Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 08-19-2010, 06:08 AM   #1021
dameetz's Avatar
Originally Posted by Akudou View Post
Cherry2Blost, was goin to tell you about my friend here who has a pink HW esc but i didnt get the chance to show it to you and now he did!!!
Specially made for me....he..he...
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 08-19-2010, 06:22 AM   #1022
AGNO's Avatar
Carbon look...
But I'd love a purple! OK Hobbywing...?
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 08-19-2010, 06:29 AM   #1023
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by AGNO View Post
Carbon look...
Buy a speed passion one, they have a purple one.
defcone is offline   Reply With Quote
Old 08-19-2010, 06:35 AM   #1024
chinaman's Avatar
Originally Posted by TRF4evr View Post
here's my extreme in my 416X ...
like the look of the aerial tube ... did you use a lighter to bend it that way?
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 08-19-2010, 06:48 AM   #1025
AGNO's Avatar
I know, but I prefer Hobbywing, perhaps like this:
Old 08-19-2010, 08:20 AM   #1026
razzor's Avatar
Whats your opinion on the GM motor Agno ?
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-19-2010, 08:48 AM   #1027
AGNO's Avatar
Excellent engine, good acceleration and good top speed with std rotor (12.3 mm), develops a little more heat Novak Ballistic at equal timing (0 )
Possibility to replace the rotors to adjust the performance,12 mm, 12.3 mm, 12.5 mm
Good price.
(Very similar to the basic construction at the Xerun or Feigao)
Old 08-19-2010, 08:50 AM   #1028
dameetz's Avatar
Is it available now with that colour?
Old 08-19-2010, 09:07 AM   #1029
AGNO's Avatar
Unfortunately no, it was present in the 2009/10 catalog as "purple fascnation edition", but never put on the market.
Old 08-19-2010, 01:37 PM   #1030
xrayal's Avatar
Originally Posted by darrenoakley View Post
Now that looks good for the UK winter instead of carpet. Are they doing Touring cars ?
Keep us posted on the weekends events mate.
just check out mkrctc.com
in the mean time, heres a link to wot we get upto at my mates place its not rc but it is racing. check out the other messy modellers videos...........
http://www.youtube.com/watch?v=j-0q-...eature=related
tamiya 416x
hobbywing
spektrum dx3r
mardave
xrayal is offline   Reply With Quote
Old 08-19-2010, 04:35 PM   #1031
Default Starting Setup
Hi Guys,
I need some advise on an initial setup to start testing with my HW120a V2. I originally had a Novak GTB / Speed Passion Fiegio 17.5 with 3.36 FDR in a TC4 FT & was consistantly at the front of the pack till some guys changed to Tekin RS speedy's.
Our track is very fast & flowing with a couple of tight sections.
I was happy with the punch of the GTB through the windy sections but these Tekins would wind up & go past me down the straight like i was standing still once their turbo kicks in.
Any feedback or starting points for Software & Settings would be much appreciated.
Shadow5t is offline   Reply With Quote
Old 08-20-2010, 01:54 AM   #1032
Originally Posted by Shadow5t View Post
Hi Guys,
If you're running a 17.5 Feigo then try this
RPM start - between 3000 and 4500
Boost timing 8
Timing Punch -4 or -3
Turbo delay - 0.2
Turbo - Max
DDRS - Between 7-9
FDR - between 5.50 - 6.00
Should be smooth and quite fast
maxg123456 is offline   Reply With Quote
Old 08-20-2010, 06:08 AM   #1033
Send a message via MSN to geubes
Boost timing 8
Turbo delay - 0.2
Turbo - Max
DDRS - Between 7-9
+1
thats a great place to start, more towards 6.00
geubes is offline   Reply With Quote
Old 08-20-2010, 04:23 PM   #1034
Originally Posted by stoichpower View Post
Hi all,
The only different I can see between HW518Stock and SP528Stock are:
HW518Stock
- lowest start RPM is 3000
- max motor timing no.9 can only go up to 21degree
SP528Stock
- lowest start RPM is 4000
- more higher timing than HW as it can go un til 26.25degree
Why people said that both are the same?? SP528Stock better?? Which one can go more Faster??
Myself been using HW120a V1 for 2months now. Last time using HW422Stock got no problem but until I change to HW518, my motor always go sensorless and need to calibrate several times due to no brake. No wonder the is still people here that using HW120a still using HW422Stock.
In the forum, people said it might be the sensor board on the motor got problem and need to change the motor. That time got no money yet so just change to 3 new sensor cables (same thing occur), download the software more than 10x (same thing occur) then lastly try to use SP528Stock software with no problem at all until now with the same motor and old sensor cable.
Why this thing happen????? HW is a manufacturer for SP but why SP software better as the programmer is the same guy???
Today I buy a new spare motor and test it again with HW518Stock but same thing happen. Try also my friend's new Tekin motor but same thing happen.
Try again this both 2 new motor with SP528Stock no problem at all.
Why.... Why.... Why...?????
Took this HW518 software from several guy inside this forum including Cobra. Same thing problem...???
Several of my friends using 120a had decide to use SP528 as not only me facing the problems... Infact we had already tried both software side 2 side with same car and setup and ratio and the results SP528Stock have more top end and not giving us any problem.
Thx.
Why nobody help to answer and give some advise?
stoichpower is offline   Reply With Quote
Old 08-20-2010, 07:34 PM   #1035
JKL1031's Avatar
I should be purchasing a LCD, xerun 60A v2 and 5.5t combo tomorrow.
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
