Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 03-14-2013, 06:41 AM   #10681
COBRARACING's Avatar
Originally Posted by Dnnap View Post
Cobraracing, do you know if there is a resolution to the Xerun 150A ESC sensor error?
I've tested two ESCs with 3 different motors and 2 different sensor wires and at about half throttle the red and green lights flash, which I believe means a sensor error. All three motors and sensor wires work fine in sensor mode on a RX8 and MMP.
The motors I've tested are Hobbywing 2000kv, Tekin 1900kv and Tekin 2250kv
Lipo used for testing, 4S 5000mah 40C
That can be a sensor error or a drop in bec voltage.When you reach half throttle does the rpm drop ? Like a delay then kicks in again?
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 03-14-2013, 07:46 AM   #10682
Dnnap's Avatar
Trader Rating: 37 (100%+)
Thanks for your reply, its greatly appreciated!!
It depends on the esc settings used. If I use the default esc settings the throttle reacts as it should, seamless without lag or rpm drop. If I use lower timing and or lower punch it will lag. For example, if the timing and punch are set lower than default there is a lag to the rpm. As the throttle approches around half throttle it will jump in rmp as it kicks out of sensor mode.
Also, please keep in mind, I've tested these ESCs with and withhout an external CC 10A BEC without change to this sensor error.
Dnnap is offline   Reply With Quote
Old 03-15-2013, 01:20 PM   #10683
hi angelo, i send you an email for info on 8.5T. Thanks for help
up
up
puma303 is offline   Reply With Quote
Old 03-15-2013, 07:18 PM   #10684
Send me an email at teamcobraracing@gmail.com and we will sort it out for you.
Old 03-15-2013, 07:29 PM   #10685
Anyone needing tech support at the cactus classic in Az please see Ron Schuur from Schuur speed for help with Hobbywing esc's
Old 03-15-2013, 07:50 PM   #10686
Old 03-17-2013, 07:02 AM   #10687
Dnnap's Avatar
Angelo, e-mail sent.
Thanks,
Dan
Old 03-17-2013, 05:51 PM   #10688
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
i would love to see a increase in the throttle adjustments higher then 30 also a setting for roll in blinky i had another brand speed control i tested that had frequency adjust and had so much rip in the infield compared to the v3 i ended up programing the v3 with 100 epa and raising it to 120 after and it has much more rip off the corners but those changes would make a big difference
Warren Weaver is offline   Reply With Quote
Old 03-17-2013, 11:55 PM   #10689
We will look into it but i make no promises as to increase the punch point levels will also mean higher c rated batterys and that were our headache will start with uses having issues.
Old 03-18-2013, 03:51 AM   #10690
hi ... I want to know if I would have the benefits of replacing the pair of external capacitors on my v3 with a capacitor of 4700 uF and 10V or if it is simply a feasible operation that does not involve malfunction or breakage. Thanks for the reply.
Old 03-18-2013, 05:11 PM   #10691
Must be low esr to have any benefit.
Old 03-18-2013, 05:44 PM   #10692
Hi,
Any recommendations on setup for the v3 speedo paired with a thunder power 13.5T? Running boost class.
I am currently using an ORCA 13.5 with:
Boost timing: 40 degrees
start rpm: 2000
end rpm: 13000
slope: linear
controlled by: throttle
Turbo: 28 degrees
Start rpm: 14000
Engage slope: 28 (i think)
Disengage slope: 24
Activation: full throttle
sammies is offline   Reply With Quote
Old 03-19-2013, 02:17 PM   #10693
Originally Posted by sammies View Post
Hi,
start rpm: 2000
end rpm: 13000
slope: linear
Turbo: 28 degrees
Start rpm: 14000
Disengage slope: 24
your combined boost and turbo is more than the speedo offers (64 max)
2000 rpm seems very low for a 13.5
13000 rpm seems low to end at, but the range is ok (11k rpm)
try bringing them both up something like 5k to 16k for example.
CPD Racing
chris_dono is offline   Reply With Quote
Old 03-21-2013, 01:24 AM   #10694
Hi,
start rpm: 2000
end rpm: 13000
slope: linear
Turbo: 28 degrees
Start rpm: 14000
Disengage slope: 24
Please send me an email and i will forward a setup for you.
Regards Angelo
Teamcobraracing@gmail.com or ae@hobbywing.com
Old 03-21-2013, 04:40 AM   #10695
AGNO's Avatar
Default Endbell with timing adjust,for Hobbywing motors.
Endbell with timing adjust,for Hobbywing motors, +15 deg, more RPM (+10.000), more power, best use for NO timing class
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
