Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 01-03-2013, 06:48 AM   #10366
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by kiwidave72 View Post
can i use a V3 in my 1/12th running a 1S on its own, or do i need to have a receiver pack as well or should i go for an 1S ESC.
You will need a Receiver pack, also need to take the red wire out of the receiver wire. Its an awesome esc for 1/12, Very smooth, heaps of power and loads of runtime We finished 1-2-3 at the Aus Nats a few months back with V3's
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 01-03-2013, 09:03 AM   #10367
Is it 121204 the latest firmware for the v3 ?
thanks
Manson is offline   Reply With Quote
Old 01-03-2013, 09:05 AM   #10368
i can select v3.1_121129_beta or v1.1_120526_beta
Old 01-03-2013, 05:11 PM   #10369
COBRARACING's Avatar
thanks
yes correct it is the latest bu you the older version to .
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-03-2013, 05:12 PM   #10370
Originally Posted by ByteStream View Post
Will it have a built in booster? (which is the most important part in a 1s ESC).
yes with built dc booster
Old 01-03-2013, 05:15 PM   #10371
The v3 can run 1s but you need to cut the red rx wire running to your receiver and run a rx battery pack or a booster
If you only going to run 1/12 pan then grab a 1s esc 120 amp 2.1v
Old 01-03-2013, 10:28 PM   #10372
Don't cut the red wire! Use a hobby knife to release the locking tab on the connector for the red wire, and shrink wrap the exposed connector. You get the same results, but alot easier to un-do in the future.
Shawn.
Shawn68z is offline   Reply With Quote
Old 01-06-2013, 05:28 PM   #10373
we are making a female to male rx adapter with the red wire missing this way you can plug and play without cutting out the red wire for 1s operation
Old 01-07-2013, 09:19 PM   #10374
Thats a great idea. Looking forward to seeing that... With Blinky stock racing so huge in the USA & Canada, could HW please fix the 508 No Timing software (Low voltage cut off, potential glitchy brakes). Its been close to 2Yrs that these bugs have been known about, and not resolved. I would like to see those FW issues finially put to rest. I was also thinking it would be nice to have a 1S Just Stock, or 1S Xtreme Stock. 10.5 and higher turn motors just dont need the power of the 120A's!
Cheers,
Shawn
Old 01-08-2013, 12:25 PM   #10375
Crashmaster's Avatar
Hi guys,
I posted in the setup only thread but seems pretty quiet!
I'm just returning to racing after a break for a few years and turbo/ boost has appeared! I'm going to be running 13.5 open and was wondering if anyone can give me some guidance on setup for a V2.1 Xerun in this spec.
I've bought the 2 in 1 programming box and updated it to the V3.2 software so think I have everything to start! To begin with I'm intending to run without boost and then I'll dial that in as I get upto speed!
Thanks for the help
Dan
Crashmaster is offline   Reply With Quote
Old 01-08-2013, 10:45 PM   #10376
Still Bill's Avatar
Cheers,
Shawn
Nice wish list items!
Cheers,
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 01-09-2013, 02:10 AM   #10377
ScottyTC4NZ's Avatar
Send a message via MSN to ScottyTC4NZ
Originally Posted by Barry_Hughes View Post
I would run a FDR around 5
boost 40
rpm start 1,500
rpm end 12,000
boost by thr No
turbo 24
turbo activation Full Thr
turbo eng 12/0.1s
turbo disengage 6/0.1s
turbo delay 0.2s
boost & turbo linear
thr punch rate switch 50%
1st stage 20
2nd stage 30
keep an eye on temp
What turbo rpm start should I use?
Jamie Scott
Onroad Race Director
O.R.C.C.C
Titan ARC R10 2013 / Blitz / Sweep / Team Titan
Titan ARC R10 Upgrade / Blitz / Sweep / Team Titan
ScottyTC4NZ is offline   Reply With Quote
Old 01-09-2013, 02:16 AM   #10378
Losiho's Avatar
The Turbo RPM Start function is disabled if you choose Turbo Activation - Full Throttle.
From page 9 of the V3 ESC manual -
Turbo Start RPM : "Note: If setting 5B is set to option 1 (Turbo Act : Full Throttle), this setting will have no effect on the turbo activation".
Losiho is offline   Reply With Quote
Old 01-09-2013, 03:21 AM   #10379
AGNO's Avatar
Cheers,
Shawn
Yes, requires new software NO timing, with more brakes for the entire series XERUN V2 and Xtreme.
We are waiting
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 01-09-2013, 04:37 AM   #10380
Benzaah's Avatar
Trader Rating: 21 (96%+)
We are waiting
Get an Orion R10. No more brake issue...
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
