Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 01-14-2013, 02:26 AM   #10411
Default Setup for TITC 2013
Hi Guys...
I'll playing 13.5 open brushless on titc this february...
I'm using xtreme esc....
any of you guys have a good base setup for this track....
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 01-14-2013, 12:17 PM   #10412
fast and detailed support answer from cobraracing
If you have a problem, the best way is to contact cobra by mail.
Manson is offline   Reply With Quote
Old 01-15-2013, 06:39 AM   #10413
Hi CobraRacing,
What is the difference between V3.1 and V3 for the 2S??
Serpenteer is offline   Reply With Quote
Old 01-16-2013, 07:57 PM   #10414
I have email cobra...asking for a setup for titc but until now i did not receive any replay from him
Old 01-16-2013, 11:06 PM   #10415
Still Bill's Avatar
Originally Posted by Serpenteer View Post
Hi CobraRacing,
That V3.1 is 1S specific. Has a built-in booster and capacitor for single cell racing.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 01-16-2013, 11:55 PM   #10416
ta04evah's Avatar
The one on the right is a 1 cell version with those additions, but the one on the left is a 2 cell version as if you look closely it has a fan connection socket where the 1 cell doesn't.
I believe his question was referring to the difference between the V3 & V3.1 2 cell esc.
Cheers
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 01-17-2013, 06:41 AM   #10417
Cheers
Rob.
Yes, I was referring to V3 and V3.1 for the 2S.
Also, the manual says that "points" in ESC settings are not real "degrees". Anyone know how points translates to degrees?? I.E. 30 points = how many degrees of electronic timing??
Old 01-17-2013, 09:56 AM   #10418
lewis110's Avatar
The esc will add up to 64 steps of timing. Each step is .8* so if you have the full 64 steps you will gain appx 51 total degrees of timing.
Hobbywing of North America/FalconSekido www.falconsekido.com
Hobby-Pro USA www.hobbyprousa.com
Dialed RC Hobbies/VP Pro USA www.Dialedhobbies.com
lewis110 is offline   Reply With Quote
Old 01-17-2013, 02:08 PM   #10419
how do you the best brake setting on v3 esc thanks for 17.5 blinky
to slow for you is offline   Reply With Quote
Old 01-17-2013, 08:42 PM   #10420
COBRARACING's Avatar
The new 1s v3 is 1s only cannot run a 2 cell and has built in caps to save space
The v3.1 is a 2-3 cell esc with rubber grommets behind the sensor port and the programming port put in place mainly for off road use so no dust enters the esc it also has a raised fan of 1mm for better cooling and airflow that's all .
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-18-2013, 02:01 AM   #10421
The bottom of the case is also aluminium to improve cooling.
here are some pictures: http://www.eurorc.com/product/3391/h...0a-v31---black
www.EuroRC.com your European webshop for Hobbywing, Xray, Yokomo, Highest, TeamC, Gens Ace, Vampire, Team Associated, TLR and many more.
goos is offline   Reply With Quote
Old 01-18-2013, 03:36 AM   #10422
TryHard's Avatar
try more like 0.6... 51 added and your motor will go backwards...
| THard.co.uk | Xray | MuchMore |
Old 01-18-2013, 03:50 AM   #10423
Originally Posted by TryHard View Post
try more like 0.3... 51 added and your motor will go backwards...
Hi, is that right 0.3 per step ? I never knew that. quite use full information that is.
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 01-18-2013, 06:34 PM   #10424
TryHard's Avatar
Sorry, I meant ~0.6, hit the wrong key...
Put it this way, most motors have around 20 or so degrees of (actual) timing at 'zero', otherwise they wouldn't run. When you up the timing on the motor or the ESC, your adding to that base value. Some motors have more, some have less, but all will have a decent amount of timing inbuilt to run, regardless of can marks.
Overall, most esc's won't add more than ~36 of actual timing, regardless of what the software says, hence HW use steps of timing. Each step equating to a set amount of timing. IIRC, I believe the V3 can add a maximum of 36 of actual timing at max settings, so 64/36 = 0.56 / step
HiH
Ed
Old 01-19-2013, 06:44 AM   #10425
cyanyde's Avatar
HiH
Ed
I will use my rpm checker to figure it out. Will do tests at no loads and compare endbell timing rpm gain vs software timing rpm gain..
Stay tuned.
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
