1.
The power button is not working. As soon as I plug it in the fan comes on and I have steering and power with a solid red led lit. When I press the power button to turn it off the led goes out, fan is still on still have steering but no power. When I hold break for 5 seconds to power it off I lose power but bot steering and the led goes to a solid green.
Any help greatly appreciated.
On a side note the esc is a week old and this is my first race weekendwith this esc.
ATXPro4 is offline   Reply With Quote
Old 04-07-2013, 05:08 PM   #10800
Control board issue .Send it back from were you purchased the esc from for a replacement.
