Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 10-06-2012, 11:36 PM   #9991
Originally Posted by COBRARACING View Post
The sensor port had been fixed with the 508 zero timing v3 version a very long time ago which was to sensitive with some motors like the lrp etc .now you might want to have a look at your motor and the sensor board in that motor you might have some damaged hall sensors even one can cause an issue as it will send back a distorted signal back to the esc .
I can use soft 508 with hardware xerun 2.1?
thanks and regards
TyoBBS is offline   Reply With Quote
Old 10-07-2012, 12:10 AM   #9992
ta04evah's Avatar
thanks and regards
Yes, you can use the 508 No Timing software with either the 60amp or 120amp Xerun 2.1
Cheers
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 10-07-2012, 09:02 AM   #9993
Cheers
Rob.
But if i want to use MOD i need to use and old one? Or is possible to use 508MOD with hardware xerun 2.1 (120A)?
thanks and regards,
Old 10-07-2012, 10:37 AM   #9994
anyone have good start setup for Hobbywing V3?
i race Boosted stock 17.5.
Zooberg is offline   Reply With Quote
Old 10-07-2012, 11:37 AM   #9995
i have tried the same question before, but with the extremestock and no one seems to know, so im just going to go from scratch and see how it ends up if i dont find a good setup there is another brand that has setups that are easy to find
but i did like my xtremestock last year so should be able to get some speed from it
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 10-07-2012, 01:31 PM   #9996
Originally Posted by narcotiks View Post
anyone tried turbo start by full throttle and rpm on the V3?
i felt it was more responsive in the infield and had a better feel when kicking in on the straight
That's how I run mine all the time and you're right, it's better.
CPD Racing
chris_dono is offline   Reply With Quote
Old 10-07-2012, 01:37 PM   #9997
What do you set the RPM settings to ?
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 10-07-2012, 07:13 PM   #9998
COBRARACING's Avatar
Please read the instructions either for the 2.1 or the v3 or the extreme stock there are basic setups listed which also explain what each does .
If you dont have the instructions please download them from the website www.hobbywing.com
Start from basics and work from there .If someone has a setup it doesnt mean its going to work for you being track size and driver ability plus car and gearing so it's better you read the instructions and work from there
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 10-08-2012, 12:41 AM   #9999
narcotiks's Avatar
Say if your boost end RPM was 20,000 , you would put the turbo start rpm at 20,000 so as the boost is fully applied, the turbo will be ready to engage soon as you hit full throttle. I haven't tried putting the turbo start rpm 1k more than the boost end rpm, all though i don't think it would yield and advantage over what i suggested before.
narcotiks is offline   Reply With Quote
Old 10-08-2012, 04:05 AM   #10000
ta04evah's Avatar
thanks and regards,
I cant see why not. The latest software is compatible both with xerun v3 & xerun 2.1/2.0
From the hobbywing site:
1. Functions
The USB LINK SOFTWARE is a PC program working together with the LCD Program Box, it has the following functions:
1.1 Precisely sets the programmable items of the ESC.
1.2 Upgrades the firmware of the ESC.
1.3 Upgrades the firmware of the Professional LCD Program Box.
1.4 Analyses the "Governor mode" parameters for RC helicopter
(This is the function of a subprogram named "Speed Calculator")
2. Software Versions
Version 3.1_120808
The Version 3.1 is suitable for the following ESC:
XERUN Series Car ESC (Version 3.0 and later)
XERUN Series Car ESC (Version 2.0 and 2.1)
EZRUN Series Car ESC (Version 2.0 and later)
PLATINUM Series helicopter/airplane ESC
However for absolute confirmation you'd best ask Cobra about your question.
Cheers
Rob.
Old 10-08-2012, 08:20 AM   #10001
it depends on the motor wind you're running really, but somewhere around the boost end rpm is usually good.
CPD Racing
Old 10-09-2012, 07:04 AM   #10002
Default About motors/sensors compatibility
Hi,
I've started to have sensor problems with my 2 Xeruns 120A v2.1 recently. I was running a tekin 8.5 without problems between them, but now the ESCs enter in sensorless mode randomly. I've then tested some other motors (and sensor cables, of course), for example a Fantom ION 1 with a brand new sensor harness and they enter sensorless mode almost inmediately, but with a cheap speed passion ultrasportsman v2.0 9.5T they work perfectly. I'm also running the latest software version, 930, tried both mod and stock.
Talking with some friends at our track, some of them have had problems with speed passions MMM motors and had to change the sensor harness to the new +10 degrees version, which seems to improve reliability, and another friend has a new V3.0 Xerun that is unable to work with any of his Novak motors.
I don't understand why this is happening, and I'd like to know if there is any compatibility chart or motor recommendations for the Xerun. Maybe HW motors are the only ones that are 100% guaranteed?
Gusi is offline   Reply With Quote
Old 10-09-2012, 07:20 AM   #10003
Originally Posted by Gusi View Post
Hi,
I've started to have sensor problems with my 2 Xeruns 120A v2.1 recently.(...) I'm also running the latest software version, 930, tried both mod and stock.
I read some post like this. In website says is possible to use new version 930MOD with xerun 2.1 but may be is better old one... Did you test with old software (like 119MOD)?
In another hand i asked to hobbyking website, email and here but don't have it any answer from cobra...
regards
Old 10-09-2012, 08:56 AM   #10004
regards
I saw with my eyes , in a friend's tc, the 930 solved his sensor problems. I've been running 930 for some months without problems, but I'll give it a try and will downgrade. Anyway, I think there is a real problem with the sensivity of different motor brands, and an official compatibility list would be great.
Maybe with the rotor losing magnet strength, the sensors have wrong reads and that's why the xerun fails with the same motor that was working perfectly for months?
Old 10-09-2012, 12:29 PM   #10005
Barry_Hughes's Avatar
I actually run turbo start rpm under the end of the boost rpm, so the two overlap!
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
