Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 03-01-2013, 05:11 AM   #10621
All the settings are factory in blinky. I have reached impossible then. I can use the program box and go to modify setting. Turn off the esc back on and works smooth. Go to blinky no good. It works in every mode but blinky.
Huskerfan1212 is offline   Reply With Quote
Old 03-01-2013, 05:13 AM   #10622
Everything is done with the box mode two zero timing. Run thro the settings fast to make sure its all factory. Unplug the box. And the motor cogs.
Old 03-01-2013, 05:13 AM   #10623
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Originally Posted by TryHard View Post
I think the issue that you can't down grade is because your LCD box is (now) on V3.1. Try putting it back to the V3.2, and then try downgrading the software.
If you want to do the ESC properly (and I know this works, as I've done it a few times on my esc) then you need to do it in the right order, especially if your at the latest software already... have a look on page 705 of this thread, myself and j.d.roost discuss downgrading to an older version.
Page 705
But in short, if you have V3_121129_beta on the ESC, then you need to use the V3.2 USB link, and downgrade to 'V1.1_120526', then switch to the V3.1 USB link of your choice.
HiH
Ed
Any news of the roar approval for the new software?
Do you guys think it will be approved by the indoor nats (March 13-17)?
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 03-01-2013, 05:35 AM   #10624
TryHard's Avatar
What motor is it, and how much endbell timing are you using?
My D3.5 17.5t does stutter a little on start-up in blinky, mainly as I have the endbell timing cranked to maximum. Doesn't effect the car on track mind, so I just live with it.
Old 03-01-2013, 05:55 AM   #10625
If i where to live with it my car would not go anywhere. The motor will only run if i only slightly pull the throttle. I mean just touch it. Any thing further then that motor jumps from some rmp to none to full rmp to some rpm.
Old 03-01-2013, 06:45 AM   #10626
ByteStream's Avatar
Have you tried to recailbrate the ESC recently or when you go to blinky mode?
Have you tried to run the motor with less endlbell timing to see if there is a difference?
Have you tried another sensor wire and motor? Perhaps a bad sensor board?
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 03-01-2013, 07:12 AM   #10627
Yes two motors. Both thunder power. Both with 35° timing. Like i said runs fine in every other mode.
Old 03-01-2013, 08:39 AM   #10628
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
Hey angelo i just wanted to let you know i sent you an email
thanks
warren
Warren Weaver is offline   Reply With Quote
Old 03-01-2013, 11:28 AM   #10629
Tried everything possible to get the motor to work in blinky. Lcd box set to no timing. All default settings. The esc blinks red. But when full throttle the motor nothing. Not full throttle the motor jumps around in apm. And also when i mean jumps around i mean no rpm to full rpm. Stupid crazy. All other modes work awesome.
Old 03-01-2013, 01:14 PM   #10630
Page 705
HiH
Ed
tanks for your help i have done its now on v1.1_120511. One question what´s the last firmare aproved for v3
pauper is offline   Reply With Quote
Old 03-01-2013, 01:19 PM   #10631
ByteStream's Avatar
v1.1_120511_beta
I was told the latest has been submitted for ROAR approval .. but don't know a timeframe.
Old 03-01-2013, 01:28 PM   #10632
v1.1_120511_beta
tanks
Old 03-01-2013, 10:07 PM   #10633
TryHard's Avatar
Have you tried backing the motor timing down? Honestly, thats the only thing I can think of at the moment..
Also, what version of the software is loadded on your esc (I might have missed this already though!)
Old 03-02-2013, 06:39 AM   #10634
Im not 100% sure. Whatever it had on it when i too it out of the box. Is there software should i have?
Old 03-02-2013, 07:16 PM   #10635
TryHard's Avatar
Ok, given it seems to be a weird issue (and I know you've checked a lot), but doing the following.
1) check all the wires on the ESC side, make sure there are no short's across the posts (I'm ruling out shorts on the motor side, as you say you've tried two different motors)
2) If your not running at a place that strictly follows ROAR rules, then update the esc to the latest software. To do this, download the latest V3.2 USB link from the Hobbywing site, and then put the ESC to 'V3.2_121129_beta' and then set to the Zero Timing mode.
3) Back down the motor timing. You haven't mentioned if you've tried this yet, and I strongly believe this will be part of the issue.
Give those a test, and let us know what happens.
Ed
