Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 05-03-2010, 06:27 PM   #91
Send a message via MSN to hobbywing Send a message via Skype™ to hobbywing
Originally Posted by Nemo racing View Post
Hi hobbywing
I try downloading the software but every time I try to open it
it will say file corrupt
Can you send me the file or can you post the link to the download site
Thank you
Hello, Nemo racing
We downloaded and decompressed the rar file from several different PC, and it was OK.
I think that the problem may caused by the different version of compression/decompression software. We use WinRAR software to compress the files, and a WINRAR Ver 3.3 or later software is recommended to decompress the rar file.
Please try, thanks!
hobbywing is offline   Reply With Quote
Old 05-03-2010, 07:40 PM   #92
smilekt's Avatar
try this 7 Zip ... can compress & decompress all type compration
http://www.7-zip.org/download.html
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 05-04-2010, 12:44 AM   #93
What would be a good starting FDR and settings for a TC5F (racing super stock class) using the 422 software with a novak 13.5 ballistic.
I run on a very tight indoor astro turf track with medium grip.
I was running the 110 software with standard spur and 30 pinion. I was down on top speed on the straight. the top guys seemed to fly past in the last 1/4 of the straight. (this was the first time I used a hobby wing ESC)
Im hopping this new software will fix this problem.
Also a FDR for a 5.5 ballistic using 323 software in a TC5F (racing mod class) and any settings you can recomend. Once im used to this motor I have a X12 4 turn to step up to.
I have just changed over from GTB's so new to this adjustability.
Any help is gratefully appreciated.
kiwi79a is offline   Reply With Quote
Old 05-04-2010, 12:54 AM   #94
defcone's Avatar
Trader Rating: 15 (100%+)
I used a 8 FDR with 230MOD software with a 5.5t LRP x12 motor with 3 hole timing block, (4 is max retarded timing). Running max timing and 3 DRRS on the ESC.
People running 13.5t have been achieving nice speed with default setup with recommended gearing.
defcone is offline   Reply With Quote
Old 05-04-2010, 02:18 AM   #95
Hi there,
First of all i wanna say is I've tried the SP 231 SCbeta and the HW422 turbo beta on my xerun 60A. The only thing for the Xerun was the threhold and i set my lipo cut off at 3.2v in which it start slow down my car at 3.6x something V. It is so annoying me. Well, i'm didn't said the 422 beta not good enough but i prefer the SP231 far more than the 422.
The HW v2.0 422 once it used, then i can't go back to use the v1.1_100231 version but then i change back the HW beta into 323a , once update to the esc then i put back the 231 file in my esc. It's good to try both s/w.
silvavisil is offline   Reply With Quote
Old 05-04-2010, 03:08 AM   #96
Born2Run's Avatar
Originally Posted by silvavisil View Post
Hi there,
Stay with the SP231 then if you prefer this.All the others we are using the HW422.
Whatever
Born2Run is offline   Reply With Quote
Old 05-04-2010, 07:31 AM   #97
Couple of questions for anyone who can answer them...
I have the 'old' speedpassion software on my computer. Can this co-exist with the new hobbywing software?
Can I go back to an 'old' profile in my speedpassion software if I so desired?
Does the update done to the LCD card affect its use with any older profiles?
Thanks in advance, Thomas
thomas ridgley is offline   Reply With Quote
Old 05-04-2010, 07:38 AM   #98
Jochim_18's Avatar
What Xerun version are you guys using for stock 17.5 or 13.5?
Hobbywing Xerun 60AMP or 120AMP which one for stock? I'm pretty sure you can get away with the 60AMP version.. Let me know guys thanks
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 05-04-2010, 07:52 AM   #99
LOL this is getting very funny now. I was about to ask the same question. Apparently, the 60AMP is all you need but I really want to make sure like you. This is the new ESC OF THE MONTH. Who's next!
Soon there will be wizzkids employed 24/7 for every esc manufacturer seeking that extra 'boost'. (If there isn't already!) In order to get the honoured 'ESC OF THE WEEK' award.
maxg123456 is offline   Reply With Quote
Old 05-04-2010, 08:18 AM   #100
Xerun-60A is OK for the 0422stock firmware. But obviously a XERUN-120A ESC is better.
Old 05-04-2010, 08:29 AM   #101
Jochim_18's Avatar
Is their any noticeable power gain between 60AMP and 120AMP version?
It's like the Tekin RS and RS PRO... you only need the RS PRO if you are running MOD... But for stock Tekin RS will do it's job without any power loss.
Old 05-04-2010, 08:33 AM   #102
I think the difference is: XERUN-60A ESC has a little bigger resistance than XERUN-120A ESC. That means the power loss at the XERUN-60A ESC is also a little larger. But the power loss at the ESC is really very very small, so who cares?
Old 05-04-2010, 08:37 AM   #103
Jochim_18's Avatar
Thats what I thought the only difference is the resistance but you can't really tell when running the car... Oh well for $80 I'm in I'll order mine ASAP and give it a try and see if it's PAR with TEKIN, LRP, MMP....
Old 05-04-2010, 09:45 AM   #104
AGNO's Avatar
I confirm, I have both ESC Xerun 60 and 120, with 17.5 I did not notice appreciable differences in performance.
You can get information on the use of value 4 # Start mode (punch) with FM422?
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 05-04-2010, 10:04 AM   #105
Can someone tell me if i got this right...
You need the advance LCD box to update the firmware + the LED box to change the settings. Is that right? Couldn't you just use the advance LCD box for everything?
Thanks!
g26er is offline   Reply With Quote
