Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 01-30-2013, 02:03 AM   #10516
JonboyGB's Avatar
Hi all, I'm going to be racing 17.5 blinky for the first time soon at new club. Never raced blinky before.
I have a HW v3 and will be getting a GM 17.5.
What's a good starting FDR for indoor carpet on a small to medium size track?
Do I turn up the timing on the motor or leave as is?
Switching the speedo to blinky is fine, but do I need to change any of the settings for best results or leave as is?
JonboyGB is offline   Reply With Quote
Old 01-30-2013, 03:32 AM   #10517
aSab's Avatar
independent of the esc, you'll most likely find out all other pple cranked the timings of their end bells to max for blinky.
aSab is offline   Reply With Quote
Old 01-30-2013, 04:38 AM   #10518
TryHard's Avatar
Originally Posted by Holmenkollen View Post
Thanks! I will try it. What ESC temps are you getting with this seetting? What is considered to be ok?
Honestly, I don't check. Using the ESC temp cutoff, if it doesn't stop, it's ok I figure
Old 01-30-2013, 10:02 AM   #10519
sbrewer's Avatar
Trader Rating: 20 (100%+)
Just trying to find some gearing help for my WGT and 17.5 1/12 . I'm running the HobbyWing 13.5 in the WGT and the HobbyWing 17.5 in my 1/12. track is small 35x45
- AKA - Team Associated - Dark Side RC Racing - Os Speed - Jc Designs - Futaba - Boca Bearings-
sbrewer is offline   Reply With Quote
Old 01-30-2013, 12:02 PM   #10520
sosidge's Avatar
If you are in Swindon, which club are you going to? As it might be one I know.
Generally, ESC set to maximum punch, brakes to whatever you like, try and avoid drag brake as it generates heat in the motor and 17.5 is about getting the most from the motor.
You'll find that most people are running some motor timing advance, you don't need too much because pretty soon you get to the point of generating more heat than speed. If yours is the latest GM, two or three notches advance should be in the ballpark. Ratios on a very small track might be in the low 4's (4.3-ish), on a medium track in the high 3's (3.7-ish). Better to start safe than cook a motor.
Old 01-30-2013, 02:30 PM   #10521
AdrianM's Avatar
Assuming you are running blinky....
Crank the timing up on the motor. Start with a 75mm roll out (for a small tight track) in 13.5 WGT and 85mm in 17.5 1/12. Check running temps after 2min of hard running. Gear up until the motors get into the 135-155deg F range.
Run the No Timing 508 V3 firmware. No drag brake, 9 on the DDRS punch setting. Disable temp and voltage cutoffs. Run 100% brakes.
Adrian Martinez
Old 01-30-2013, 03:24 PM   #10522
Aravan's Avatar
Originally Posted by Aravan View Post
Anybody got a good base setup for a 120A 1s with a D3.5 17.5t boosted in a 12th scale indoors? Guessing 930stock will be the best firmware to run?
Anybody?
Aravan Eagleheart
Corvictoria.com
//Schumacher: Cougar SVR, SV2, Cat K1//Losi SCTE 2.0//Kyosho SC-R SP//CRC XTi//
Aravan is offline   Reply With Quote
Old 01-30-2013, 04:04 PM   #10523
COBRARACING's Avatar
Originally Posted by LOW ET View Post
so this place is not legit anymore? http://www.falconsekido.com/
Falcon sekido is a distributor not a brand or a manufacturer.They distribute for hobbywing in the usa along side CRC
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-31-2013, 02:34 AM   #10524
M7H
M7H's Avatar
Anybody?
The default settings from the firmware is a nice starting point.....
Did you try that already?
Asking and just copying someone else his setting, is not the way to get faster....
Feel yourself when changing a setting what happens, and go from there.
Serpent
M7H is offline   Reply With Quote
Old 01-31-2013, 05:28 AM   #10525
sbrewer's Avatar
Do you run hobbywing motors?
Old 01-31-2013, 06:30 AM   #10526
AdrianM's Avatar
No but this is a safe place to start for any motor. You will certainly need to gear up from my recommendations.
Adrian Martinez
Old 01-31-2013, 09:47 AM   #10527
Hi Guys,
I want to know if it's ok to install HW software for V3 in to my Speedpassion GT2.0 Pro?
If I connect my SP to HW USB Link V3.2, it shows that my Speedo hardware is HW427_V1.0.
Vidra is offline   Reply With Quote
Old 01-31-2013, 09:56 AM   #10528
sosidge's Avatar
Originally Posted by Vidra View Post
Hi Guys,
No, the SP is a V2 based ESC, so you cannot use the V3 software.
However there is another software within the v3.2 USB package that can be used on the SP. I have it on mine.
Old 02-01-2013, 01:00 AM   #10529
Ok, now I am using V3.0_110323STOCK from SP.
What is the equivalent or better from HW that I can use?
Old 02-01-2013, 03:27 PM   #10530
Smile HOBBYWING of North America
Just to clarify to everyone. Have contacted to Hobbywing directly.
HOBBYWING of North America (HWNA) is the representative of HOBBYWING technology. HWNA is managed by FalconSEKIDO who is the executive distributor in North America. CRC belongs their dealer network.
You can also check directly at HOBBYWING website under 'distributor list' as well as the direct link provided at HW's front page.
They said that they are preparing the authorized dealer list in NA.
Hope this helps,
d_hob is offline   Reply With Quote
