NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
Hi Guys
The usb link is now available to download from the hobbywing website
http://www.hobbywing.com/product_show.asp?id=218
we havent included the carbon look at this time around the background of the control icons we are working on it will take another 2-3 days to complete so you have a choice you either wait and download later in 2-3 days or you just down load the it now its only the artwork it doesnt affect the program functions at all .
Moderator
By Mid FEB 2013 this problem with the lcd box upgrades and down grades will no longer be an issue with the new 3 in 1 programmer i have been testing this unit now for a few weeks and its very very good hold v3 and v2.1 etc firmware in one unit plus it also features a lipo voltage checker built in
so guys i know its been a long time waiting but it all had to do with the control files of the software that michael would not open for all access for various reasons
Not to tout Speed Passion on this site but I put 1.11 software on my Speed Passion box found out later this would not work with the 2.1 ESC's & software. So I simple reprogrammed the box with 1.08 software without an issue. I would think the Hobbywing boxes would be the same.
Clegg,
The 3 in 1 is new hardware. The current boxes do not have the internal capabilities to do 2 different versions of software.
Clegg,
I noticed some problems after installing the new software 3.2 on my pc:
- The program box sometimes is blocked, it seemed as turned again between items
- The program 3.2 on my pc did not boot quickly and not close properly
- Sometimes I could not change the parameters from the PC
it is also true that I still had 3.1 installed on my PC, now I uninstalled 3.2 and left the old version and everything seems to work properly as it once was. Have you had similar problems?
have posted in elec off road thought i'd put it here as well . cheers
Originally Posted by gogi108
hi all , i recently bought a secondhand 2.1 60amp and its got some problems , hope someone has some ideas what it might be . what happens is it seems to have a delay in throttle and steering signal intermitantly but regular . hard to pinpoint but it feels dangerous . ive recalibrated to radio several time re installed firmware tried 2 different motors servo's and rx all with the same result . i installed one of my known xerun 2.1 esc into the exact same combo and works perfect . any ideas ? cheers
some info i forgot to add . the combo seems to work fine within a few metres of the tx but if it gets more than 5 or 10 metres the throttle steering delay is there . does anyone here have experience with bec glitchbuster setups . ive never had any problems with my xerun stuff except this one . any help greatly appreciated . cheers
Ok, somewhat an update, work around and wtf moment in regards to this software/firmware nightmare..
Downloaded the Turnigy 2 in 1 programming box software 1.62 from here http://www.hobbyking.com/hobbyking/s...less_ESC_.html
*note* you'll have to click on the files tab to access the file.
Installed the software on both my desktop and laptop. Hooked up the esc to my 2 in 1 box, and to my surprise it not only worked but it gave me the option of flashing the esc with V1_508_no timing software.
Flashed the esc with above software, checked all the settings and disconnected pc from the 2 in 1 box. Turned car back on with only the 2 in 1 box plugged in and I was able to access & adjust the settings using the 2 in 1 box only.
Switched car off, switched car back on again, display read the following - 1.08_120504, then V1_508_No Timing.
Then I connected the esc into the receiver and switched the car on again, red led on esc blinks and car works fine.
What the heck!
If someone can point me to where I can download the hobbywing 1.63 software (if it exists) along with the 1.62 I'd appreciate it as I'd be able to see if it gives me the same or more no timing software options.
Cheers
Rob
What the heck!
Cheers
Rob
@M7H
Your method worked superb! The LCD box I got from my friend had v1.08_111007 and not v1.08_120504. With this "older" version of the v1.08 on the box I was able to use software v1.64 to downgrade the LCD box to v1.07_101224. At this point I flashed the esc with v1.10_09025_MOD. I then closed software v1.64 and opened v1.63 and was able to flash the esc with V1_508_no timing!!!!!
Thank you soooo much!
NOTE: And I did this with all 3 versions of the software installed to the PC!!!!! V3.1, V1.64 and V1.63 all on my desktop and working great!!! Didnt have to uninstall anything.
I have all (well, most) USB-link pc version on a USB stick, and run the program from there if needed. Yes I have this USB stick with me at the track. If anybody needs help, I just need a pc/laptop/notebook, which nowadays is almost always available.
There where more V1.63 versions, but the one I use in 12scale is this one:
http://sdrv.ms/VAi4uZ
The Turnigy software works but I'd prefer to have Hobbywing software.
I'll let you know if it works or not, that way others may be helped that have a similar situation.
Cheers
Rob.
If I don't forget, I'll upload all the versions I have tonight (it's 12.53 now here)
have any one a link for 3.1 pc software?????
you dont want the new software...?
You can PM me your email and i can try to email the zip file...
