Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 12-04-2012, 01:25 PM   #10261
Got a problem with my v3.
If I use the throttle the car works ok, I then take my throttle back to neutral and it is as if the motor won't spin, back to neutral and accelerate and it works ok again, back to neutral and it won't work again and so on.
I've tried two different motors and still the same problem.
Any ideas?
Mb3195 is offline   Reply With Quote
Old 12-04-2012, 01:59 PM   #10262
AdrianM's Avatar
Originally Posted by ByteStream View Post
Your question has alredy been answered.
Reread Post #10225
V3_508_NO Timing will not work on my Justock. If I try to use it the apply changes button is grayed out and will not allow me to make changes to the ESC. If I connect the LCD box to the ESC running Blinky - V3_508_NO Timing it prompts me to update software. When I revert to Blinky - V1_508_NO Timing all is well.
Cobraracing has sent me new software and a setting file and after installing it twice following instructions precisely it doesn't work so I continue to run V1_508.
Its fine as the Speedo fast and brakes work fine in my WGT car.
Adrian Martinez
Old 12-04-2012, 02:23 PM   #10263
Any ideas?
Solved it! Powerpot was shorting out
Old 12-04-2012, 02:30 PM   #10264
pressure's Avatar
Default Revention Pro and Hobbywing?
I Have a S/P revention Pro that I'm having trouble with can I load hobbywing software on it? Are the brands compatible? If so whats required ? Any pointers would be appreciated.
ITS COMPLICATED......................
pressure is offline   Reply With Quote
Old 12-04-2012, 02:34 PM   #10265
ByteStream's Avatar
1. Are you running the software as Admin on your PC?
2. What Windows version?
3. What version of LCD Program Box software do you have installed?
I have noticed that when you update your USB Link software, like cobra mentions with files and you don't run in admin mode, then your 'Apply' button will be grey'd out.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 12-04-2012, 02:36 PM   #10266
ByteStream's Avatar
I'm pretty sure Hobbywing does not make the Reventon series .. so you'll need to hit up the SP thread.
Old 12-04-2012, 08:53 PM   #10267
Default Punch control
What throttle punch level is good with a 4.5T motor on a TC with the V2.1?
Med grip asphalt technical track
zzztech is offline   Reply With Quote
Old 12-04-2012, 11:02 PM   #10268
Originally Posted by puma303 View Post
I did some testing with stock firmware and eventually I began with turbo and boost to 0, should be a kind of no timing, right? I did not mind how it was because the car was quieter, next time I would try to turn it up a bit. The values ​​that I set before was 20 for and 24 for the turbo boost, advice?
the engine is a Lipotech 10.5t, RDF 6.22 ( hot bodies tcx with pinion and crown module 48 )
thanks for help.
I'm having a problem with the stock firmware. If I set my BRAKE DRAG FORCE in custom (value 23) and then put INITIAL BRAKE FORCE to =DRAG BRAKE FORCE I can't enter the reverse, putting on INITIAL BRAKE FORCE another value reversing enter and work correctly. I tried to flash several times, even several times in a row. Some help?
up
puma303 is offline   Reply With Quote
Old 12-05-2012, 04:32 AM   #10269
lewis110's Avatar
If you have the drag brake set to 23. Why not just set your initial brake to 20? That's a known bug in the system. I personally don't run reverse so its not a big deal.
Hobbywing of North America/FalconSekido www.falconsekido.com
Hobby-Pro USA www.hobbyprousa.com
Dialed RC Hobbies/VP Pro USA www.Dialedhobbies.com
lewis110 is offline   Reply With Quote
Old 12-05-2012, 05:36 AM   #10270
AdrianM's Avatar
1. Yes, running program as Admin (Right click shortcut, click advanced, check run as admin)
2. Win 7 will all latest updates
3. 1.08, 1.11 will hang up while loading and not complete.
Adrian Martinez
Old 12-05-2012, 06:52 AM   #10271
ByteStream's Avatar
I ran into this a couple of weeks ago with someone else's Justock. I'll try to test it out again when I get back to the track as I can't remember off-hand what we did to fix the issue.
Either we tried installing the software on a different computer (I have had issues with my Win7 machine and all kinds of software).
Or we tried an older version of the USB Link Software, which you can get here: Version 1.64
For the LCD Program Box Firmware - V1.11 is for the XERUN-120A-V3 ESC only so use 1.08 for your Justock.
Old 12-05-2012, 09:41 AM   #10272
AdrianM's Avatar
I appreciate the help. Let me know what you find.
All in all I am very happy with the Justock as it is. It is smooth and works perfectly...even the brakes.
I got it as an emergency speedo after I blew up my Tekin RS Pro. I just got a new speedo from Tekin as a non-warranty replacement. I will be trying it and the Justock back to back tonight. I am very interested to see if there is any difference in lap times
Adrian Martinez
Old 12-06-2012, 03:59 PM   #10273
COBRARACING's Avatar
Dear Adrian
first i would like to thank you for choosing hobbywing
Your not doing anything wrong when you update to v3 508 zero timing it is actually in v3 508 zero timing the message you get at the end please update software that is an error in the program that the usb link is not seeing .
look at the area software version once you click on upgrade on the usb link and you will see it will have v3 508 zero timing that is the version you are in now the other message is an error in the software i will fix it asap .
regards Angelo
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 12-06-2012, 04:18 PM   #10274
[QUOTE=Mb3195;11515584]Got a problem with my v3.
Any ideas?[/QUOTE
Have you tried a new sensor cable ?
but more important when you press the throttle can you please spin the motor or if in the car turn the wheels by hand and let me know if it kick starts ?
Old 12-06-2012, 04:21 PM   #10275
Six/6 is a Good level for punch but remember you will need a high discharge battery pack like a 50c and over rating to handle higher punch /torque levels or else it will just cut out especvially with current demanding low turn motors like your 4.5T
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
