Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 11-08-2012, 06:23 AM   #10111
M7H
M7H's Avatar
Originally Posted by Stanmarsh View Post
Hi guys
Anyone a good setup for TW Modified indoor mid size track with 4.5 motor?
Thanks a lot
Regards from Switzerland
Sandro
4.5T indoor.
I say, blinky.
Just use the latest MOD firmware, and be gentle with boost.
Serpent
M7H is offline   Reply With Quote
Old 11-08-2012, 09:19 AM   #10112
I asked a couple pages back, but maybe it was missed.
Any updates on the upcoming V3 1S?
Steve S is offline   Reply With Quote
Old 11-08-2012, 12:55 PM   #10113
Thanks guys
CTEKTOOL is offline   Reply With Quote
Old 11-09-2012, 03:58 AM   #10114
Hi. I bought a V3, downloaded the software (120808) upgraded the 2 in 1 box (V1.11 120331) but all i have is V3 110930STOCK.
On the main screen i have, 'About, basic, advanced and firmware upgrade. I dont have any other options which are, 'about, general, throttle control, brake control boost turbo and data record. Any help please?
Also, when I plug in the box it says, please update software.
RSCosworth is offline   Reply With Quote
Old 11-09-2012, 05:09 AM   #10115
any news about the possibility to have usb link software on android?
puma303 is offline   Reply With Quote
Old 11-09-2012, 08:34 AM   #10116
Yes, please provide for android device
b.wihardja is offline   Reply With Quote
Old 11-09-2012, 10:27 AM   #10117
SlideMasteR's Avatar
+1 for Android app !!
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 11-10-2012, 01:00 AM   #10118
any news about the bluetooth module?
cheapskate.brok is offline   Reply With Quote
Old 11-10-2012, 02:53 AM   #10119
Guys really need some help pls.
We are having a problem with 17.5t and 13.5t boosted that the esc v3 goes into safe mode at grid pull away, switch off and on and you can complete the whole race.
We have changed servo's, use 4 caps, check sensor leads and esc rx read what els could it be.
It happened with 3 different cars the past nats weekend.
Thanks Charl
TQ Hobbies South Africa Home of 3Racing, Team Power SA, Avid Bearings, TQ Power High Power Lipo's and TQ Raceway Club KBY.
charl mac is offline   Reply With Quote
Old 11-11-2012, 09:52 PM   #10120
glide 1's Avatar
Hi everyone, i am having all sorts of problems with both my 120A ver.2.1 and 60A ver.2.0 esc's right after latest firmware updates. I'm still trying to read as much in this thread to see if i can solve this but as of now, no luck.
I would like to flash back to the older firmware (if possible??) so if anyone has previous versions of the firmware for program card and esc they could email me, that would be much appreciated. galensalvador(@)yahoo.com.
Still troubleshooting and need to comfirm that both esc's were working 100% up until i updated it.
edit: previous to V1.08_120504 for program card and V3.0_110930STOCK for esc
glide 1 is offline   Reply With Quote
Old 11-11-2012, 11:14 PM   #10121
TeamWTF's Avatar
930 is the latest stock software, I'd say you have put V3 ESC software onto your esc's.
Not sure on how you go back, but it should be on the drop down menu...?
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 11-11-2012, 11:30 PM   #10122
TeamWTF's Avatar
I may have read you wrong, did you go to 930 or from it?
Old 11-12-2012, 02:10 AM   #10123
glide 1's Avatar
@TeamWTF yes I updated to 930 and had issues. The previous version i had could have been 2 updates before 930 not sure.
Old 11-12-2012, 05:15 AM   #10124
TryHard's Avatar
Strange... if it's a V3, all the software should be showing up fine to upgrade. For some reason, sounds like it's only seeing the V2 software. In the upgrade area, what databse version do you have?
Thanks Charl
What motors are you using, and what batteries?
If your settings are too high for what the batteries can supply, then the speedo can lapse into sensorless, especially in a high draw situation like starting from dead stop.
Can you post up the settings you are using?
Other things to look at are rotor spacing (although unlikely if it's different motors), as well as cleaning out the sensor boards both on motor and ESC.
Easiest way to flash back, is to drop the esc's back to the 524 or V1 508, then flash back up to the software you want to use. Should be able to do that without dropping the program box back as well.
HiH
Ed
Old 11-12-2012, 05:42 AM   #10125
[QUOTE=TryHard;11431584]Strange... if it's a V3, all the software should be showing up fine to upgrade. For some reason, sounds like it's only seeing the V2 software. In the upgrade area, what databse version do you have?
I believe it comes up as 120511 or something like that. It doesnt come up as 120808. I have double checked and it is definatley software version V3.1 that i have downloaded.
