Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 01-23-2013, 12:13 PM   #10486
Hi i want to run my supastox in open class , what pinion size and esc software and settings for a small ish carpet indoor,
motor 13.5t speed passion
hobbywing exrun 1s 120a
1s lipo
70t 48dp
49mm dia rear foams
thanks
darrenheli is offline   Reply With Quote
Old 01-23-2013, 03:34 PM   #10487
Radio Active's Avatar
Originally Posted by M7H View Post
Maybe you have a lot of exponential set on the brake side on your TX?
I always set throttle and brake exponential to zero before I set the ESC. Otherwise I don't get a clear idea of what the radio settings mean from race to race. That's the same reason I always set the ESC to 100% brake and 100% reverse when I load new software.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 01-23-2013, 11:25 PM   #10488
Well something odd happened today. Was just working on my car when all of a sudden a puff of smoke & a nasty smell from around the esc. When i noticed the smell/smoke I immediately pulled the lipo connection. I noticed one of my two capacitors fried. Puffed up & popped.
No idea how so I triple checked all my wiring & it's correct so don't know what caused it. As soon as it happened the green light on the esc started blinking which I assume was "overheat protection mode." I removed the one bad capacitor & went back into normal running mode.
So my question is it safe to run with one capacitor while I wait for my replacement to come in? I went through all the functions & everything is working properly.
UberPare is offline   Reply With Quote
Old 01-24-2013, 12:56 AM   #10489
blade072's Avatar
Trader Rating: 98 (100%+)
though not recommended...you can run them without the capacitor bank....i had something worse than that happen.....last year i had not only the capacitor bank blow, but had not only the esc fan smoke up, but a motor one aswell.....came home changed the caps and fan....good as new but am using it as my backup esc....it all happened after a huge shunt with a mod car...
David Randall
AWESOMATIX A800 ★ MUCHMORE ★ R1 WURKS ★
TEAM XRAY X116 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 01-24-2013, 07:49 PM   #10490
COBRARACING's Avatar
Your cap would have burnt to save your esc as it seens either your motor was producing massive ripple current causing heat or your battery would have had a large voltage spike .
replace your cap dont run your esc without one .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-24-2013, 10:33 PM   #10491
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
hi cobra,
any idea where i can get the wire hayness for the Hobbywing motor checker??
Give the best while u can !
kschu is offline   Reply With Quote
Old 01-26-2013, 03:03 PM   #10492
AUSCAN's Avatar
Hi Cobraracing. Could you please check your pm.
Serpent Eryx 2.0
Serpent Eryx 3.0
Serpent 977E
Walter RC Hobby
AUSCAN is offline   Reply With Quote
Old 01-26-2013, 07:00 PM   #10493
ta04evah's Avatar
Tony, send Cobraracing a email instead of a pm, you'll get a quicker response.
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 01-26-2013, 07:19 PM   #10494
TCCustoms's Avatar
Cheers
Rob.
+1
If you follow the thread he tells you that he doesnt like the PM system and tells you to email him, even repeatedly if you have to or post here and he can reply or someone else can help out as there are alot of knowledgeable people on here
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 01-27-2013, 12:55 AM   #10495
Please help...
I downloaded and upgraded to the newest USBLInk V3.2.
I then upgraded my LCD box but I selected the wrong firmware, I have got V1,1_120301_V3 displayed on the screen but I only make use of XeRun's V2.1 ESC's.
I need to downgrade to the correct firmware on my LCD Box but now my PC doesn't recognize the LCD box any more.
I have un-installed all HobbyWing versions from my PC, re-installed V1.62 run the installation app as "Administrator"
When I plug in my LCD Box is still says unrecognized device.
Strange thing this only started to happen after upgrading to V3.2 and flashing the V3 software on the LCD box.
How do I go back to a previous version on my LCD box if my PC doesn't pickup it up?
SeanV is offline   Reply With Quote
Old 01-27-2013, 01:28 AM   #10496
AUSCAN's Avatar
Cheers
Rob.
Thanks for that Rob.
Email sent
Cheers
Serpent Eryx 2.0
Serpent Eryx 3.0
Serpent 977E
Walter RC Hobby
Old 01-27-2013, 03:36 AM   #10497
Originally Posted by SeanV View Post
Please help...
Nm it was my USB cable that went faulty.
Tried a new one and all is good again.
Old 01-27-2013, 03:52 AM   #10498
Johnny-RC's Avatar
Trader Rating: 24 (100%+)
By Mid FEB 2013 this problem with the lcd box upgrades and down grades will no longer be an issue with the new 3 in 1 programmer i have been testing this unit now for a few weeks and its very very good hold v3 and v2.1 etc firmware in one unit plus it also features a lipo voltage checker built in
so guys i know its been a long time waiting but it all had to do with the control files of the software that michael would not open for all access for various reasons
Angelo, is this the box you are speaking of? So with this box you can program both the V3 Xerun and the V2.* Xeruns with one box?
http://www.falconsekido.com/products/lcd-program
Will it allow the storage of firmware on the box for say flashing from the blinky 508 firmware to anyother firmware? I remember awhile back you had mentioned this was a feature in the works, (or something similar) but that kinda never came up again.
Products I run
| Hobbywing | Gens Ace | Highest Servos | Sanwa | Team Associated | AKA |
Johnny-RC is offline   Reply With Quote
Old 01-27-2013, 07:48 AM   #10499
TCCustoms's Avatar
That must be the new box since i have the LCD box and it does not have the battery checker which i do like the idea of but i to would also like to know if you can have multiple software versions on the box to be able to change to(only need it to do it on 1 of my ESC's since the SCT Pro doesnt have any other software)
Old 01-28-2013, 01:38 AM   #10500
Holmenkollen's Avatar
Anyone with a good V3 setup with SP 4.5t? Indoor carpet. Im lost in the setting jungle....
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
