Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 11-29-2012, 08:57 PM   #10231
COBRARACING's Avatar
Originally Posted by Vrooom View Post
I got a xtreme stock esc, I accidently crossed the battery wires only for nenosecond. the sensor? board is burned out, but in sensorless mode, it work ok fine, smoothly accerlate. but when i connect sensor cable, it will not move at standstill unless i push the car forward. any idea how i can fix or resolve it? can anyone repair this? i has this esc for 2 years,
I was told, you can run motor down to 5.5T without boost with certain firmware with xtremestock, is that true?
ok what has happened is that you have damaged one of the phases and thats the reason why it will not work with a sensor from start .
Now that you are running in sensorless mode it will work as esc sends current to two phases because it doesnt know were the rotor of the motor is positioned at any given time and thats the reason it works were with the sensor the esc needs to know were the rotor is positioned as it applies a current only to one phase and thats the reason why when you push the car manually it will start as the hall sensors have detected the rotor at a working position .
You need to send the esc in for repair
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 11-30-2012, 11:43 AM   #10232
ScottyTC4NZ's Avatar
Send a message via MSN to ScottyTC4NZ
Default 21.5t setup
Hey Guys and Girls
Looking for a setup for V3, 21.5t Open (boosted/turbo) on a flowing low traction track, will need to know what FDR to run too.
Jamie Scott
Onroad Race Director
O.R.C.C.C
Titan ARC R10 2013 / Blitz / Sweep / Team Titan
Titan ARC R10 Upgrade / Blitz / Sweep / Team Titan
ScottyTC4NZ is offline   Reply With Quote
Old 11-30-2012, 01:40 PM   #10233
Barry_Hughes's Avatar
Originally Posted by ScottyTC4NZ View Post
Hey Guys and Girls
depends so much on the motor you are using, whether it is a torquey or rpm motor!
But fdr is normally around 5.
Boost & turbo dependent on the motor.
Start rpm 1500 to 3000
end rpm 12000 to 15000 rpm
boost by Th
Turbo by Th
as guide if you have been using a 2.1 use similar settings post your rpm start and acc and I can tell you the boost end rpm.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 11-30-2012, 01:44 PM   #10234
AdrianM's Avatar
I damaged my Tekin and got a Justock as a low cost replacement for a few races until it was repaired. I am not sure I want to take it out. I race 1s/13.5 Blinky WGT and I am on pace with the fastest locals running $200 speeod with a $55 Justock....pretty impressive.
Adrian Martinez
Old 11-30-2012, 07:27 PM   #10235
Any nice surprises prior to TITC 2013?
cheapskate.brok is offline   Reply With Quote
Old 11-30-2012, 08:41 PM   #10236
TCCustoms's Avatar
I wish you would have posted that about 2 days ago...just spend $60 on the Xtreme Stock for a few more options down the road but knew the Justock would have been plenty and now that its on sale for $50 at falconsekido.com i knew i should have stuck with the Justock, Dagnabit!
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 11-30-2012, 11:54 PM   #10237
utah300rum's Avatar
Trader Rating: 27 (100%+)
Just picked up a CRC 1/12 pan car and a Hobbywing 1s ESC....we are running a 13.5 blinky class.....what software version would be best?
I looked thru the thread quite a bit and couldnt find an answer
Spooky's Racing for Asphalt & Carpet, Blacksheep Raceway for off-road, Utah Mountains for bashing!
utah300rum is offline   Reply With Quote
Old 12-01-2012, 03:11 AM   #10238
For blinky on a 1S Speedo, use the V3_508_NoTiming software, don't forget to remove the voltage cutoff and rebind your transmitter though !
CPD Racing
chris_dono is offline   Reply With Quote
Old 12-01-2012, 08:10 AM   #10239
ByteStream's Avatar
The HW 1S is also a V2 based ESC:
Post #10225
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 12-01-2012, 12:34 PM   #10240
TCCustoms's Avatar
ok, the voltage cut-off...why are you turning that off?
Old 12-01-2012, 05:27 PM   #10241
ByteStream's Avatar
Because there is a bug in the software that has yet to be fixed.
The bug is with 1S packs only .. the ESC thinks it's a low 2S battery and does not recognize it as a 1S. If you set it to something other than "off" then it won't work for 1S applications. So we just turn it off and it works perfectly fine.
It is something that needs to be fixed and has been an issue for a very long time.
Old 12-01-2012, 05:58 PM   #10242
TCCustoms's Avatar
so if i run 2s packs only do i set the LVC like on my SCT Pro to custom and do a 6.2v as i was told if you do custom it goes of total voltage and so far has worked good but thought about goin back to the 3.2 or 3.0 setting since HW seems to be slightly off on the settings
Old 12-02-2012, 01:26 AM   #10243
ta04evah's Avatar
Correct me if I am wrong, when setting up the 1S esc you have a 2S plugged into it until all the settings are done?
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 12-02-2012, 01:48 AM   #10244
boost by Th
Turbo by Th
Either a hw 21.5 or a sp mmm 21.5t
Jamie Scott
O.R.C.C.C
Old 12-02-2012, 07:23 AM   #10245
ByteStream's Avatar
If you run 2s only .. you can set it to whatever you want, 3.0, 3.2, custom, etc.
Cheers
Rob.
It use to be like that .. however I don't remember doing that recently. I'll have to double check. I think the LVC might be set to "off" by default now, which would solve that particular problem (unless of course you turned it back on).
