NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
can't seem to enter program mode
hey
can some one let me know what I am doing wrong.
1. Turn on Radio
2. Hold Set button
3. Turn on ESC
4. While holding set button ESC beeps while red light flashes.
5. The green light flashes 3 times (every time), let go of the set button,& thats it.
6. after that you can press or hold the set button nothing happens.
7. it appears to be back in normal operation mode
1. Turn on Radio
2. Hold Set button
3. Turn on ESC
Have you tried reversing your throttle?
Hey
yeah tried that.
I actually bought the v2.1 also.
so just hooked it up & it it works ok. so I am doing it right.
I had a good look at the lights this time & when the green blinks, its three time back & forth with the red & the motor dosent make a noise.
it might be no good.
any other ideas let me know
thanks
yeah tried that.
thanks
Hey
yeah tried that.
thanks
yeah tried that.
thanks
Either way, make sure your doing it this way.
1) Turn on Radio, make sure all EPA's are at 100%.
2) Plug in battery, press and hold set button, and turn on ESC (for V3, just press and hold power button).
3) When esc starts to beep and flash red, release the set button
4) Leave throttle at neutral, and press set button once. ESC will beep once, and flash green once. Neutral is now set.
5) Push Throttle full foward, and press set button once. ESC will beep twice, and flash green twice. Full forward is now set.
6) Push throttle full back, and press set button once. ESC will beep three times, and flash green three times. Full brake is now set.
7) Turn ESC off and back on again to ensure settings take.
HiH
Ed
V3 setup with LRP Stock Spec 13.5 Required
Hey Guys and Girls
Urgently require setup for one of my club members.
Current FDR is 3.75 running in Xray T3-R
Any help with much appreciated.
3.75?!?!?!?! is that blinky or boosted? Either way, thats sounds quite a bit overgeared, especially for a LRP (put it this way, on my D3.5 17.5T, I'm on 3.86 FDR)
So this is on a V2.1? Not a V3 right?
HiH
Ed
HiH
Ed
but setting foward, neutural, reverse is ok, it gettting into the programing that doesn't work.
cheers
What software do you have on the V2.1? Or is it new from the box? Note, you can't use the ESC programming mode with a ESC software that uses 15 programmable items, you need the program box to do it. I'm not sure what software a new from box ESC comes with... but I would hazard a guess that you can't do programming with it on the ESC.
Having said that, I just tested out on my V2.1 which has V3_508 loaded on it, and I can get the programming mode to work fine... (although that has only 10 items)
Ed
Regards
Ed
Honestly, flick the ESC to the standard 13.5 setup provided (plug in the program box, and press the r/p button to change the profile), and go from there. Difficult to suggest rest of the settings, but that will be a good starting point.
Regards
Ed
Regards
Ed
thanks I have orderd the program box,
I bought two esc's the s1 & the v2.1 last week
The v2.1 will program straight out of the box but not the s1,
it seem to run ok though,
so i think your right I just need the program box.
cheers
Tim
Hi all. Has anyone played about with the custom boost slope rate yet on the v3 program 129?
Any word on a new 1s controller yet?
